NAND bad blocks problem when we enable the ‘NAND Flash device on DaVinci SoC’ in kernel configuration
kernel
Linux video capture interface: v2.00
i2c /dev entries driver
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
MUX: initialized ATAEN
ide0: MMIO-DMA , BIOS settings: hda:pio, hdb:pio
hda: TOSHIBA MK4032GAX, ATA DISK drive
ide0 at 0xfec661f0-0xfec661f7,0xfec663f6 on irq 22
No valid DiskOnChip devices found
nand_davinci nand_davinci.0: Using 1-bit hardware ECC
NAND device: Manufacturer ID: 0x20, Chip ID: 0xf1 (ST Micro NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 0 at 0x00000000
Bad eraseblock 2 at 0x00040000
Bad eraseblock 3 at 0x00060000
Bad eraseblock 4 at 0x00080000
Bad eraseblock 5 at 0x000a0000
Bad eraseblock 6 at 0x000c0000
Bad eraseblock 7 at 0x000e0000
Bad eraseblock 8 at 0x00100000
Bad eraseblock 9 at 0x00120000
Bad eraseblock 1017 at 0x07f20000
Bad eraseblock 1018 at 0x07f40000
Bad eraseblock 1019 at 0x07f60000
Bad eraseblock 1020 at 0x07f80000
Bad eraseblock 1021 at 0x07fa0000
Bad eraseblock 1022 at 0x07fc0000
Bad eraseblock 1023 at 0x07fe0000
Creating 4 MTD partitions on "nand_davinci.0":
0x00000000-0x00080000 : "bootloader"
0x00080000-0x000a0000 : "params"
0x000a0000-0x004a0000 : "kernel"
0x004a0000-0x08000000 : "filesystem"
nand_davinci nand_davinci.0: hardware revision: 2.2
Initializing USB Mass Storage driver...
do you know what's the problem?
