Hi
I tried to control LED on my AM437x idk by following "AM437x Industrial Development Kit for Industrial Automation Quick Start Guide"
However, during the steps I meet the problem that after scan for the boxes, manual's TwinCAT automatically import Box(TIESC-001) but in my case there are only input and output.
I did all same steps same as this website's method : "http://processors.wiki.ti.com/images/6/62/AM335x_ICE_QSG.pdf"
- Copy sdk\examples\ethercat\esi\TiEtherCATLib.xml to :\TwinCAT\Io\EtherCAT folder.
- Go to Options > Show Real Time Ethernet Compatible Devices and install the RT Ethernet Adapter connected to the ICE.
- Go to I/O – Confi guration > I/O Devices – right click and select Scan Device. You will see a list of Ethernet adapters on your system, with a tick next to the adapter connected to the ICE. Choose OK. Device n (EtherCAT) will be added to I/O devices
and so on...
Then, what can I do for import exact box for control LED on my AM437x idk board.
Is there any other alternation for control the board with failure to import box( TIESC-001)?
