Champs,
Customer has requested the above info . This in the same context and by the same customer who asked earlier for the same info on AM5716:
https://e2e.ti.com/support/arm/sitara_arm/int_sitara_am335x/f/425/p/435545/1559915 .
will greatly appreciate you providing the info ASAP
thank you
Michael
Mukul,
Customer's release to manufacturing is pending on this info and things start heating up. I'll greatly appreciate your help expediting the response
thanks
Michael
Hi Michael
Solder Mask Opening: 450 um
Substrate Pad size: 550 um +/- 30 um (tolerance)
You will see some of this captured in table 2 in the application note
http://www.ti.com/lit/ug/spru811a/spru811a.pdf
This is referred in the device datasheet.
The table mentions 0.52 mm, which is 550 um - 30 um (for min size guidance) - it took us time internally to understand the discrepancy.
Hope this helps.
Mukul
