Linux/AM5728: AM572x EVM boot failed : alg: skcipher: Chunk test 1 failed on encryption at page 0 for ecb-aes-omap
Part Number: AM5728
Tool/software: Linux
I am testing AM572x boot up with Linux OS( using SD card) on AM572x EVM.
I have boot fail once each 100 times. At that time, I see the error message.
        [   18.454801] alg: skcipher: Chunk test 2 failed on encryption at page 0 for cbc-aes-omap
And, I found the similar E2E thread for this error message.
https://e2e.ti.com/support/arm/automotive_processors/f/1020/t/542020
But I could not find  "GIC CPU mask not found - kernel will fail to boot " message. Please see the atached log file.
3107.boot_fail.txt
Is my boot fail same issue of this E2E thread?
Please advise me.
Michi
  • Hi Michi,
    The described above boot fail printing
    "alg: skcipher: Chunk test 2 failed on encryption at page 0 for cbc-aes-omap"
    can be due to memory corruption caused by some kind of electromagnetic confusion or noise.
    I suggest you to add debug message which dumps not only the first string but both compared strings. This can be done by adding in "../linux../crypto/testmgr.c" file after:
    pr_err("alg: skcipher%s: Chunk test %d failed on %s at page %u for %s\n",
    d, j, e, k, algo);
    hexdump(q, template[i].tap[k]);
    printing of second string with:
    hexdump(template[i].result + temp, template[i].tap[k]);
    You can share the booting log after this kernel source modification.
    BR
    Tsvetolin Shulev
