HEVC Encoder (01_00_00_44) works good in a single DSP , but it doesn't work on multiple DSPs as bit stream of the output looks like was wrong. The stream can be used as ffmpeg software decoding, but the decoded image is wrong, and the image which is 0 core decoding is correct, 0~11's image were wrong (I used 12 cores to encode the YUV image)
Question1: I doubt when multiple DSPs station, enabled the mailbox moule and other modules, then worng YUV address was transfer to slave cores including core 8, How do I can do?
Question 2, how does the YUV address passed to the master_slave core and slave cores?
Question 3, I have
description :I have read the similar posts, found that he had LOG, but did not know how the LOG is generated, the example LOG is
Start at 2015-03-25 02:42:29 +0100 [2015-03-25 02:42:30] main() on DSP#0 CORE#0 [2015-03-25 02:42:30] Activating core 1 [2015-03-25 02:42:30] Activating core 2 [2015-03-25 02:42:30] Activating core 3 [2015-03-25 02:42:30] Activating core 4 [2015-03-25 02:42:30] Activating core 5 [2015-03-25 02:42:30] Activating core 6 [2015-03-25 02:42:30] Activating core 7 [2015-03-25 02:42:30] Starting IPC [2015-03-25 02:42:30] IPC: attaching to core#1 [2015-03-25 02:42:30] Attached [2015-03-25 02:42:30] IPC: attaching to core#2 [2015-03-25 02:42:30] Attached [2015-03-25 02:42:30] IPC: attaching to core#3 [2015-03-25 02:42:30] Attached [2015-03-25 02:42:30] IPC: attaching to core#4 [2015-03-25 02:42:30] Attached [2015-03-25 02:42:30] IPC: attaching to core#5 [2015-03-25 02:42:30] Attached [2015-03-25 02:42:30] IPC: attaching to core#6 [2015-03-25 02:42:30] Attached [2015-03-25 02:42:30] IPC: attaching to core#7 [2015-03-25 02:42:30] Attached [2015-03-25 02:42:30] Starting SYS/BIOS [2015-03-25 02:42:30] Initialization task @00848318 [2015-03-25 02:42:30] Initializing GateMP [2015-03-25 02:42:30] L2 free 10f08 of 14810 addr=@00845d00 handle=@00866fa0 [2015-03-25 02:42:30] DDR3 free 39ffff80 of 39ffff80 addr=@86000080 handle=@008460e8 [2015-03-25 02:42:30] DDR3U free ffff80 of ffff80 addr=@85000080 handle=@00846118 [2015-03-25 02:42:30] MSMC free 24bc80 of 24bc80 addr=@00846000 handle=@008460b8 [2015-03-25 02:42:30] Initializing IPC interrupts [2015-03-25 02:42:30] Initializing codec interrupts [2015-03-25 02:42:30] Initializing RMAN [2015-03-25 02:42:30] Using EDMA3 instance 1 [2015-03-25 02:42:30] Using 12 EDMA channels for codecs and 4 for auxiliary purposes [2015-03-25 02:42:30] Initializing common support algorithm [2015-03-25 02:42:30] Initializing statistics component [2015-03-25 02:42:30] Initializing resize component [2015-03-25 02:42:30] Initializing transcode queue component [2015-03-25 02:42:30] Synchronizing cores [2015-03-25 02:42:30] Commander worker task @0084a1d0 [2015-03-25 02:42:30] Commander task @0084a848 [2015-03-25 02:42:30] Commander worker started [2015-03-25 02:42:30] Commander task started [2015-03-25 02:42:30] COMMANDER: Ping [2015-03-25 02:42:30] COMMANDER WORKER: Pong [2015-03-25 02:42:35] COMMANDER: Creating component #136 [2015-03-25 02:42:35] COMMANDER: Creating component #56 [2015-03-25 02:42:35] Component #56 task @00848338 [2015-03-25 02:42:35] Initializing maser encoder #56 task that runs on 16 cores [2015-03-25 02:42:35] Create input frame queue "E38" [2015-03-25 02:42:35] Initialize video output encoder cyclic buffer: 0x64000000 [2015-03-25 02:42:35] Creating master encoder #56 [2015-03-25 02:42:35] Type: HEVC [2015-03-25 02:42:35] swbarr name=H265Ebarrier1 user_id=0 num_users=16 user_ids=0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15 [2015-03-25 02:42:35] key=@0084e400 barrier value address=@64800240 [2015-03-25 02:42:35] swbarr name=H265Ebarrier2 user_id=0 num_users=16 user_ids=0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15 [2015-03-25 02:42:35] key=@0084e418 barrier value address=@64800250 [2015-03-25 02:42:35] swbarr name=H265Ebarrier3 user_id=0 num_users=16 user_ids=0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15 [2015-03-25 02:42:35] key=@0084e430 barrier value address=@64800260 [2015-03-25 02:42:35] swbarr name=H265Ebarrier9 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 [2015-03-25 02:42:35] key=@0084e448 barrier value address=@85000880 [2015-03-25 02:42:35] swbarr name=H265Ebarrier10 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 [2015-03-25 02:42:35] key=@0084e460 barrier value address=@85000888 [2015-03-25 02:42:35] swbarr name=H265Ebarrier11 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 [2015-03-25 02:42:35] key=@0084e478 barrier value address=@85000890 [2015-03-25 02:42:35] swbarr name=H265Ebarrier12 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 [2015-03-25 02:42:35] key=@0084e490 barrier value address=@85000898 [2015-03-25 02:42:35] lock name=H265E_lock100 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 [2015-03-25 02:42:35] key=@85000980 lock value address=@85000980 [2015-03-25 02:42:35] lock name=H265E_lock200 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 [2015-03-25 02:42:35] key=@85000a00 lock value address=@85000a00 [2015-03-25 02:42:35] shmem name=shared_mem_pcontext00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=SL2 size=13928 alignment=128 [2015-03-25 02:42:35] key=@0c044a80 shm address=@0c045780 size=13928 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_referenceL000 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=SL2 size=517720 alignment=128 [2015-03-25 02:42:35] key=@0c044a98 shm address=@0c048e00 size=517720 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_NAL_params00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=287486 alignment=128 [2015-03-25 02:42:35] key=@0c044ab0 shm address=@8a027500 size=287486 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_DataSync_params00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=800 alignment=128 [2015-03-25 02:42:35] key=@0c044ac8 shm address=@8a06d800 size=800 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_entry_points00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=228 alignment=128 [2015-03-25 02:42:35] key=@0c044ae0 shm address=@8a06db80 size=228 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_NAL_info00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=SL2 size=3512 alignment=128 [2015-03-25 02:42:35] key=@0c044af8 shm address=@0c0c7480 size=3512 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_bitoutInit00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=24 alignment=128 [2015-03-25 02:42:35] key=@0c044b10 shm address=@8a06dc80 size=24 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_CABAC_Context00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=1600 alignment=128 [2015-03-25 02:42:35] key=@0c044b28 shm address=@8a06dd00 size=1600 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_CABAC_Context00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=1600 alignment=128 [2015-03-25 02:42:35] key=@0c044b28 shm address=@8a06dd00 size=1600 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_bitout00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=24 alignment=128 [2015-03-25 02:42:35] key=@0c044b40 shm address=@8a06e380 size=24 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_bitout00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=24 alignment=128 [2015-03-25 02:42:35] key=@0c044b40 shm address=@8a06e380 size=24 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_bitconsumed00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=40 alignment=128 [2015-03-25 02:42:35] key=@0c044b58 shm address=@8a06e400 size=40 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_bitconsumed00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=40 alignment=128 [2015-03-25 02:42:35] key=@0c044b58 shm address=@8a06e400 size=40 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_CABAC_params00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=24 alignment=128 [2015-03-25 02:42:35] key=@0c044b70 shm address=@8a06e480 size=24 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_CABAC_params00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=24 alignment=128 [2015-03-25 02:42:35] key=@0c044b70 shm address=@8a06e480 size=24 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_LCU_strs00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=SL2 size=552 alignment=128 [2015-03-25 02:42:35] key=@0c044b88 shm address=@0c0c8280 size=552 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_MV_Buf_loc00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=38808 alignment=128 [2015-03-25 02:42:35] key=@0c044ba0 shm address=@8a06e500 size=38808 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_MV_Buf00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=28224 alignment=128 [2015-03-25 02:42:35] key=@0c044bb8 shm address=@8a077d00 size=28224 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_MV_Buf00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=28224 alignment=128 [2015-03-25 02:42:35] key=@0c044bb8 shm address=@8a077d00 size=28224 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_const00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=SL2 size=17464 alignment=128 [2015-03-25 02:42:35] key=@0c044bd0 shm address=@0c0c8500 size=17464 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_scan_tables00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=16512 alignment=128 [2015-03-25 02:42:35] key=@0c044be8 shm address=@8a07eb80 size=16512 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_pic_mngmt_str00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=140664 alignment=128 [2015-03-25 02:42:35] key=@0c044c00 shm address=@8a082c00 size=140664 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_ScalingList00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=44520 alignment=128 [2015-03-25 02:42:35] key=@0c044c18 shm address=@8a0a5180 size=44520 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_QPOffsetROI00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=SL2 size=102 alignment=128 [2015-03-25 02:42:35] key=@0c044c30 shm address=@0c0cc980 size=102 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_trans_coeffs00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=1216512 alignment=128 [2015-03-25 02:42:35] key=@0c044c48 shm address=@8a0aff80 size=1216512 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_tmp_bitstream00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=456192 alignment=128 [2015-03-25 02:42:35] key=@0c044c60 shm address=@8a1d8f80 size=456192 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_NAL_info_rmt00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_UNCACHED size=3512 alignment=128 [2015-03-25 02:42:35] key=@0c044c78 shm address=@85000a80 size=5560 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_bitstream00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=456192 alignment=128 [2015-03-25 02:42:35] key=@0c044c90 shm address=@8a248580 size=456192 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_SwappedStream00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=456192 alignment=128 [2015-03-25 02:42:35] key=@0c044ca8 shm address=@8a2b7b80 size=456192 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_chip2chip user_id=0 num_users=2 user_ids=0,8 type=RMT_UNCACHED_NO_LOC size=1152 alignment=128 [2015-03-25 02:42:35] key=@0c044cc0 shm address=@64800280 size=1152 isMultiDsp=1 [2015-03-25 02:42:35] shmem name=shared_recon_stitch_buf user_id=0 num_users=2 user_ids=0,8 type=RMT_UNCACHED_NO_LOC size=446688 alignment=128 [2015-03-25 02:42:35] key=@0c044cd8 shm address=@64800780 size=446688 isMultiDsp=1 [2015-03-25 02:42:35] shmem name=shared_mem_LCU_hdr_loc00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=224928 alignment=128 [2015-03-25 02:42:35] key=@0c044cf0 shm address=@8a327180 size=224928 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_LCU_hdr00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=163584 alignment=128 [2015-03-25 02:42:35] key=@0c044d08 shm address=@8a35e080 size=163584 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_LCU_hdr00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=163584 alignment=128 [2015-03-25 02:42:35] key=@0c044d08 shm address=@8a35e080 size=163584 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_LCU_hdr_EP00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=81792 alignment=128 [2015-03-25 02:42:35] key=@0c044d20 shm address=@8a385f80 size=81792 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_LCU_hdr_EP00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=81792 alignment=128 [2015-03-25 02:42:35] key=@0c044d20 shm address=@8a385f80 size=81792 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_LCU_hdr_WF2_loc00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=224928 alignment=128 [2015-03-25 02:42:35] key=@0c044d38 shm address=@8a399f00 size=224928 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_tH265_SAOStr_loc00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=1984 alignment=128 [2015-03-25 02:42:35] key=@0c044d50 shm address=@8a3d0e00 size=1984 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_SAOStr00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=184 alignment=128 [2015-03-25 02:42:35] key=@0c044d68 shm address=@8a3d1600 size=184 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_SAOStr00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=184 alignment=128 [2015-03-25 02:42:35] key=@0c044d68 shm address=@8a3d1600 size=184 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_CTU_activity00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=139808 alignment=128 [2015-03-25 02:42:35] key=@0c044d80 shm address=@8a3d1700 size=139808 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_chip_activity00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=1056 alignment=128 [2015-03-25 02:42:35] key=@0c044d98 shm address=@8a3f3980 size=1056 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_top_left_recon_loc00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=304128 alignment=128 [2015-03-25 02:42:35] key=@0c044db0 shm address=@8a3f3e00 size=304128 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_dblkd_edge_pixels00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=50688 alignment=128 [2015-03-25 02:42:35] key=@0c044dc8 shm address=@8a43e200 size=50688 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_top_left_recon00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=268 alignment=128 [2015-03-25 02:42:35] key=@0c044de0 shm address=@8a44a800 size=268 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_top_left_recon00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=268 alignment=128 [2015-03-25 02:42:35] key=@0c044de0 shm address=@8a44a800 size=268 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_slice_tile_no_buf00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=146144 alignment=128 [2015-03-25 02:42:35] key=@0c044df8 shm address=@8a44a980 size=146144 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_RefPic_strs00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=SL2 size=504 alignment=128 [2015-03-25 02:42:35] key=@0c044e10 shm address=@0c0cca00 size=504 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_recon00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=4659480 alignment=128 [2015-03-25 02:42:35] key=@0c044e28 shm address=@8a46e480 size=4659480 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_recon_shared00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=366336 alignment=128 [2015-03-25 02:42:35] key=@0c044e40 shm address=@8a8dfe00 size=366336 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_recon_shared00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=366336 alignment=128 [2015-03-25 02:42:35] key=@0c044e40 shm address=@8a8dfe00 size=366336 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_dblk_shared00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=3456 alignment=128 [2015-03-25 02:42:35] key=@0c044e58 shm address=@8a939500 size=3456 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_dblk_shared00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=3456 alignment=128 [2015-03-25 02:42:35] key=@0c044e58 shm address=@8a939500 size=3456 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_SAO_shared00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=27648 alignment=128 [2015-03-25 02:42:35] key=@0c044e70 shm address=@8a93a280 size=27648 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_SAO_shared00 user_id=0 num_users=2 user_ids=0,1 type=DDR_CACHED size=27648 alignment=128 [2015-03-25 02:42:35] key=@0c044e70 shm address=@8a93a280 size=27648 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_local_str00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_UNCACHED size=448 alignment=128 [2015-03-25 02:42:35] key=@0c044e88 shm address=@85002080 size=2496 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=EDMA_State_Struct00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=SL2 size=320 alignment=128 [2015-03-25 02:42:35] key=@0c044ea0 shm address=@0c0ccc00 size=320 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_Mode_Decision00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=2055680 alignment=128 [2015-03-25 02:42:35] key=@0c044eb8 shm address=@8a940e80 size=2055680 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_Mode_Decision_Inter00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=104720 alignment=128 [2015-03-25 02:42:35] key=@0c044ed0 shm address=@8ab36c80 size=104720 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_Mode_Decision_Cost00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=448800 alignment=128 [2015-03-25 02:42:35] key=@0c044ee8 shm address=@8ab50600 size=448800 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_SFRC_State00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_UNCACHED size=1272 alignment=128 [2015-03-25 02:42:35] key=@0c044f00 shm address=@85002a80 size=3320 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_Pre_CABAC_Info00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=2717718 alignment=128 [2015-03-25 02:42:35] key=@0c044f18 shm address=@8abbdf80 size=2717718 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_STM00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=RMT_UNCACHED_LOC_SL2 size=2966 alignment=128 [2015-03-25 02:42:35] key=@0c044f30 shm address=@85003780 size=5014 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_EPO_struct00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=4896 alignment=128 [2015-03-25 02:42:35] key=@0c044f48 shm address=@8ae55800 size=4896 isMultiDsp=0 [2015-03-25 02:42:35] shmem name=shared_mem_adptintra_refresh_lcumap00 user_id=0 num_users=8 user_ids=0,1,2,3,4,5,6,7 type=DDR_CACHED size=102 alignment=128 [2015-03-25 02:42:35] key=@0c044f60 shm address=@8ae56b80 size=102 isMultiDsp=0 [2015-03-25 02:42:35] swbarr name=H265Ebarrier4 user_id=0 num_users=2 user_ids=0,8 [2015-03-25 02:42:35] key=@0084e4a8 barrier value address=@6486d870 [2015-03-25 02:42:35] swbarr name=H265Ebarrier5 user_id=0 num_users=2 user_ids=0,8 [2015-03-25 02:42:35] key=@0084e4c0 barrier value address=@6486d880 [2015-03-25 02:42:35] swbarr name=H265Ebarrier6 user_id=0 num_users=2 user_ids=0,8 [2015-03-25 02:42:35] key=@0084e4d8 barrier value address=@6486d890 [2015-03-25 02:42:35] swbarr name=H265Ebarrier7 user_id=0 num_users=2 user_ids=0,8 [2015-03-25 02:42:35] key=@0084e4f0 barrier value address=@6486d8a0 [2015-03-25 02:42:35] swbarr name=H265Ebarrier8 user_id=0 num_users=2 user_ids=0,8 [2015-03-25 02:42:35] key=@0084e508 barrier value address=@6486d8b0 [2015-03-25 02:42:35] swbarr name=H265Ebarrier9 user_id=0 num_users=2 user_ids=0,8 [2015-03-25 02:42:35] key=@0084e520 barrier value address=@6486d8c0 [2015-03-25 02:42:35] swbarr name=H265Ebarrier10 user_id=0 num_users=2 user_ids=0,8 [2015-03-25 02:42:35] key=@0084e538 barrier value address=@6486d8d0 [2015-03-25 02:42:35] Create encoder buffers [2015-03-25 02:42:35] minNumInBufs 3 [2015-03-25 02:42:35] minNumOutBufs 1 [2015-03-25 02:42:35] minInBufSize[0] 405504 0 [2015-03-25 02:42:35] minInBufSize[1] 101376 0 [2015-03-25 02:42:35] minInBufSize[2] 101376 0 [2015-03-25 02:42:35] minOutBufSize[0] 456192 0 [2015-03-25 02:42:35] Connecting encoder input #56 to output #136 [2015-03-25 02:42:35] Master encoder #56 initialized 704x576@25p
If My analysis is wrong, there is any othee reasons to make a series of code stream is wrong, the results bit streaming isas follows
JL,wang
