How to configure M3 as syslink master and Linux syslink as a slave?.
Dear Sirs:
  This question is raised previously in DM814x and AM387x Processors Forum. And I was told to ask here in TI-RTOS Furum.
  We are using a DM814x CPU. And we are trying to start the M3/DSP before linux on A8 starts up.
  We have now can load and run the M3/DSP successfully by using u-boot.
  But it is looped in calling Ipc_start due to the IPC is not ready in A8. So I try to make the M3 as a mater in the system the let M3/DSP running first and later when linux startup, I can control it through syslink. To make this happen, can you give me some hints to do this?
  Or you may give me some more advices/examples that running M3/DSP with syslink/ipc without linux starts first. Even not a DM814x CPU example is also welcome.
Sincerely,
/ckhsu
