AM3894 Waiting for root device /dev/mmcblk0p2
Other Parts Discussed in Thread: PMP
Loading kernel stop on "Waiting for root device /dev/mmcblk0p2..."
I am not use card detect pin on CPU (card detect pin pullup 10KOm on 3.3V).
My boot log:
Linux version 2.6.37 (admin@admin) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Mon Apr 27 11:16:19 MSK 2015
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8168evm
vram size = 52428800 at 0x0
reserved size = 52428800 at 0x0
FB: Reserving 52428800 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8168 1.1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 31904
Kernel command line: console=ttyO0,115200n8 rootwait root=/dev/mmcblk0p2 rootfstype=ext3 rw mem=176M@0x80000000 vram=50M notifyk.vpssm3_sva=0xBF900000 vpss s
bufaddr=0xBFB00000 vmalloc=500M
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 126MB = 126MB total
Memory: 121960k/121960k available, 58264k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xcb800000 - 0xf8000000 ( 712 MB)
lowmem : 0xc0000000 - 0xcb000000 ( 176 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc003c000 ( 208 kB)
.text : 0xc003c000 - 0xc04df000 (4748 kB)
.data : 0xc04e0000 - 0xc0528f40 ( 292 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 27000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 0
_omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
_omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
NOR: Can't request GPMC CS
registered ti816x_gpio_vr device
registered ti816x_sr device
pm_dbg_init: only OMAP3 supported
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
registered ti81xx_vin device
ti81xx_pcie: Invoking PCI BIOS...
ti81xx_pcie: Setting up Host Controller...
ti81xx_pcie: Register base mapped @0xcb820000
ti81xx_pcie: Starting PCI scan...
PCI: bus0: Fast back to back transfers enabled
bio: create slab <bio-0> at 0
regulator: VFB: 800 <--> 1025 mV at 800 mV
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea20808
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc: kernel must blacklist external hubs
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at cb81e000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at cb826800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 238
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
brd: module loaded
loop: module loaded
ahci ahci.0: forcing PORTS_IMPL to 0x3
ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16
omap2-nand driver initializing
No NAND device found.
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffd
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmci-omap-hs: probe of mmci-omap-hs.0 failed with error -16
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbf900000
usbcore: registered new interface driver snd-usb-audio
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
ALSA device list:
#0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
smartreflex smartreflex: Driver initialized
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
  • Sergey,
    Are you using UART0 for console? Or using the default UART2? Can you try with the below boot args:
    Kernel command line: console=ttyO2,115200n8 rootwait root=/dev/mmcblk0p2 rw mem=364M@0x80000000 mem=320M@0x9FC00000 vmalloc=500M  notifyk.vpssm3_sva=0xBF900000 ip=off noinitrd
    Make sure also you are aligned with the below AM389x silicon errata advisory:
    Advisory 2.1.106  SDIO: SD_SDCD Pin Used as an GPIO Input Affects SDIO Operation
    Pavel
  • Pavel,
    Yes, i am use UART0 as default.
    Try, not effect.
    I find post: e2e.ti.com/.../399022
    And replace function in mmc driver on:
    static int omap_hsmmc_get_cd(struct mmc_host *mmc)
    return 1;
    static int omap_hsmmc_get_ro(struct mmc_host *mmc)
    return 0;
    Now kernel detect sd-card, but there are new errors:
    Machine: ti8168evm
    Built 1 zonelists in Zone order, mobility grouping on. Total pages: 160648
    Kernel command line: console=ttyO0,115200n8 rootwait root=/dev/mmcblk0p2 rw mem=364M@0x80000000 mem=320M@0x9FC00000 vmalloc=500M notifyk.vpssm3_sva=0xBF900000 ip=off noinitrd
    PID hash table entries: 2048 (order: 1, 8192 bytes)
    Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    Memory: 364MB 270MB = 634MB total
    Memory: 637816k/637816k available, 62600k reserved, 276480K highmem
    vmalloc : 0xd7000000 - 0xf8000000 ( 528 MB)
    lowmem : 0xc0000000 - 0xd6c00000 ( 364 MB)
    .init : 0xc0008000 - 0xc003b000 ( 204 kB)
    .text : 0xc003b000 - 0xc04d8000 (4724 kB)
    .data : 0xc04d8000 - 0xc0520f00 ( 292 kB)
    NR_IRQS:407
    GPMC revision 6.0
    regulator: dummy:
    ti81xx_pcie: Register base mapped @0xd7020000
    vgaarb: loaded
    Cppi41 Init Done
    musb-hdrc musb-hdrc.0: USB Host mode controller at d701e000 using DMA, IRQ 18
    musb-hdrc musb-hdrc.1: USB Host mode controller at d7026800 using DMA, IRQ 19
    IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
    TCP established hash table entries: 65536 (order: 7, 524288 bytes)
    TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
    TCP: Hash tables configured (established 65536 bind 65536)
    TCP reno registered
    highmem bounce pool size: 64 pages
    msgmni has been set to 705
    brd: module loaded
    loop: module loaded
    ALSA device list:
    #0: TI81XX EVM
    mmc0: new high speed SD card at address f1a3
    mmcblk0: mmc0:f1a3 SD02G 1.87 GiB
    mmcblk0: p1 p2
    EXT3-fs: barriers not enabled
    kjournald starting. Commit interval 5 seconds
    EXT3-fs (mmcblk0p2): using internal journal
    EXT3-fs (mmcblk0p2): recovery complete
    EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
    VFS: Mounted root (ext3 filesystem) on device 179:2.
    devtmpfs: mounted
    Freeing init memory: 204K
    INIT: version 2.86 booting
    Please wait: booting...
    mmcblk0: retrying using single block read
    mmcblk0: error -110 sending read/write command, response 0x0, card status 0xc00b00
    mmcblk0: error -110 transferring data, sector 1554885, nr 8, card status 0xc00b00
    end_request: I/O error, dev mmcblk0, sector 1554885
    Error opening /dmmcblk0: error -110 sending read/write command, response 0x0, card status 0x400b00
    ev/fb0: No such mmcblk0: error -110 transferring data, sector 1554886, nr 7, card status 0x400b00
    file or directorend_request: I/O error, dev mmcblk0, sector 1554886
    y
    mmcblk0: error -110 transferring data, sector 1554887, nr 6, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 1554887
    mmcblk0: error -110 transferring data, sector 1554888, nr 5, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 1554888
    mmcblk0: error -110 transferring data, sector 1554889, nr 4, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 1554889
    mmcblk0: error -110 transferring data, sector 1554890, nr 3, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 1554890
    mmcblk0: error -110 transferring data, sector 1554891, nr 2, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 1554891
    mmcblk0: error -110 transferring data, sector 1554892, nr 1, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 1554892
    EXT3-fs error (device mmcblk0p2): ext3_find_entry: reading directory #40001 offset 0
    mmcblk0: error -110 transferring data, sector 976517, nr 8, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 976517
    mmcblk0: error -110 transferring data, sector 976518, nr 7, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 976518
    mmcblk0: error -110 transferring data, sector 976519, nr 6, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 976519
    mmcblk0: error -110 transferring data, sector 976520, nr 5, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 976520
    mmcblk0: error -110 transferring data, sector 976521, nr 4, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 976521
    mmcblk0: error -110 transferring data, sector 976522, nr 3, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 976522
    mmcblk0: error -110 transferring data, sector 976523, nr 2, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 976523
    mmcblk0: error -110 transferring data, sector 976524, nr 1, card status 0x400b00
    end_request: I/O error, dev mmcblk0, sector 976524
    mmcblk0: error -110 transferring data, sector 80325, nr 8, card status 0x0
  • Sergey,
    We have two filesystems in the EZSDK:
    ti-ezsdk_dm816x-evm_5_04_00_11/filesystem/ezsdk-dm816x-evm-rootfs.targ.gz and arago-base-tisdk-image-dm816x-evm.tar.gz
    The script should create you SD card with ROOTFS partition for the filesystem, and extract ezsdk-dm816x-evm-rootfs.targ.gz by default. Can you try with removing this filesystem from the ROOTFS and put the other one instead.
    See also the below e2e threads which discuss similar issues:
    e2e.ti.com/.../348145
    e2e.ti.com/.../473772
    e2e.ti.com/.../199914
    e2e.ti.com/.../160266
    e2e.ti.com/.../719053
    e2e.ti.com/.../264401
    e2e.ti.com/.../299255
    e2e.ti.com/.../191322
    e2e.ti.com/.../1167180
    Pavel
