AM5728: Boot fails
Part Number: AM5728
Other Parts Discussed in Thread: DRA752, , PMP, TLC59108, WL1271
Hi ,
Unable to boot from uboot in Dra752 , u-boot getting struck at random places and sometimes it is booting along with kernel ,sometimes after u-boot boots getting hang at kernel .
I dont know what may be rootcause for this ,
Can anyone Help on this issue as it is the urgent requirement for my Project .
Nagarjuna G
    Is this AM572x or DRA752? Which software SDK are you using?
  • Which software SDK are you using? Please post the boot log.
  • Hi ,
    we are using the following SDK
    ti-glsdk_dra7xx-evm_6_10_00_02
    U-Boot 2013.04 (Feb 21 2017 - 11:13:05)
    CPU  : DRA752 ES1.1
    Board: DRA7xx
    I2C:   ready
    DRAM:  1.5 GiB
    WARNING: Caches not enabled
    U-Boot SPL 2013.04 (Feb 21 2017 - 11:13:05)
    DRA752 ES1.1
     DCMIST : sdram.c() : emif_get_dmm_regs_sdp() : 705
     ----------------ddr3_init:ddr3_sw_leveling-------------------
    0x482a f040 =0x0
    0x482a f044 =0x80640300
    0x482a f044 =0xc0500220
    0x482a f04c =0xff020100
    DCMIST : board_init_f(): spl.c : 53
    DCMIST: boot device - 5
    Default mmc->f_max = 52000000
     Frequency After modification  : mmc->f_max = 24000000
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    CPU  : DRA752 ES1.1
    Board: DRA7xx
    I2C:   ready
    DRAM:  1.5 GiB
     NOR config : gpmc_cfg->cs[0] = 0x848
     NOR config : gpmc_cfg->cs[1] = 0x850
    Flash:  cfi_flash_bank_addr(0) = 0x8000000
     Flash info : flash_info[i].flash_id = 0x1000000 : size = 0x8000000
     cfi_flash_bank_addr(1) = 0x10000000
     Flash info : flash_info[i].flash_id = 0x1000000 : size = 0x10000000
    256 MiB
    MMC:   Default mmc->f_max = 52000000
    OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Using default environment
    In:    serial
    Out:   serial
    Err:   serial
    Net:   <ethaddr> not set. Validating first E-fuse MAC
    IN :m88e1111s_config,   phydev->interface = 0x0
    cpsw
    Hit any key to stop autoboot:  0
    mmc0 is current device
    SD/MMC found on device 0
    reading boot.scr
    382 bytes read in 5 ms (74.2 KiB/s)
    Running bootscript from mmc0 ...
    ## Executing script at 82000000
    Partition Map for MMC device 0  --   Partition Type: DOS
    Part    Start Sector    Num Sectors     UUID            Type
      1     2048            614400          62eb1576-01     0c Boot
      2     616448          14907392        62eb1576-02     83
    reading dra7-evm.dtb
    85382 bytes read in 35 ms (2.3 MiB/s)
    reading uImage
    4768688 bytes read in 1612 ms (2.8 MiB/s)
    ## Booting kernel from Legacy Image at 80300000 ...
       Image Name:   Linux-3.12.25
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    4768624 Bytes = 4.5 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
    ## Flattened Device Tree blob at 825f0000
       Booting using the fdt blob at 0x825f0000
       Loading Kernel Image ... OK
    OK
       Loading Device Tree to 83fe8000, end 83fffd85 ... OK
    Starting kernel ...
             machid =0x40980b40      r2 =0x83fe8000
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 3.12.25 (mistral@mistral-Veriton-Series) (gcc vers6
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] Machine: Jacinto6 evm board, model: TI DRA7
    [    0.000000] cma: CMA: reserved 64 MiB at 99000000
    [    0.000000] cma: CMA: reserved 56 MiB at 95800000
    [    0.000000] cma: CMA: reserved 104 MiB at 9f000000
    [    0.000000] cma: CMA: reserved 32 MiB at 9d000000
    [    0.000000] cma: CMA: reserved 64 MiB at b1000000
    [    0.000000] Memory policy: ECC disabled, Data cache writealloc
    [    0.000000] OMAP4: Map 0xb5000000 to 0xfe600000 for dram barrier
    [    0.000000] PERCPU: Embedded 8 pages/cpu @81079000 s9216 r8192 d15360 u32768
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pa8
    [    0.000000] Kernel command line: elevator=noop console=ttyO0,115200n8 root=/0
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 522204K/868352K available (6471K kernel code, 526K rwdat)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     vmalloc : 0xb5800000 - 0xff000000   (1176 MB),VMALLOC_END =0
    [    0.000000]     lowmem  : 0x80000000 - 0xb5200000   ( 850 MB)
    [    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    [    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
    [    0.000000]       .text : 0x80008000 - 0x808830d4   (8685 kB)
    [    0.000000]       .init : 0x80884000 - 0x808dc400   ( 353 kB)
    [    0.000000]       .data : 0x808de000 - 0x80961ac8   ( 527 kB)
    [    0.000000]        .bss : 0x80961ad4 - 0x8099f9fc   ( 248 kB)
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] OMAP clockevent source: timer1 at 32768 Hz
    [    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 1s
    [    0.000000] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000000] Architected cp15 timer(s) running at 6.14MHz (virt).
    [    0.000000] Switching to timer-based delay loop
    [    0.000000] sched_clock: ARM arch timer >56 bits at 6144kHz, resolution 162ns
    [    0.000000] Console: colour dummy device 80x30
    [    8.465069] Calibrating delay loop (skipped), value calculated using timer f)
    [    8.465081] pid_max: default: 32768 minimum: 301
    [    8.465192] Security Framework initialized
    [    8.465234] Mount-cache hash table entries: 512
    [    8.485611] CPU: Testing write buffer coherency: ok
    [    8.485817] /cpus/cpu@0 missing clock-frequency property
    [    8.485833] /cpus/cpu@1 missing clock-frequency property
    [    8.485844] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    8.485866] Setting up static identity map for 0x80657930 - 0x80657988
    [    8.544290] CPU1: Booted secondary processor
    [    8.544318] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    8.544397] Brought up 2 CPUs
    [    8.544411] SMP: Total of 2 processors activated.
    [    8.544417] CPU: All CPU(s) started in SVC mode.
    [    8.544861] devtmpfs: initialized
    [    8.549294] VFP support v0.3: implementor 41 architecture 4 part 30 variant 0
    [    8.607668] omap_hwmod: dss_dispc: cannot be enabled for reset (3)
    [    8.610232] omap_hwmod: dss_hdmi: cannot be enabled for reset (3)
    [    8.684104] omap_hwmod: mmu1_dsp1: _wait_target_disable failed
    [    8.684117] omap_hwmod: mmu1_dsp1: cannot be enabled for reset (3)
    [    8.693082] omap_hwmod: mmu1_dsp2: _wait_target_disable failed
    [    8.693093] omap_hwmod: mmu1_dsp2: cannot be enabled for reset (3)
    [    8.699494] omap_hwmod: pcie1: _wait_target_disable failed
    [    8.705872] omap_hwmod: pcie2: _wait_target_disable failed
    [    8.707347] pinctrl core: initialized pinctrl subsystem
    [    8.707997] regulator-dummy: no parameters
    [    8.713434] NET: Registered protocol family 16
    [    8.715284] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    8.717203] cpuidle: using governor ladder
    [    8.717213] cpuidle: using governor menu
    [    8.718651] omap_l3_noc: probe of ocp.3 failed with error -2
    [    8.718917] crossbar 4a002a48.mpuirq: replacing irq 159 mapped to cb input 27
    [    8.718937] crossbar 4a002a48.mpuirq: replacing irq 158 mapped to cb input 30
    [    8.718951] crossbar 4a002a48.mpuirq: replacing irq 157 mapped to cb input 11
    [    8.718965] crossbar 4a002a48.mpuirq: replacing irq 155 mapped to cb input 16
    [    8.718978] crossbar 4a002a48.mpuirq: replacing irq 154 mapped to cb input 17
    [    8.718991] crossbar 4a002a48.mpuirq: replacing irq 146 mapped to cb input 18
    [    8.719004] crossbar 4a002a48.mpuirq: replacing irq 147 mapped to cb input 19
    [    8.719016] crossbar 4a002a48.mpuirq: replacing irq 136 mapped to cb input 21
    [    8.719029] crossbar 4a002a48.mpuirq: replacing irq 141 mapped to cb input 25
    [    8.719042] crossbar 4a002a48.mpuirq: replacing irq 124 mapped to cb input 33
    [    8.719054] crossbar 4a002a48.mpuirq: replacing irq 156 mapped to cb input 14
    [    8.719067] crossbar 4a002a48.mpuirq: replacing irq 152 mapped to cb input 31
    [    8.719079] crossbar 4a002a48.mpuirq: replacing irq 153 mapped to cb input 32
    [    8.719092] crossbar 4a002a48.mpuirq: replacing irq 150 mapped to cb input 32
    [    8.719105] crossbar 4a002a48.mpuirq: replacing irq 151 mapped to cb input 33
    [    8.719117] crossbar 4a002a48.mpuirq: replacing irq 148 mapped to cb input 33
    [    8.719129] crossbar 4a002a48.mpuirq: replacing irq 149 mapped to cb input 34
    [    8.719142] crossbar 4a002a48.mpuirq: replacing irq 50 mapped to cb input 334
    [    8.719155] crossbar 4a002a48.mpuirq: replacing irq 51 mapped to cb input 335
    [    8.719168] crossbar 4a002a48.mpuirq: replacing irq 52 mapped to cb input 336
    [    8.719181] crossbar 4a002a48.mpuirq: replacing irq 53 mapped to cb input 337
    [    8.719194] crossbar 4a002a48.mpuirq: replacing irq 129 mapped to cb input 12
    [    8.719206] crossbar 4a002a48.mpuirq: replacing irq 134 mapped to cb input 03
    [    8.719224] crossbar 4a002a48.mpuirq: replacing irq 142 mapped to cb input 36
    [    8.719237] crossbar 4a002a48.mpuirq: replacing irq 143 mapped to cb input 15
    [    8.719250] crossbar 4a002a48.mpuirq: replacing irq 144 mapped to cb input 16
    [    8.719262] crossbar 4a002a48.mpuirq: replacing irq 145 mapped to cb input 17
    [    8.719521] crossbar 4a002b78.dmareq: replacing irq 124 mapped to cb input 13
    [    8.719538] crossbar 4a002b78.dmareq: replacing irq 125 mapped to cb input 12
    [    8.719552] crossbar 4a002b78.dmareq: replacing irq 121 mapped to cb input 19
    [    8.719565] crossbar 4a002b78.dmareq: replacing irq 120 mapped to cb input 18
    [    8.719578] crossbar 4a002b78.dmareq: replacing irq 122 mapped to cb input 11
    [    8.719590] crossbar 4a002b78.dmareq: replacing irq 123 mapped to cb input 10
    [    8.721472] syscon 4a002e00.tisyscon: regmap [mem 0x4a002e00-0x4a002e03] regd
    [    8.722759] OMAP GPIO hardware version 0.1
    [    8.737568] platform 4e000000.dmm: Cannot lookup hwmod 'dmm'
    [    8.737908] platform 56000000.gpu: FIXME: clock-name 'fck' DOES NOT exist in!
    [    8.738298] syscon 4a002534.tisyscon_dispc: regmap [mem 0x4a002534-0x4a00253d
    [    8.741836] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/pie
    [    8.741854] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral
    [    8.744634] No ATAGs?
    [    8.744659] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint.
    [    8.744668] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    8.746184] OMAP DMA hardware revision 0.0
    [    8.770532] bio: create slab <bio-0> at 0
    [    8.772518] edma-dma-engine edma-dma-engine.0: Can't allocate PaRAM dummy slt
    [    8.772535] edma-dma-engine: probe of edma-dma-engine.0 failed with error -5
    [    8.791568] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
    [    8.792265] evm_3v3_sd: 3300 mV
    [    8.792538] evm_3v3_sw: 3300 mV
    [    8.792807] aic-dvdd-1v8: 1800 mV
    [    8.793133] vmmcwl_fixed: 1800 mV
    [    8.795767] pbias_regulator: 2600 <--> 3000 mV
    [    8.798147] vgaarb: loaded
    [    8.799050] SCSI subsystem initialized
    [    8.800019] usbcore: registered new interface driver usbfs
    [    8.800154] usbcore: registered new interface driver hub
    [    8.800324] usbcore: registered new device driver usb
    [    8.801091] omap_i2c 48070000.i2c: could not find pctldev for node /ocp/pinme
    [    8.801108] platform 48070000.i2c: Driver omap_i2c requests probe deferral
    [    8.801135] omap_i2c 48072000.i2c: could not find pctldev for node /ocp/pinme
    [    8.801148] platform 48072000.i2c: Driver omap_i2c requests probe deferral
    [    8.801344] media: Linux media interface: v0.10
    [    8.801466] Linux video capture interface: v2.00
    [    8.801663] pps_core: LinuxPPS API ver. 1 registered
    [    8.801671] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
    [    8.801773] PTP clock support registered
    [    8.802639] omap-iommu omap-iommu.0: mmu0_dsp1 registered
    [    8.802693] omap-iommu omap-iommu.1: mmu1_dsp1 registered
    [    8.802743] omap-iommu omap-iommu.2: mmu0_dsp2 registered
    [    8.802792] omap-iommu omap-iommu.3: mmu1_dsp2 registered
    [    8.802840] omap-iommu omap-iommu.4: mmu_ipu1 registered
    [    8.802906] omap-iommu omap-iommu.5: mmu_ipu2 registered
    [    8.803392] Advanced Linux Sound Architecture Driver Initialized.
    [    8.804078] Bluetooth: Core ver 2.16
    [    8.804205] NET: Registered protocol family 31
    [    8.804213] Bluetooth: HCI device and connection manager initialized
    [    8.804228] Bluetooth: HCI socket layer initialized
    [    8.804240] Bluetooth: L2CAP socket layer initialized
    [    8.804270] Bluetooth: SCO socket layer initialized
    [    8.804714] Switched to clocksource arch_sys_counter
    [    8.820995] NET: Registered protocol family 2
    [    8.821507] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    8.821637] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    8.821768] TCP: Hash tables configured (established 8192 bind 8192)
    [    8.821820] TCP: reno registered
    [    8.821831] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    8.821861] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    8.822061] NET: Registered protocol family 1
    [    8.822306] RPC: Registered named UNIX socket transport module.
    [    8.822315] RPC: Registered udp transport module.
    [    8.822322] RPC: Registered tcp transport module.
    [    8.822329] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    8.822994] NetWinder Floating Point Emulator V0.97 (double precision)
    [    8.824003] platform omap-rproc.0: platform_device for rproc dsp1 created
    [    8.824195] platform omap-rproc.1: platform_device for rproc ipu2 created
    [    8.824384] platform omap-rproc.2: platform_device for rproc dsp2 created
    [    8.824564] platform omap-rproc.3: platform_device for rproc ipu1 created
    [    8.910467] VFS: Disk quotas dquot_6.5.2
    [    8.910583] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    8.911222] NFS: Registering the id_resolver key type
    [    8.911266] Key type id_resolver registered
    [    8.911275] Key type id_legacy registered
    [    8.911306] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
    [    8.911478] msgmni has been set to 1659
    [    8.912958] NET: Registered protocol family 38
    [    8.912985] io scheduler noop registered (default)
    [    8.912994] io scheduler deadline registered
    [    8.913029] io scheduler cfq registered
    [    8.918381] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
    [    8.919641]
    [    8.919641] THE pin  control status  =0
    [    9.154118] dra7xx-pcie 51002000.pcie: link is not up
    [    9.154343] PCI host bridge to bus 0000:00
    [    9.154358] pci_bus 0000:00: root bus resource [io  0x1000-0x10000]
    [    9.154369] pci_bus 0000:00: root bus resource [mem 0x20012000-0x2fffffff]
    [    9.154380] pci_bus 0000:00: No busn resource found for root bus, will use []
    [    9.154871] PCI: bus0: Fast back to back transfers disabled
    [    9.155087] PCI: bus1: Fast back to back transfers enabled
    [    9.155154] PCI: Device 0000:00:00.0 not available because of resource collis
    [    9.155170] pcieport: probe of 0000:00:00.0 failed with error -22
    [    9.155212] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [    9.155227] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [    9.155241] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    9.155270] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    9.156230]
    [    9.156230] The backlight driver : T1
    [    9.156243]
    [    9.156243] The backlight driver : T2
    [    9.156251]
    [    9.156251] The backlight driver : T3
    [    9.156258]
    [    9.156258] The backlight driver : T4
    [    9.156277]
    [    9.156277] The backlight driver : T7
    [    9.156440]
    [    9.156440] The backlight driver : T8
    [    9.156449]
    [    9.156449] The backlight driver : T9
    [    9.156495]
    [    9.156495] The backlight driver : T10
    [    9.157060] OMAP DSS rev 6.1
    [    9.162512] platform 4ae07ddc.regulator-abb-mpu: Driver ti_abb requests probl
    [    9.162560] platform 4ae07e24.regulator-abb-ivahd: Driver ti_abb requests prl
    [    9.162605] platform 4ae07e20.regulator-abb-dspeve: Driver ti_abb requests pl
    [    9.162649] platform 4ae07de4.regulator-abb-gpu: Driver ti_abb requests probl
    [    9.163452] tiavs_class0 4a003b18.regulator-avs: avs_class0 regulator not av)
    [    9.163469] platform 4a003b18.regulator-avs: Driver tiavs_class0 requests prl
    [    9.163517] tiavs_class0 4a0025ec.regulator-avs: avs_class0 regulator not av)
    [    9.163533] platform 4a0025ec.regulator-avs: Driver tiavs_class0 requests prl
    [    9.163579] tiavs_class0 4a003b00.regulator-avs: avs_class0 regulator not av)
    [    9.163594] platform 4a003b00.regulator-avs: Driver tiavs_class0 requests prl
    [    9.163640] tiavs_class0 4a0025d8.regulator-avs: avs_class0 regulator not av)
    [    9.163655] platform 4a0025d8.regulator-avs: Driver tiavs_class0 requests prl
    [    9.163699] tiavs_class0 4a0025c4.regulator-avs: avs_class0 regulator not av)
    [    9.163715] platform 4a0025c4.regulator-avs: Driver tiavs_class0 requests prl
    [    9.164245] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    9.166147] 4806a000.serial: ttyO0 at MMIO 0x4806a000 (irq = 104, base_baud 0
    [   10.639250] console [ttyO0] enabled
    [   10.643945] [drm] Initialized drm 1.1.0 20060810
    [   10.656999] brd: module loaded
    [   10.664495] loop: module loaded
    [   10.689130] ahci 4a140000.sata: can't get clock
    [   10.694029] ahci 4a140000.sata: forcing PORTS_IMPL to 0x1
    [   10.699761] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 ie
    [   10.708757] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pi
    [   10.719016] scsi0 : ahci_platform
    [   10.722872] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x6
    [   10.732331] mtdoops: mtd device (mtddev=name/number) must be supplied
    [   10.740358] omap-dma-engine 4a056000.dma-controller: allocating channel for 6
    [   10.748000] omap-dma-engine 4a056000.dma-controller: allocating channel for 5
    [   10.756458] omap-dma-engine 4a056000.dma-controller: allocating channel for 4
    [   10.764071] omap-dma-engine 4a056000.dma-controller: allocating channel for 3
    [   10.772528] omap-dma-engine 4a056000.dma-controller: allocating channel for 6
    [   10.780154] omap-dma-engine 4a056000.dma-controller: allocating channel for 5
    [   10.790974] usbcore: registered new interface driver asix
    [   10.796795] usbcore: registered new interface driver ax88179_178a
    [   10.803321] usbcore: registered new interface driver cdc_ether
    [   10.809591] usbcore: registered new interface driver r815x
    [   10.815504] usbcore: registered new interface driver smsc95xx
    [   10.821657] usbcore: registered new interface driver net1080
    [   10.827753] usbcore: registered new interface driver cdc_subset
    [   10.834096] usbcore: registered new interface driver zaurus
    [   10.840118] usbcore: registered new interface driver cdc_ncm
    [   10.846443] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [   10.853310] ehci-pci: EHCI PCI platform driver
    [   10.858122] ehci-omap: OMAP-EHCI Host Controller driver
    [   10.864372] usbcore: registered new interface driver cdc_wdm
    [   10.870485] usbcore: registered new interface driver usb-storage
    [   10.877785] mousedev: PS/2 mouse device common for all mice
    [   10.886122] omap_rtc 48838000.rtcss: rtc core: registered 48838000.rtcss as 0
    [   10.894633] i2c /dev entries driver
    [   10.899419] vpe 489d0000.vpe: loading firmware vpdma-1b8.fw
    [   10.906181] Driver for 1-wire Dallas network protocol.
    [   10.912391] platform 4a0021e0.bandgap: Driver ti-soc-thermal requests probe l
    [   10.921842] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [   10.929513] vpe 489d0000.vpe: Device registered as /dev/video0
    [   10.937677] (stc): gdata/new_proto/recv or reg_complete_cb not ready
    [   10.944171] Bluetooth: st_register failed -22
    [   10.949885]
    [   10.949885] T1
    [   10.953278]
    [   10.953278] T2
    [   10.956703]
    [   10.956703] T3
    [   10.960098]
    [   10.960098] T4
    [   10.963531]
    [   10.963531] T5
    [   10.967040] omap-dma-engine 4a056000.dma-controller: allocating channel for 2
    [   10.974685] omap-dma-engine 4a056000.dma-controller: allocating channel for 1
    [   10.982380] omap_hsmmc 4809c000.mmc: unable to get vmmc_aux regulator -517
    [   10.989697] omap-dma-engine 4a056000.dma-controller: freeing channel for 61
    [   10.997054] omap-dma-engine 4a056000.dma-controller: freeing channel for 62
    [   11.010786] omap_hwmod: gpio6: _wait_target_disable failed
    [   11.016619] platform 4809c000.mmc: Driver omap_hsmmc requests probe deferral
    [   11.024090]
    [   11.024090] T1
    [   11.027510]
    [   11.027510] T2
    [   11.030907]
    [   11.030907] T3
    [   11.034332]
    [   11.034332] T4
    [   11.037730]
    [   11.037730] T5
    [   11.041185] omap-dma-engine 4a056000.dma-controller: allocating channel for 8
    [   11.048811] omap-dma-engine 4a056000.dma-controller: allocating channel for 7
    [   11.074089] ata1: SATA link down (SStatus 0 SControl 300)
    [   11.167601] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [   11.173719] omap-dma-engine 4a056000.dma-controller: allocating channel for 0
    [   11.181419] mmc0: card claims to support voltages below the defined range. T.
    [   11.190781] omap-dma-engine 4a056000.dma-controller: allocating channel for 1
    [   11.199102] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [   11.205198] omap-dma-engine 4a056000.dma-controller: allocating channel for 6
    [   11.212916] omap-dma-engine 4a056000.dma-controller: allocating channel for 7
    [   11.221480] usbcore: registered new interface driver usbhid
    [   11.227376] usbhid: USB HID core driver
    [   11.234073]  remoteproc0: dsp1 is available
    [   11.238490]  remoteproc0: Note: remoteproc is still under development and co.
    [   11.247955]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backwa.
    [   11.259205]  remoteproc1: ipu2 is available
    [   11.263643]  remoteproc1: Note: remoteproc is still under development and co.
    [   11.273092]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backwa.
    [   11.284388]  remoteproc2: dsp2 is available
    [   11.288814]  remoteproc2: Note: remoteproc is still under development and co.
    [   11.298289]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backwa.
    [   11.309495]  remoteproc3: ipu1 is available
    [   11.313957]  remoteproc3: Note: remoteproc is still under development and co.
    [   11.323424]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backwa.
    [   11.335458] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
    [   11.342017] mmc0: new high speed SDIO card at address 0001
    [   11.352293] omap-hdmi-audio-dai omap-hdmi-audio-dai: Cannot obtain IORESOURCI
    [   11.361155] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   11.370165] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   11.377970] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   11.386711] oprofile: no performance counters
    [   11.391549] oprofile: using timer interrupt.
    [   11.396214] TCP: cubic registered
    [   11.399697] Initializing XFRM netlink socket
    [   11.404222] NET: Registered protocol family 17
    [   11.408921] NET: Registered protocol family 15
    [   11.413705] Bluetooth: RFCOMM TTY layer initialized
    [   11.418858] Bluetooth: RFCOMM socket layer initialized
    [   11.424323] Bluetooth: RFCOMM ver 1.11
    [   11.428264] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   11.433874] Bluetooth: BNEP socket layer initialized
    [   11.439096] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [   11.445371] Bluetooth: HIDP socket layer initialized
    [   11.450635] 8021q: 802.1Q VLAN Support v1.8
    [   11.455088] Key type dns_resolver registered
    [   11.459580] NET: Registered protocol family 41
    [   11.464738] cpu cpu0: cpu0 regulator not ready, retry
    [   11.470062] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe defel
    [   11.477879] Power Management for TI OMAP4+ devices.
    [   11.483244] ThumbEE CPU extension supported.
    [   11.487751] Registering SWP/SWPB emulation handler
    [   11.493797] pbias_regulator: disabling
    [   11.497754] vmmcwl_fixed: disabling
    [   11.501434] aic-dvdd-1v8: disabling
    [   11.505126] evm_3v3_sw: disabling
    [   11.508620] evm_3v3_sd: disabling
    [   11.512124] regulator-dummy: disabling
    [   11.518411] dmm 4e000000.dmm: initialized all PAT entries
    [   11.524427] platform omapdrm.0: Driver omapdrm requests probe deferral
    [   11.531680] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [   11.537177] gpmc_probe_generic_child : cs = 0, child->full_name = /ocp/gpmc@
    [   11.546204] gpmc_probe_generic_child : cs = 0, base = 0x8000000
    [   11.552568] gpmc_probe_generic_child : cs = 0, bank-width = 0x2
    [   11.558940] *********** Rahul : gpmc_cs_set_timings *************
    [   11.565381] GPMC CS0: cs_on     :   2 ticks,   3 ns (was   1 ticks)   2 ns
    [   11.572647] GPMC CS0: cs_rd_off :  28 ticks,  52 ns (was  28 ticks)  51 ns
    [   11.579901] GPMC CS0: cs_wr_off :  29 ticks,  54 ns (was  30 ticks)  54 ns
    [   11.587172] GPMC CS0: adv_on    :   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.594445] GPMC CS0: adv_rd_off:   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.601715] GPMC CS0: adv_wr_off:   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.608972] GPMC CS0: oe_on     :   4 ticks,   7 ns (was   3 ticks)   6 ns
    [   11.616243] GPMC CS0: oe_off    :  28 ticks,  52 ns (was  28 ticks)  51 ns
    [   11.623511] GPMC CS0: we_on     :   7 ticks,  13 ns (was   7 ticks)  13 ns
    [   11.630767] GPMC CS0: we_off    :  15 ticks,  28 ns (was  15 ticks)  27 ns
    [   11.638029] GPMC CS0: rd_cycle  :  30 ticks,  56 ns (was  31 ticks)  56 ns
    [   11.645294] GPMC CS0: wr_cycle  :  30 ticks,  56 ns (was  31 ticks)  56 ns
    [   11.652560] GPMC CS0: access    :  27 ticks,  50 ns (was  27 ticks)  49 ns
    [   11.659811] GPMC CS0: page_burst_access:   5 ticks,   9 ns (was   4 ticks)  s
    [   11.667716] GPMC CS0: bus_turnaround:   0 ticks,   0 ns (was   0 ticks)   0 s
    [   11.675348] GPMC CS0: cycle2cycle_delay:   0 ticks,   0 ns (was   0 ticks)  s
    [   11.683256] GPMC CS0: wait_monitoring:   0 ticks,   0 ns (was   0 ticks)   0s
    [   11.690970] GPMC CS0: clk_activation:   0 ticks,   0 ns (was   0 ticks)   0 s
    [   11.698604] GPMC CS0: wr_data_mux_bus:   7 ticks,  13 ns (was   7 ticks)  13s
    [   11.706327] GPMC CS0: wr_access :  30 ticks,  56 ns (was  15 ticks)  56 ns
    [   11.713591]
    ==============CS = 0  ==========
    The CONFIG_1 =0x41041010
    The CONFIG_2 =0x1e1c01
    The CONFIG_3 =0x0
    The CONFIG_4 =0xf071c03
    The CONFIG_5 =0x41b1f1f
    The CONFIG_6 =0x8f070000
    The CONFIG_7 =0x848
    [   11.734216]
    ==============CS=0==========
    name of flash ------------------ chip cfi_probe
    [   11.744234] intel,pf48f6000m0y1be: Found 1 x16 devices at 0x0 in 16-bit bank2
    [   11.755626] Intel/Sharp Extended Query Table at 0x010A
    [   11.761070] Intel/Sharp Extended Query Table at 0x010A
    [   11.766505] Intel/Sharp Extended Query Table at 0x010A
    [   11.771956] Intel/Sharp Extended Query Table at 0x010A
    [   11.777398] Intel/Sharp Extended Query Table at 0x010A
    [   11.782856] Using buffer write method
    [   11.786710] Using auto-unlock on power-up/resume
    [   11.791591] cfi_cmdset_0001: Erase suspend on write enabled
    [   11.797484]
    [   11.797484] flash chip ret =-1338809344 =====================================
    [   11.811650] 5 ofpart partitions found on MTD device intel,pf48f6000m0y1be
    [   11.818812] Creating 5 MTD partitions on "intel,pf48f6000m0y1be":
    [   11.825281] 0x000000000000-0x000000060000 : "NOR.u-boot"
    [   11.831997] 0x000000060000-0x000000080000 : "NOR.u-boot-env"
    [   11.838902] 0x000000080000-0x0000000a0000 : "NOR.u-boot-kernel.dtb"
    [   11.846494] 0x0000000a0000-0x000000680000 : "NOR.kernel"
    [   11.853186] 0x000000680000-0x000008000000 : "NOR.file-system"
    [   11.863087]
    [   11.863087] THE GPMC ret = 0
    [   11.867690] gpmc_probe_generic_child : cs = 1, child->full_name = /ocp/gpmc@
    [   11.876725] gpmc_probe_generic_child : cs = 1, base = 0x10000000
    [   11.883191] gpmc_probe_generic_child : cs = 1, bank-width = 0x2
    [   11.889570] *********** Rahul : gpmc_cs_set_timings *************
    [   11.896023] GPMC CS1: cs_on     :   2 ticks,   3 ns (was   1 ticks)   2 ns
    [   11.903292] GPMC CS1: cs_rd_off :  28 ticks,  52 ns (was  28 ticks)  51 ns
    [   11.910566] GPMC CS1: cs_wr_off :  29 ticks,  54 ns (was  30 ticks)  54 ns
    [   11.917817] GPMC CS1: adv_on    :   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.925083] GPMC CS1: adv_rd_off:   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.932353] GPMC CS1: adv_wr_off:   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.939608] GPMC CS1: oe_on     :   4 ticks,   7 ns (was   3 ticks)   6 ns
    [   11.946886] GPMC CS1: oe_off    :  28 ticks,  52 ns (was  28 ticks)  51 ns
    [   11.954152] GPMC CS1: we_on     :   7 ticks,  13 ns (was   7 ticks)  13 ns
    [   11.961420] GPMC CS1: we_off    :  15 ticks,  28 ns (was  15 ticks)  27 ns
    [   11.968677] GPMC CS1: rd_cycle  :  30 ticks,  56 ns (was  31 ticks)  56 ns
    [   11.975943] GPMC CS1: wr_cycle  :  30 ticks,  56 ns (was  31 ticks)  56 ns
    [   11.983204] GPMC CS1: access    :  27 ticks,  50 ns (was  27 ticks)  49 ns
    [   11.990472] GPMC CS1: page_burst_access:   5 ticks,   9 ns (was   4 ticks)  s
    [   11.998360] GPMC CS1: bus_turnaround:   0 ticks,   0 ns (was   0 ticks)   0 s
    [   12.006000] GPMC CS1: cycle2cycle_delay:   0 ticks,   0 ns (was   0 ticks)  s
    [   12.013911] GPMC CS1: wait_monitoring:   0 ticks,   0 ns (was   0 ticks)   0s
    [   12.021641] GPMC CS1: clk_activation:   0 ticks,   0 ns (was   0 ticks)   0 s
    [   12.029259] GPMC CS1: wr_data_mux_bus:   7 ticks,  13 ns (was   7 ticks)  13s
    [   12.036990] GPMC CS1: wr_access :  30 ticks,  56 ns (was  15 ticks)  56 ns
    [   12.044248]
    ==============CS = 1  ==========
    The CONFIG_3 =0x0
    The CONFIG_7 =0x850
    [   12.064866]
    ==============CS=1==========
    [   12.074875] intel,pf48f6000m0y1be: Found 1 x16 devices at 0x0 in 16-bit bank2
    [   12.086278] Intel/Sharp Extended Query Table at 0x010A
    [   12.091723] Intel/Sharp Extended Query Table at 0x010A
    [   12.097154] Intel/Sharp Extended Query Table at 0x010A
    [   12.102600] Intel/Sharp Extended Query Table at 0x010A
    [   12.108045] Intel/Sharp Extended Query Table at 0x010A
    [   12.113501] Using buffer write method
    [   12.117361] Using auto-unlock on power-up/resume
    [   12.122244] cfi_cmdset_0001: Erase suspend on write enabled
    [   12.128143]
    [   12.128143] flash chip ret =-1335622656 =====================================
    [   12.142287] 1 ofpart partitions found on MTD device intel,pf48f6000m0y1be
    [   12.149498] Creating 1 MTD partitions on "intel,pf48f6000m0y1be":
    [   12.155918] 0x000000000000-0x000008000000 : "NOR.ROOTFS"
    [   12.165540]
    [   12.165540] THE GPMC ret = 0
    [   12.170176] gpmc_dcmist_fpga_init(): GPMC FCLK: TRACE 1
    [   12.175681]  GPMC BEFORE GPMC_GET_CS b0191da8
    [   12.180297]  GPMC base address 18000000
    [   12.184341]  GPMC Chipseleect 2
    [   12.187651] ++++++++++++++++++++++++++++++++++
    [   12.192348] GPMC Chip select 2
    [   12.195563] ===============================
    [   12.199993] **********GPMC CS  = 2*************
    [   12.204773] GPMC_CS_CONFIG1:= 0x7ac81211
    [   12.208923] GPMC_CS_CONFIG2:= 0xb0f03
    [   12.212784] GPMC_CS_CONFIG3:= 0x60604
    [   12.216647] GPMC_CS_CONFIG4:= 0xa060f06
    [   12.220716] GPMC_CS_CONFIG5:= 0x3090f14
    [   12.224763] GPMC_CS_CONFIG6:= 0x90604c4
    [   12.228825] GPMC_CS_CONFIG7:= 0xe58
    [   12.232500] ===============================
    [   12.237285]
    [   12.237285] res-start =0x18000000 and size = 0x2000000
    [   12.244610] MISC DEVICE REGISTERED
    [   12.248633] input: TX FPGA as /devices/virtual/input/input0
    [   12.254940]
    [   12.254940] THE END OF PROBE
    [   12.260728] palmas 0-0058: Irq flag is 0x00000000
    [   12.267516]
     Regmao irq T1
     Regmao irq T4
     Regmao irq T5
     Regmao irq T5
     Regmao irq T5
     Regmao irq T5
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6[   12.291917] palmas 0-0058: Muxing GPIO e, PWM 0, LED 0
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6
     Regmao irq T6[   12.332081] smps123: 850 <--> 1250 mV at 1070 mV
    [   12.338649] smps45: 850 <--> 1150 mV at 990 mV
    [   12.344991] smps6: 850 <--> 1650 mV at 1010 mV
    [   12.351167] smps7: 850 <--> 1060 mV at 1050 mV
    [   12.357500] smps8: 850 <--> 1250 mV at 1010 mV
    [   12.363833] smps9: 1800 mV
    [   12.367970] ldo1: 1800 <--> 3300 mV at 3000 mV
    [   12.374369] ldo2: 3300 mV
    [   12.378980] ldo3: 2000 mV
    [   12.382629] LDO4: at 1800 mV
    [   12.386282] LDO5: no parameters
    [   12.390157] LDO6: no parameters
    [   12.394019] LDO7: no parameters
    [   12.397882] LDO8: no parameters
    [   12.402571] ldo9: 1050 mV
    [   12.407096] ldoln: 1800 mV
    [   12.411716] ldousb: 3300 mV
    [   12.415434] REGEN1: no parameters
    [   12.419151] REGEN2: no parameters
    [   12.422838] REGEN3: no parameters
    [   12.426539] SYSEN1: no parameters
    [   12.430252] SYSEN2: no parameters
    [   12.434205]  value of debouce-pmic from dts :dcmist = -1335605224
    [   12.442306] input: palmas_pwron as /devices/ocp.3/48070000.i2c/i2c-0/0-0058/1
    [   12.454232]
    [   12.454232] LCD DEVICE =KRB======== :[   12.459747] tlc59108 0-0040: Success8
    [   12.465930] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [   12.472463] omap_i2c 48072000.i2c: bus 1 rev0.12 at 10 kHz
    [   12.478442] platform 4ae07ddc.regulator-abb-mpu: Driver ti_abb requests probl
    [   12.487031] platform 4ae07e24.regulator-abb-ivahd: Driver ti_abb requests prl
    [   12.495797] platform 4ae07e20.regulator-abb-dspeve: Driver ti_abb requests pl
    [   12.504667] platform 4ae07de4.regulator-abb-gpu: Driver ti_abb requests probl
    [   12.513819] 4a003b18.regulator-avs: 1090 <--> 1280 mV at 1090 mV
    [   12.520983] 4a0025ec.regulator-avs: 1030 mV
    [   12.526055] 4a003b00.regulator-avs: 1090 <--> 1280 mV at 1090 mV
    [   12.533083] 4a0025d8.regulator-avs: 1060 <--> 1250 mV at 1060 mV
    [   12.540107] 4a0025c4.regulator-avs: 1060 <--> 1250 mV at 1060 mV
    [   12.546865] platform 4a0021e0.bandgap: Driver ti-soc-thermal requests probe l
    [   12.555365]
    [   12.555365] T1
    [   12.558784]
    [   12.558784] T2
    [   12.562185]
    [   12.562185] T3
    [   12.565587]
    [   12.565587] T4
    [   12.569048]
    [   12.569048] T5
    [   12.572544] omap-dma-engine 4a056000.dma-controller: allocating channel for 2
    [   12.580193] omap-dma-engine 4a056000.dma-controller: allocating channel for 1
    [   12.588175]
    [   12.588175] The pbaias regulator vmode =0x200000
    [   12.626962] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.635979] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.643814] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.652093] cpu cpu0: cpu0 regulator not ready, retry
    [   12.657448] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe defel
    [   12.667585] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
    [   12.674563] [drm] No driver support for vblank timestamp query.
    [   12.688530] [drm] Enabling DMM ywrap scrolling
    [   12.700089] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   12.722384] Console: switching to colour frame buffer device 160x50
    [   12.742891] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [   12.749164] omapdrm omapdrm.0: registered panic notifier
    [   12.754785] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [   12.761522] abb_mpu: 1090 <--> 1280 mV
    [   12.766394] abb_ivahd: 1055 <--> 1250 mV
    [   12.770675] regulator regulator.34: No match for 1060000
    [   12.776686] abb_dspeve: 1055 <--> 1250 mV
    [   12.781070] regulator regulator.35: No match for 1060000
    [   12.787070] abb_gpu: 1090 <--> 1280 mV
    [   12.791880] platform 4a0021e0.bandgap: Driver ti-soc-thermal requests probe l
    [   12.800298] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.809353] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.817214] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.828370] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.837409] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.845217] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.915432] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [   12.921849] davinci_mdio 48485000.mdio: detected phy mask fffffffb
    [   12.930654] libphy: 48485000.mdio: probed
    [   12.934876] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, dri1
    [   12.944162] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.945429] Missing dual_emac_res_vlan in DT.
    [   12.945432] Using 1 as Reserved VLAN for 0 slave
    [   12.945515] Missing dual_emac_res_vlan in DT.
    [   12.945517] Using 2 as Reserved VLAN for 1 slave
    [   12.945520] Detected MACID = fc:0f:4b:c9:76:ba
    [   12.976767] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.984607] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.993135] cpsw: Random MACID = 32:30:52:60:d3:2e
    [   12.998607] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   12.999018] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.999048] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.999061] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   13.031139] omap_rtc 48838000.rtcss: setting system clock to 2000-01-01 00:0)
    [   13.049796] platform 48970000.vip: omap_device_late_idle: enabled but no drig
    [   13.058345] platform 48990000.vip: omap_device_late_idle: enabled but no drig
    [   13.066883] platform 489b0000.vip: omap_device_late_idle: enabled but no drig
    [   13.075701] ALSA device list:
    [   13.078831]   No soundcards found.
    [   13.082819] Waiting for root device /dev/mmcblk0p2...
    [   13.286114] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   13.534921] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   13.783750] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   14.032583] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   14.281441] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   14.530266] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   14.779081] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   15.027913] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   15.075297] mmc1: Skipping voltage switch
    [   15.288539] mmc1: new high speed SDHC card at address aaaa
    [   15.294773] mmcblk0: mmc1:aaaa SS08G 7.40 GiB
    [   15.305848]  mmcblk0: p1 p2
    [   15.309603] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   15.318749] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   15.326580] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   15.388304] EXT3-fs (mmcblk0p2): error: couldn't mount because of unsupporte)
    [   15.402259] EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupporte)
    [   15.446754] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. )
    [   15.455331] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [   15.490431] devtmpfs: mounted
    [   15.493793] Freeing unused kernel memory: 352K (80884000 - 808dc000)
    INIT: version 2.88 booting
    ******* Tx card driven low(0)**********
    ******* Tx card driven high(1)**********
    [   17.418793] cryptodev: driver 1.6 loaded.
    Starting udev
    [   17.668529] udevd[1193]: starting version 182
    [   17.938343] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   17.992275] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   18.050617] Loading modules backported from Linux version ol_r8.a9.14-6-g0e4b
    [   18.075547] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   18.077515] Backport generated by backports.git ol_r8.a9.15-0-g0d46f43
    [   18.276839] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   18.316923] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [   18.322025] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   18.322044] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or y
    bootlogd.
    [   18.779017]  remoteproc3: failed to load dra7-ipu1-fw.xem4
    [   18.855472] wl1271_sdio mmc0:0001:2: No platform data set
    [   18.861892] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   18.873596] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   18.885347] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   19.187516] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   19.197190] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   19.205009] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   19.399893] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   19.414095] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   19.422449] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   19.451374] cfg80211: Calling CRDA to update world regulatory domain
    [   20.326922] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   20.339595] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   20.347447] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    ALSA: Restoring mixer settings...
    [   20.836879]  remoteproc1: powering up ipu2
    [   20.841989]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3365812
    [   20.849382] omap-iommu omap-iommu.5: mmu_ipu2: version 2.1
    [   20.924069]  remoteproc1: remote processor ipu2 is now up
    [   20.930441] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   20.936263]  remoteproc1: registered virtio0 (type 7)
    [   20.936501] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   20.936541] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   20.936557] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   20.978579] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [   20.991773] wlcore: loaded
    [   20.994646] wlcore: driver version: ol_r8.a9.14
    [   21.000559] wlcore: compilation time: Wed Sep 24 00:03:03 2014
    U-Boot 2013.04 (Apr 18 2017 - 16:18:53)
    CPU  : DRA752 ES1.1
    Board: DRA7xx
    I2C:
    DRA752 ES1.1
    0x482a f040 =0x0
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    CPU  : DRA752 ES1.1
    Board: DRA7xx
    I2C:   ready
    DRAM:  1.5 GiB
    U-Boot SPL 2013.04 (Apr 18 2017 - 16:18:53)
    DRA752 ES1.1
    0x482a f040 =0x0
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    CPU  : DRA752 ES1.1
    Board: DRA7xx
    I2C:
    DRA752 ES1.1
    0x482a f040 =0x0
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    CPU  : DRA752 ES1.1
    Board: DRA7xx
    I2C:   ready
    DRAM:  1.5 GiB
    256 MiB
    In:    serial
    Out:   serial
    Err:   serial
    cpsw
    reading boot.scr
    382 bytes read in 3 ms (124 KiB/s)
      1     2048            409600          3624ae20-01     0c Boot
      2     411648          15112192        3624ae20-02     83
    85382 bytes read in 36 ms (2.3 MiB/s)
    reading uImage
    4687160 bytes read in 1617 ms (2.8 MiB/s)
       Data Size:    4687096 Bytes = 4.5 MiB
    OK
    Starting kernel ...
             machid =0x94f706c1      r2 =0x83fe8000
    [    0.000000] Linux version 3.12.25 (mistral@CPU000456-U) (gcc version 4.7.3 27
    [    0.000000] PERCPU: Embedded 8 pages/cpu @81050000 s9216 r8192 d15360 u32768
    [    0.000000] Memory: 522368K/868352K available (6359K kernel code, 524K rwdat)
    [    0.000000]       .text : 0x80008000 - 0x8085c0d4   (8529 kB)
    [    0.000000]       .init : 0x8085d000 - 0x808b5400   ( 353 kB)
    [    0.000000]       .data : 0x808b6000 - 0x809393c8   ( 525 kB)
    [    0.000000]        .bss : 0x809393d4 - 0x80976b3c   ( 246 kB)
    [    8.379864] Calibrating delay loop (skipped), value calculated using timer f)
    [    8.379877] pid_max: default: 32768 minimum: 301
    [    8.379991] Security Framework initialized
    [    8.380034] Mount-cache hash table entries: 512
    [    8.400365] CPU: Testing write buffer coherency: ok
    [    8.400570] /cpus/cpu@0 missing clock-frequency property
    [    8.400585] /cpus/cpu@1 missing clock-frequency property
    [    8.400597] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    8.400620] Setting up static identity map for 0x8063b370 - 0x8063b3c8
    [    8.459087] CPU1: Booted secondary processor
    [    8.459115] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    8.459195] Brought up 2 CPUs
    [    8.459210] SMP: Total of 2 processors activated.
    [    8.459217] CPU: All CPU(s) started in SVC mode.
    [    8.459659] devtmpfs: initialized
    [    8.464026] VFP support v0.3: implementor 41 architecture 4 part 30 variant 0
    [    8.522644] omap_hwmod: dss_dispc: cannot be enabled for reset (3)
    [    8.525208] omap_hwmod: dss_hdmi: cannot be enabled for reset (3)
    [    8.598918] omap_hwmod: mmu1_dsp1: _wait_target_disable failed
    [    8.598931] omap_hwmod: mmu1_dsp1: cannot be enabled for reset (3)
    [    8.607839] omap_hwmod: mmu1_dsp2: _wait_target_disable failed
    [    8.607850] omap_hwmod: mmu1_dsp2: cannot be enabled for reset (3)
    [    8.614250] omap_hwmod: pcie1: _wait_target_disable failed
    [    8.620628] omap_hwmod: pcie2: _wait_target_disable failed
    [    8.622123] pinctrl core: initialized pinctrl subsystem
    [    8.622777] regulator-dummy: no parameters
    [    8.628182] NET: Registered protocol family 16
    [    8.630048] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    8.631991] cpuidle: using governor ladder
    [    8.632001] cpuidle: using governor menu
    [    8.633448] omap_l3_noc: probe of ocp.3 failed with error -2
    [    8.633716] crossbar 4a002a48.mpuirq: replacing irq 159 mapped to cb input 27
    [    8.633736] crossbar 4a002a48.mpuirq: replacing irq 158 mapped to cb input 30
    [    8.633750] crossbar 4a002a48.mpuirq: replacing irq 157 mapped to cb input 11
    [    8.633764] crossbar 4a002a48.mpuirq: replacing irq 155 mapped to cb input 16
    [    8.633777] crossbar 4a002a48.mpuirq: replacing irq 154 mapped to cb input 17
    [    8.633791] crossbar 4a002a48.mpuirq: replacing irq 146 mapped to cb input 18
    [    8.633804] crossbar 4a002a48.mpuirq: replacing irq 147 mapped to cb input 19
    [    8.633817] crossbar 4a002a48.mpuirq: replacing irq 136 mapped to cb input 21
    [    8.633830] crossbar 4a002a48.mpuirq: replacing irq 141 mapped to cb input 25
    [    8.633843] crossbar 4a002a48.mpuirq: replacing irq 124 mapped to cb input 33
    [    8.633855] crossbar 4a002a48.mpuirq: replacing irq 156 mapped to cb input 14
    [    8.633868] crossbar 4a002a48.mpuirq: replacing irq 152 mapped to cb input 31
    [    8.633880] crossbar 4a002a48.mpuirq: replacing irq 153 mapped to cb input 32
    [    8.633893] crossbar 4a002a48.mpuirq: replacing irq 150 mapped to cb input 32
    [    8.633905] crossbar 4a002a48.mpuirq: replacing irq 151 mapped to cb input 33
    [    8.633917] crossbar 4a002a48.mpuirq: replacing irq 148 mapped to cb input 33
    [    8.633930] crossbar 4a002a48.mpuirq: replacing irq 149 mapped to cb input 34
    [    8.633943] crossbar 4a002a48.mpuirq: replacing irq 50 mapped to cb input 334
    [    8.633955] crossbar 4a002a48.mpuirq: replacing irq 51 mapped to cb input 335
    [    8.633968] crossbar 4a002a48.mpuirq: replacing irq 52 mapped to cb input 336
    [    8.633981] crossbar 4a002a48.mpuirq: replacing irq 53 mapped to cb input 337
    [    8.633994] crossbar 4a002a48.mpuirq: replacing irq 129 mapped to cb input 12
    [    8.634007] crossbar 4a002a48.mpuirq: replacing irq 134 mapped to cb input 03
    [    8.634024] crossbar 4a002a48.mpuirq: replacing irq 142 mapped to cb input 36
    [    8.634038] crossbar 4a002a48.mpuirq: replacing irq 143 mapped to cb input 15
    [    8.634050] crossbar 4a002a48.mpuirq: replacing irq 144 mapped to cb input 16
    [    8.634063] crossbar 4a002a48.mpuirq: replacing irq 145 mapped to cb input 17
    [    8.634322] crossbar 4a002b78.dmareq: replacing irq 124 mapped to cb input 13
    [    8.634338] crossbar 4a002b78.dmareq: replacing irq 125 mapped to cb input 12
    [    8.634352] crossbar 4a002b78.dmareq: replacing irq 121 mapped to cb input 19
    [    8.634366] crossbar 4a002b78.dmareq: replacing irq 120 mapped to cb input 18
    [    8.634379] crossbar 4a002b78.dmareq: replacing irq 122 mapped to cb input 11
    [    8.634391] crossbar 4a002b78.dmareq: replacing irq 123 mapped to cb input 10
    [    8.636280] syscon 4a002e00.tisyscon: regmap [mem 0x4a002e00-0x4a002e03] regd
    [    8.637576] OMAP GPIO hardware version 0.1
    [    8.652385] platform 4e000000.dmm: Cannot lookup hwmod 'dmm'
    [    8.652728] platform 56000000.gpu: FIXME: clock-name 'fck' DOES NOT exist in!
    [    8.653118] syscon 4a002534.tisyscon_dispc: regmap [mem 0x4a002534-0x4a00253d
    [    8.656660] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/pie
    [    8.656678] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral
    [    8.659450] No ATAGs?
    [    8.659474] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint.
    [    8.659483] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    8.660983] OMAP DMA hardware revision 0.0
    [    8.685379] bio: create slab <bio-0> at 0
    [    8.687380] edma-dma-engine edma-dma-engine.0: Can't allocate PaRAM dummy slt
    [    8.687397] edma-dma-engine: probe of edma-dma-engine.0 failed with error -5
    [    8.707560] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
    [    8.708267] evm_3v3_sd: 3300 mV
    [    8.708534] evm_3v3_sw: 3300 mV
    [    8.708802] aic-dvdd-1v8: 1800 mV
    [    8.709103] vmmcwl_fixed: 1800 mV
    [    8.709915] pbias_regulator: 2600 <--> 3000 mV
    [    8.712296] vgaarb: loaded
    [    8.713207] SCSI subsystem initialized
    [    8.714178] usbcore: registered new interface driver usbfs
    [    8.714314] usbcore: registered new interface driver hub
    [    8.714473] usbcore: registered new device driver usb
    [    8.715239] omap_i2c 48070000.i2c: could not find pctldev for node /ocp/pinme
    [    8.715256] platform 48070000.i2c: Driver omap_i2c requests probe deferral
    [    8.715282] omap_i2c 48072000.i2c: could not find pctldev for node /ocp/pinme
    [    8.715296] platform 48072000.i2c: Driver omap_i2c requests probe deferral
    [    8.715489] media: Linux media interface: v0.10
    [    8.715610] Linux video capture interface: v2.00
    [    8.715813] pps_core: LinuxPPS API ver. 1 registered
    [    8.715822] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
    [    8.715923] PTP clock support registered
    [    8.716801] omap-iommu omap-iommu.0: mmu0_dsp1 registered
    [    8.716855] omap-iommu omap-iommu.1: mmu1_dsp1 registered
    [    8.716905] omap-iommu omap-iommu.2: mmu0_dsp2 registered
    [    8.716956] omap-iommu omap-iommu.3: mmu1_dsp2 registered
    [    8.717005] omap-iommu omap-iommu.4: mmu_ipu1 registered
    [    8.717051] omap-iommu omap-iommu.5: mmu_ipu2 registered
    [    8.717536] Advanced Linux Sound Architecture Driver Initialized.
    [    8.719318] Bluetooth: Core ver 2.16
    [    8.719448] NET: Registered protocol family 31
    [    8.719457] Bluetooth: HCI device and connection manager initialized
    [    8.719472] Bluetooth: HCI socket layer initialized
    [    8.719484] Bluetooth: L2CAP socket layer initialized
    [    8.719513] Bluetooth: SCO socket layer initialized
    [    8.719958] Switched to clocksource arch_sys_counter
    [    8.736508] NET: Registered protocol family 2
    [    8.737007] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    8.737137] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    8.737268] TCP: Hash tables configured (established 8192 bind 8192)
    [    8.737311] TCP: reno registered
    [    8.737323] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    8.737353] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    8.737558] NET: Registered protocol family 1
    [    8.737801] RPC: Registered named UNIX socket transport module.
    [    8.737810] RPC: Registered udp transport module.
    [    8.737817] RPC: Registered tcp transport module.
    [    8.737823] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    8.738506] NetWinder Floating Point Emulator V0.97 (double precision)
    [    8.739526] platform omap-rproc.0: platform_device for rproc dsp1 created
    [    8.739717] platform omap-rproc.1: platform_device for rproc ipu2 created
    [    8.739944] platform omap-rproc.2: platform_device for rproc dsp2 created
    [    8.740139] platform omap-rproc.3: platform_device for rproc ipu1 created
    [    8.826424] VFS: Disk quotas dquot_6.5.2
    [    8.826535] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    8.827178] NFS: Registering the id_resolver key type
    [    8.827238] Key type id_resolver registered
    [    8.827247] Key type id_legacy registered
    [    8.827281] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
    [    8.827463] msgmni has been set to 1660
    [    8.828878] NET: Registered protocol family 38
    [    8.828904] io scheduler noop registered (default)
    [    8.828913] io scheduler deadline registered
    [    8.828944] io scheduler cfq registered
    [    8.834331] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
    [    8.835580]
    [    8.835580] THE pin  control status  =0
    [    9.070067] dra7xx-pcie 51002000.pcie: link is not up
    [    9.070296] PCI host bridge to bus 0000:00
    [    9.070311] pci_bus 0000:00: root bus resource [io  0x1000-0x10000]
    [    9.070322] pci_bus 0000:00: root bus resource [mem 0x20012000-0x2fffffff]
    [    9.070333] pci_bus 0000:00: No busn resource found for root bus, will use []
    [    9.070834] PCI: bus0: Fast back to back transfers disabled
    [    9.071058] PCI: bus1: Fast back to back transfers enabled
    [    9.071126] PCI: Device 0000:00:00.0 not available because of resource collis
    [    9.071143] pcieport: probe of 0000:00:00.0 failed with error -22
    [    9.071185] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [    9.071201] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [    9.071215] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    9.071243] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    9.072963] OMAP DSS rev 6.1
    [    9.078471] platform 4ae07ddc.regulator-abb-mpu: Driver ti_abb requests probl
    [    9.078519] platform 4ae07e24.regulator-abb-ivahd: Driver ti_abb requests prl
    [    9.078564] platform 4ae07e20.regulator-abb-dspeve: Driver ti_abb requests pl
    [    9.078607] platform 4ae07de4.regulator-abb-gpu: Driver ti_abb requests probl
    [    9.079392] tiavs_class0 4a003b18.regulator-avs: avs_class0 regulator not av)
    [    9.079410] platform 4a003b18.regulator-avs: Driver tiavs_class0 requests prl
    [    9.079456] tiavs_class0 4a0025ec.regulator-avs: avs_class0 regulator not av)
    [    9.079471] platform 4a0025ec.regulator-avs: Driver tiavs_class0 requests prl
    [    9.079516] tiavs_class0 4a003b00.regulator-avs: avs_class0 regulator not av)
    [    9.079531] platform 4a003b00.regulator-avs: Driver tiavs_class0 requests prl
    [    9.079576] tiavs_class0 4a0025d8.regulator-avs: avs_class0 regulator not av)
    [    9.079590] platform 4a0025d8.regulator-avs: Driver tiavs_class0 requests prl
    [    9.079634] tiavs_class0 4a0025c4.regulator-avs: avs_class0 regulator not av)
    [    9.079649] platform 4a0025c4.regulator-avs: Driver tiavs_class0 requests prl
    [    9.080186] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    9.082087] 4806a000.serial: ttyO0 at MMIO 0x4806a000 (irq = 104, base_baud 0
    [   10.511553] console [ttyO0] enabled
    [   10.516246] [drm] Initialized drm 1.1.0 20060810
    [   10.529341] brd: module loaded
    [   10.536874] loop: module loaded
    [   10.542664] ahci 4a140000.sata: can't get clock
    [   10.547574] ahci 4a140000.sata: forcing PORTS_IMPL to 0x1
    [   10.553322] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 ie
    [   10.562314] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pi
    [   10.572568] scsi0 : ahci_platform
    [   10.576443] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x6
    [   10.585874] mtdoops: mtd device (mtddev=name/number) must be supplied
    [   10.593944] omap-dma-engine 4a056000.dma-controller: allocating channel for 6
    [   10.601573] omap-dma-engine 4a056000.dma-controller: allocating channel for 5
    [   10.610034] omap-dma-engine 4a056000.dma-controller: allocating channel for 4
    [   10.617671] omap-dma-engine 4a056000.dma-controller: allocating channel for 3
    [   10.626126] omap-dma-engine 4a056000.dma-controller: allocating channel for 6
    [   10.633762] omap-dma-engine 4a056000.dma-controller: allocating channel for 5
    [   10.644607] usbcore: registered new interface driver asix
    [   10.650410] usbcore: registered new interface driver ax88179_178a
    [   10.656953] usbcore: registered new interface driver cdc_ether
    [   10.663224] usbcore: registered new interface driver r815x
    [   10.669121] usbcore: registered new interface driver smsc95xx
    [   10.675295] usbcore: registered new interface driver net1080
    [   10.681377] usbcore: registered new interface driver cdc_subset
    [   10.687714] usbcore: registered new interface driver zaurus
    [   10.693749] usbcore: registered new interface driver cdc_ncm
    [   10.700057] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [   10.706939] ehci-pci: EHCI PCI platform driver
    [   10.711751] ehci-omap: OMAP-EHCI Host Controller driver
    [   10.717999] usbcore: registered new interface driver cdc_wdm
    [   10.724103] usbcore: registered new interface driver usb-storage
    [   10.731383] mousedev: PS/2 mouse device common for all mice
    [   10.739685] omap_rtc 48838000.rtcss: rtc core: registered 48838000.rtcss as 0
    [   10.748219] i2c /dev entries driver
    [   10.753014] vpe 489d0000.vpe: loading firmware vpdma-1b8.fw
    [   10.759739] Driver for 1-wire Dallas network protocol.
    [   10.765959] platform 4a0021e0.bandgap: Driver ti-soc-thermal requests probe l
    [   10.774359] vpe 489d0000.vpe: Device registered as /dev/video0
    [   10.781783] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [   10.791458] (stc): gdata/new_proto/recv or reg_complete_cb not ready[   10.72
    [   10.792695] omap-dma-engine 4a056000.dma-controller: allocating channel for 1
    [   10.792794] omap_hsmmc 4809c000.mmc: unable to get vmmc_aux regulator -517
    [   10.792870] omap-dma-engine 4a056000.dma-controller: freeing channel for 61
    [   10.792880] omap-dma-engine 4a056000.dma-controller: freeing channel for 62
    [   10.792946] platform 4809c000.mmc: Driver omap_hsmmc requests probe deferral
    [   10.793071] omap-dma-engine 4a056000.dma-controller: allocating channel for 8
    [   10.793086] omap-dma-engine 4a056000.dma-controller: allocating channel for 7
    [   10.799602] omap_hwmod: gpio6: _wait_target_disable failed
    [   10.863527] Bluetooth: st_register failed -22
    [   10.903741] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [   10.909866] omap-dma-engine 4a056000.dma-controller: allocating channel for 0
    [   10.917562] mmc0: card claims to support voltages below the defined range. T.
    [   10.926926] omap-dma-engine 4a056000.dma-controller: allocating channel for 1
    [   10.935300] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [   10.941398] omap-dma-engine 4a056000.dma-controller: allocating channel for 6
    [   10.949132] omap-dma-engine 4a056000.dma-controller: allocating channel for 7
    [   10.957726] usbcore: registered new interface driver usbhid
    [   10.963627] usbhid: USB HID core driver
    [   10.970339]  remoteproc0: dsp1 is available
    [   10.974761]  remoteproc0: Note: remoteproc is still under development and co.
    [   10.979389] ata1: SATA link down (SStatus 0 SControl 300)
    [   10.989914]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backwa.
    [   11.001170]  remoteproc1: ipu2 is available
    [   11.005588]  remoteproc1: Note: remoteproc is still under development and co.
    [   11.015047]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backwa.
    [   11.026326]  remoteproc2: dsp2 is available
    [   11.030761]  remoteproc2: Note: remoteproc is still under development and co.
    [   11.040226]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backwa.
    [   11.051525]  remoteproc3: ipu1 is available
    [   11.055943]  remoteproc3: Note: remoteproc is still under development and co.
    [   11.066175] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
    [   11.071983]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backwa.
    [   11.083588] mmc0: new high speed SDIO card at address 0001
    [   11.094349] omap-hdmi-audio-dai omap-hdmi-audio-dai: Cannot obtain IORESOURCI
    [   11.103224] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   11.112264] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   11.120074] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   11.128818] oprofile: no performance counters
    [   11.133674] oprofile: using timer interrupt.
    [   11.138333] TCP: cubic registered
    [   11.141879] Initializing XFRM netlink socket
    [   11.146383] NET: Registered protocol family 17
    [   11.151286] NET: Registered protocol family 15
    [   11.156034] Bluetooth: RFCOMM TTY layer initialized
    [   11.161217] Bluetooth: RFCOMM socket layer initialized
    [   11.166621] Bluetooth: RFCOMM ver 1.11
    [   11.170605] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   11.176198] Bluetooth: BNEP socket layer initialized
    [   11.181479] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [   11.187709] Bluetooth: HIDP socket layer initialized
    [   11.192985] 8021q: 802.1Q VLAN Support v1.8
    [   11.197427] Key type dns_resolver registered
    [   11.201937] NET: Registered protocol family 41
    [   11.207096] cpu cpu0: cpu0 regulator not ready, retry
    [   11.212436] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe defel
    [   11.220246] Power Management for TI OMAP4+ devices.
    [   11.225589] ThumbEE CPU extension supported.
    [   11.230120] Registering SWP/SWPB emulation handler
    [   11.236113] pbias_regulator: disabling
    [   11.240091] vmmcwl_fixed: disabling
    [   11.243776] aic-dvdd-1v8: disabling
    [   11.247456] evm_3v3_sw: disabling
    [   11.250965] evm_3v3_sd: disabling
    [   11.254459] regulator-dummy: disabling
    [   11.260759] dmm 4e000000.dmm: initialized all PAT entries
    [   11.266758] platform omapdrm.0: Driver omapdrm requests probe deferral
    [   11.274044] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [   11.279538] gpmc_probe_generic_child : cs = 0, child->full_name = /ocp/gpmc@
    [   11.288570] gpmc_probe_generic_child : cs = 0, base = 0x8000000
    [   11.294920] gpmc_probe_generic_child : cs = 0, bank-width = 0x2
    [   11.301309] *********** Rahul : gpmc_cs_set_timings *************
    [   11.307731] GPMC CS0: cs_on     :   2 ticks,   3 ns (was   1 ticks)   2 ns
    [   11.315001] GPMC CS0: cs_rd_off :  28 ticks,  52 ns (was  28 ticks)  51 ns
    [   11.322275] GPMC CS0: cs_wr_off :  29 ticks,  54 ns (was  30 ticks)  54 ns
    [   11.329542] GPMC CS0: adv_on    :   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.336794] GPMC CS0: adv_rd_off:   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.344057] GPMC CS0: adv_wr_off:   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.351321] GPMC CS0: oe_on     :   4 ticks,   7 ns (was   3 ticks)   6 ns
    [   11.358595] GPMC CS0: oe_off    :  28 ticks,  52 ns (was  28 ticks)  51 ns
    [   11.365850] GPMC CS0: we_on     :   7 ticks,  13 ns (was   7 ticks)  13 ns
    [   11.373108] GPMC CS0: we_off    :  15 ticks,  28 ns (was  15 ticks)  27 ns
    [   11.380375] GPMC CS0: rd_cycle  :  30 ticks,  56 ns (was  31 ticks)  56 ns
    [   11.387646] GPMC CS0: wr_cycle  :  30 ticks,  56 ns (was  31 ticks)  56 ns
    [   11.394907] GPMC CS0: access    :  27 ticks,  50 ns (was  27 ticks)  49 ns
    [   11.402172] GPMC CS0: page_burst_access:   5 ticks,   9 ns (was   4 ticks)  s
    [   11.410104] GPMC CS0: bus_turnaround:   0 ticks,   0 ns (was   0 ticks)   0 s
    [   11.417734] GPMC CS0: cycle2cycle_delay:   0 ticks,   0 ns (was   0 ticks)  s
    [   11.425635] GPMC CS0: wait_monitoring:   0 ticks,   0 ns (was   0 ticks)   0s
    [   11.433366] GPMC CS0: clk_activation:   0 ticks,   0 ns (was   0 ticks)   0 s
    [   11.441005] GPMC CS0: wr_data_mux_bus:   7 ticks,  13 ns (was   7 ticks)  13s
    [   11.448743] GPMC CS0: wr_access :  30 ticks,  56 ns (was  15 ticks)  56 ns
    [   11.456007]
    The CONFIG_3 =0x0
    The CONFIG_7 =0x848
    [   11.476647]
    [   11.481980] intel,pf48f6000m0y1be: Found 1 x16 devices at 0x0 in 16-bit bank2
    [   11.493574] Intel/Sharp Extended Query Table at 0x010A
    [   11.499016] Intel/Sharp Extended Query Table at 0x010A
    [   11.504455] Intel/Sharp Extended Query Table at 0x010A
    [   11.509908] Intel/Sharp Extended Query Table at 0x010A
    [   11.515347] Intel/Sharp Extended Query Table at 0x010A
    [   11.520805] Using buffer write method
    [   11.524670] Using auto-unlock on power-up/resume
    [   11.529546] cfi_cmdset_0001: Erase suspend on write enabled
    [   11.535660] 5 ofpart partitions found on MTD device intel,pf48f6000m0y1be
    [   11.542842] Creating 5 MTD partitions on "intel,pf48f6000m0y1be":
    [   11.549292] 0x000000000000-0x000000060000 : "NOR.u-boot"
    [   11.556013] 0x000000060000-0x000000080000 : "NOR.u-boot-env"
    [   11.562988] 0x000000080000-0x0000000a0000 : "NOR.u-boot-kernel.dtb"
    [   11.570578] 0x0000000a0000-0x000000680000 : "NOR.kernel"
    [   11.577304] 0x000000680000-0x000008000000 : "NOR.file-system"
    [   11.587269]
    [   11.587269] THE GPMC ret = 0
    [   11.591866] gpmc_probe_generic_child : cs = 1, child->full_name = /ocp/gpmc@
    [   11.600898] gpmc_probe_generic_child : cs = 1, base = 0x10000000
    [   11.607346] gpmc_probe_generic_child : cs = 1, bank-width = 0x2
    [   11.613721] *********** Rahul : gpmc_cs_set_timings *************
    [   11.620164] GPMC CS1: cs_on     :   2 ticks,   3 ns (was   1 ticks)   2 ns
    [   11.627434] GPMC CS1: cs_rd_off :  28 ticks,  52 ns (was  28 ticks)  51 ns
    [   11.634685] GPMC CS1: cs_wr_off :  29 ticks,  54 ns (was  30 ticks)  54 ns
    [   11.641951] GPMC CS1: adv_on    :   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.649220] GPMC CS1: adv_rd_off:   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.656486] GPMC CS1: adv_wr_off:   0 ticks,   0 ns (was   0 ticks)   0 ns
    [   11.663741] GPMC CS1: oe_on     :   4 ticks,   7 ns (was   3 ticks)   6 ns
    [   11.671010] GPMC CS1: oe_off    :  28 ticks,  52 ns (was  28 ticks)  51 ns
    [   11.678277] GPMC CS1: we_on     :   7 ticks,  13 ns (was   7 ticks)  13 ns
    [   11.685532] GPMC CS1: we_off    :  15 ticks,  28 ns (was  15 ticks)  27 ns
    [   11.692801] GPMC CS1: rd_cycle  :  30 ticks,  56 ns (was  31 ticks)  56 ns
    [   11.700070] GPMC CS1: wr_cycle  :  30 ticks,  56 ns (was  31 ticks)  56 ns
    [   11.707342] GPMC CS1: access    :  27 ticks,  50 ns (was  27 ticks)  49 ns
    [   11.714595] GPMC CS1: page_burst_access:   5 ticks,   9 ns (was   4 ticks)  s
    [   11.722493] GPMC CS1: bus_turnaround:   0 ticks,   0 ns (was   0 ticks)   0 s
    [   11.730133] GPMC CS1: cycle2cycle_delay:   0 ticks,   0 ns (was   0 ticks)  s
    [   11.738042] GPMC CS1: wait_monitoring:   0 ticks,   0 ns (was   0 ticks)   0s
    [   11.745763] GPMC CS1: clk_activation:   0 ticks,   0 ns (was   0 ticks)   0 s
    [   11.753382] GPMC CS1: wr_data_mux_bus:   7 ticks,  13 ns (was   7 ticks)  13s
    [   11.761104] GPMC CS1: wr_access :  30 ticks,  56 ns (was  15 ticks)  56 ns
    [   11.768374]
    The CONFIG_3 =0x0
    The CONFIG_7 =0x850
    [   11.788999]
    [   11.794312] intel,pf48f6000m0y1be: Found 1 x16 devices at 0x0 in 16-bit bank2
    [   11.805901] Intel/Sharp Extended Query Table at 0x010A
    [   11.811330] Intel/Sharp Extended Query Table at 0x010A
    [   11.816779] Intel/Sharp Extended Query Table at 0x010A
    [   11.822213] Intel/Sharp Extended Query Table at 0x010A
    [   11.827669] Intel/Sharp Extended Query Table at 0x010A
    [   11.833113] Using buffer write method
    [   11.836983] Using auto-unlock on power-up/resume
    [   11.841850] cfi_cmdset_0001: Erase suspend on write enabled
    [   11.847937] 1 ofpart partitions found on MTD device intel,pf48f6000m0y1be
    [   11.855101] Creating 1 MTD partitions on "intel,pf48f6000m0y1be":
    [   11.861550] 0x000000000000-0x000008000000 : "NOR.ROOTFS"
    [   11.871092]
    [   11.871092] THE GPMC ret = 0
    [   11.875708] gpmc_dcmist_fpga_init(): GPMC FCLK: TRACE 1
    [   11.881223]  GPMC BEFORE GPMC_GET_CS b0191da8
    [   11.885835]  GPMC base address 18000000
    [   11.889881]  GPMC Chipseleect 2
    [   11.893194] ++++++++++++++++++++++++++++++++++
    [   11.897890] GPMC Chip select 2
    [   11.901106] ===============================
    [   11.905533] **********GPMC CS  = 2*************
    [   11.910313] GPMC_CS_CONFIG1:= 0x7ac81211
    [   11.914442] GPMC_CS_CONFIG2:= 0xb0f03
    [   11.918311] GPMC_CS_CONFIG3:= 0x60604
    [   11.922173] GPMC_CS_CONFIG4:= 0xa060f06
    [   11.926226] GPMC_CS_CONFIG5:= 0x3090f14
    [   11.930272] GPMC_CS_CONFIG6:= 0x90604c4
    [   11.934310] GPMC_CS_CONFIG7:= 0xe58
    [   11.937999] ===============================
    [   11.942796]
    [   11.942796] res-start =0x18000000 and size = 0x2000000
    [   11.950118] MISC DEVICE REGISTERED
    [   11.954100] input: TX FPGA as /devices/virtual/input/input0
    [   11.960405]
    [   11.960405] THE END OF PROBE
    [   11.966156] palmas 0-0058: Irq flag is 0x00000000
    [   11.973971] palmas 0-0058: Muxing GPIO e, PWM 0, LED 0
    [   11.981520] smps123: 850 <--> 1250 mV at 1070 mV
    [   11.988097] smps45: 850 <--> 1150 mV at 990 mV
    [   11.994426] smps6: 850 <--> 1650 mV at 1010 mV
    [   12.000752] smps7: 850 <--> 1060 mV at 1050 mV
    [   12.007123] smps8: 850 <--> 1250 mV at 1010 mV
    [   12.013479] smps9: 1800 mV
    [   12.017723] ldo1: 1800 <--> 3300 mV at 3000 mV
    [   12.024129] ldo2: 3300 mV
    [   12.028742] ldo3: 2000 mV
    [   12.032411] LDO4: at 1800 mV
    [   12.036154] LDO5: no parameters
    [   12.040006] LDO6: no parameters
    [   12.043881] LDO7: no parameters
    [   12.047761] LDO8: no parameters
    [   12.052423] ldo9: 1050 mV
    [   12.057000] ldoln: 1800 mV
    [   12.061581] ldousb: 3300 mV
    [   12.065292] REGEN1: no parameters
    [   12.068993] REGEN2: no parameters
    [   12.072681] REGEN3: no parameters
    [   12.076388] SYSEN1: no parameters
    [   12.080079] SYSEN2: no parameters
    [   12.085674] input: palmas_pwron as /devices/ocp.3/48070000.i2c/i2c-0/0-0058/1
    [   12.097608] tlc59108 0-0040: Successfully initialized tlc59108
    [   12.103788] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [   12.110358] omap_i2c 48072000.i2c: bus 1 rev0.12 at 10 kHz
    [   12.116336] platform 4ae07ddc.regulator-abb-mpu: Driver ti_abb requests probl
    [   12.124947] platform 4ae07e24.regulator-abb-ivahd: Driver ti_abb requests prl
    [   12.133690] platform 4ae07e20.regulator-abb-dspeve: Driver ti_abb requests pl
    [   12.142530] platform 4ae07de4.regulator-abb-gpu: Driver ti_abb requests probl
    [   12.151678] 4a003b18.regulator-avs: 1090 <--> 1280 mV at 1090 mV
    [   12.158849] 4a0025ec.regulator-avs: 1030 mV
    [   12.163961] 4a003b00.regulator-avs: 1090 <--> 1280 mV at 1090 mV
    [   12.170945] 4a0025d8.regulator-avs: 1060 <--> 1250 mV at 1060 mV
    [   12.177946] 4a0025c4.regulator-avs: 1060 <--> 1250 mV at 1060 mV
    [   12.184727] platform 4a0021e0.bandgap: Driver ti-soc-thermal requests probe l
    [   12.193355] omap-dma-engine 4a056000.dma-controller: allocating channel for 2
    [   12.201009] omap-dma-engine 4a056000.dma-controller: allocating channel for 1
    [   12.208979]
    [   12.208979] The pbaias regulator vmode =0x200000
    [   12.253543] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.262569] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.270455] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.278777] cpu cpu0: cpu0 regulator not ready, retry
    [   12.285181] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe defel
    [   12.297411] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
    [   12.304440] [drm] No driver support for vblank timestamp query.
    [   12.318362] [drm] Enabling DMM ywrap scrolling
    [   12.352259] Console: switching to colour frame buffer device 160x50
    [   12.365438] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [   12.371701] omapdrm omapdrm.0: registered panic notifier
    [   12.377344] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [   12.384134] abb_mpu: 1090 <--> 1280 mV
    [   12.389699] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   12.397773] abb_ivahd: 1055 <--> 1250 mV
    [   12.402067] regulator regulator.34: No match for 1060000
    [   12.408195] abb_dspeve: 1055 <--> 1250 mV
    [   12.412570] regulator regulator.35: No match for 1060000
    [   12.418568] abb_gpu: 1090 <--> 1280 mV
    [   12.423410] platform 4a0021e0.bandgap: Driver ti-soc-thermal requests probe l
    [   12.431750] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.440811] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.449667] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.462916] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.471908] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.479732] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.552003] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [   12.558426] davinci_mdio 48485000.mdio: detected phy mask fffffffb
    [   12.566840] libphy: 48485000.mdio: probed
    [   12.566970] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.567002] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.567013] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.595972] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, dri1
    [   12.605249] Missing dual_emac_res_vlan in DT.
    [   12.605279] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.605308] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.605320] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.634728] Using 1 as Reserved VLAN for 0 slave
    [   12.639655] Missing dual_emac_res_vlan in DT.
    [   12.644260] Using 2 as Reserved VLAN for 1 slave
    [   12.649124] Detected MACID = fc:0f:4b:c9:76:ba
    [   12.654435] cpsw: Random MACID = a2:2f:39:04:18:46
    [   12.660070] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   12.669174] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   12.677187] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   12.685418] omap_rtc 48838000.rtcss: setting system clock to 2000-01-01 00:0)
    [   12.704066] platform 48970000.vip: omap_device_late_idle: enabled but no drig
    [   12.712705] platform 48990000.vip: omap_device_late_idle: enabled but no drig
    [   12.721300] platform 489b0000.vip: omap_device_late_idle: enabled but no drig
    [   12.730073] ALSA device list:
    [   12.733241]   No soundcards found.
    [   12.737359] Waiting for root device /dev/mmcblk0p2...
    [   12.742876] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   13.012243] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   13.280958] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   13.549713] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   13.818452] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   14.087192] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   14.355900] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   14.624652] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   14.893406] pbias_regulator: unsupportable voltage range: 2600000-1800000uV
    [   14.940775] mmc1: Skipping voltage switch
    [   15.173745] mmc1: new high speed SDHC card at address aaaa
    [   15.179987] mmcblk0: mmc1:aaaa SS08G 7.40 GiB
    [   15.190989]  mmcblk0: p1 p2
    [   15.194750] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   15.203837] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   15.211675] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   15.263471] EXT3-fs (mmcblk0p2): error: couldn't mount because of unsupporte)
    [   15.277337] EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupporte)
    [   15.828900] EXT4-fs (mmcblk0p2): recovery complete
    [   15.835931] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. )
    [   15.844520] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [   15.855631] devtmpfs: mounted
    [   15.858997] Freeing unused kernel memory: 352K (8085d000 - 808b5000)
    [   17.756342] cryptodev: driver 1.6 loaded.
    Starting udev
    [   17.966398] udevd[1188]: starting version 182
    [   18.318281] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   18.376657] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   18.384486] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   18.466350] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   18.491655] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   18.503081] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   18.550745] Loading modules backported from Linux version ol_r8.a9.14-6-g0e4b
    [   18.559406] Backport generated by backports.git ol_r8.a9.15-0-g0d46f43
    [   18.600579] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Starting Bootlog daemon: [   18.694781] omap-hdmi-audio omap-hdmi-audio: ASoC: d
    [   18.726405]  remoteproc3: failed to load dra7-ipu1-fw.xem4
    [   18.746816] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   18.791528] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   19.006368] wl1271_sdio mmc0:0001:2: No platform data set
    [   19.012977] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   19.024449] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   19.037601] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    bootlogd: cannot allocate pseudo tty: No such file or directory
    bootlogd.
    [   19.177795] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   19.186916] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   19.194774] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   19.398277] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   19.408320] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   19.416454] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   19.697856] cfg80211: Calling CRDA to update world regulatory domain
    [   20.557832] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   20.567041] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   20.574917] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   20.819926]  remoteproc1: powering up ipu2
    [   20.824842]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3365812
    [   20.834219] omap-iommu omap-iommu.5: mmu_ipu2: version 2.1
    [   20.952725]  remoteproc1: remote processor ipu2 is now up
    [   21.010835] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   21.017050] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   21.026443]  remoteproc1: registered virtio0 (type 7)
    [   21.032251] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   21.040138] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   21.272026] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [   21.285030] wlcore: loaded
    [   21.287899] wlcore: driver version: ol_r8.a9.14
    [   21.292695] wlcore: compilation time: Wed Sep 24 00:03:03 2014
    [   21.370299] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample a2
    [   21.378772] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample a3
    [   21.390580] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x3b
    [   21.397978] rpmsg_rpc rpmsg2: probing service rpmsg-dce with src 1024 dst 59
    [   21.409075] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    udevadm settle - timeout of 3 seconds reached,[   21.418187] rpmsg_rpc rpmsg2: 8
     the event queue contains:
      /sys/devices/ocp.3[   21.427751] omap-hdmi-audio omap-hdmi-audio: snd_soc_reg)
    /4809c000.mmc/mmc_host/mmc1/mmc1:aaaa/block/mmcb[   21.440214] platform omap-hdl
    lk0 (1128)
      /sys/devices/ocp.3/4809c000.mmc/mmc_host/mmc1/mmc1:aaaa/block/mmcblk0/mmcblk0)
      /sys/devices/platform/omap-rproc.0/remoteproc0/firmware/dra7-dsp1-fw.xe66 (14)
      /sys/devices/platform/omap-rproc.2/remoteproc2/firmware/dra7-dsp2-fw.xe66 (14)
      /sys/devices/platform/regulatory.0 (1539)
    Configuring network interfaces... [   22.633794]  remoteproc0: powering up dsp1
    [   22.639615]  remoteproc0: Booting fw image dra7-dsp1-fw.xe66, size 7383232
    [   22.654191] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [   22.660425] omap-iommu omap-iommu.0: mmu0_dsp1: version 3.0
    [   22.666360] omap-iommu omap-iommu.1: mmu1_dsp1: version 3.0
    [   22.700081]  remoteproc2: powering up dsp2
    [   22.704442]  remoteproc2: Booting fw image dra7-dsp2-fw.xe66, size 7499100
    [   22.718889] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
    [   22.725111] omap-iommu omap-iommu.2: mmu0_dsp2: version 3.0
    [   22.731041] omap-iommu omap-iommu.3: mmu1_dsp2: version 3.0
    /usr/sbin/alsactl: load_state:1729: No soundcards found...
    [   22.791033]  remoteproc0: remote processor dsp1 is now up
    [   22.814439] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   22.820498] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   22.829549]  remoteproc0: registered virtio1 (type 7)
    [   22.834948] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   22.842786] platform omap-hdmi-audio: Driver omap-hdmi-audio requests probe l
    [   22.845279] cfg80211: World regulatory domain updated:
    [   22.845285] cfg80211:  DFS Master region: unset
    [   22.845286] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_ga)
    [   22.845293] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2)
    [   22.845299] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2)
    [   22.845304] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2)
    [   22.845309] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2)
    [   22.845314] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2)
    [   22.972216] net eth0: initializing cpsw version 1.15 (0)
    [   22.981929] net eth0: phy found : id is : 0x1410cc2
    [   22.987523] cpsw 48484000.ethernet: Phy mode driver DT not found
    [   23.001468] 8021q: adding VLAN 0 to HW filter on device eth0
    udhcpc (v1.21.1) started
    [   23.030001]  remoteproc2: remote processor dsp2 is now up
    [   23.036426] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   23.042241]  remoteproc2: registered virtio2 (type 7)
    [   23.042488] omap-hdmi-audio omap-hdmi-audio: ASoC: CPU DAI omap-hdmi-audio-dd
    [   23.042526] omap-hdmi-audio omap-hdmi-audio: snd_soc_register_card failed (-)
    [   23.042542] platform omap-hdmi-audio: Driver omap-hdmi-audio requests prob
  • Nagarjuna Guttikonda said:
    we are using the following SDK: ti-glsdk_dra7xx-evm_6_10_00_02
    This SDK is not supported on AM57x devices. DRA7xx processors are supported on a different forum: e2e.ti.com/.../1020
  • Nagarjuna,
    For AM57x, please use the Processor SDK found here:
    www.ti.com/.../PROCESSOR-SDK-AM57X sdk&tisearch=Search-EN-Everything
