Other Parts Discussed in Thread: TMP102
Tool/software: Linux
Hi ,
We are try to bring up the linux on AM5728 custom board with SDK 04.01.00.06.
I was struck with u-boot first and when i commented CONFIG_SPL_LOAD_FIT=y in am57xx_evm_defconfig file , it went further and started kernel but after this log lines.
[ 3.082973] tmp102 0-0048: error reading config register
[ 3.088403] tmp102: probe of 0-0048 failed with error -121
it's throw some error and stop.
I attached the error log during the boot process.
Any one please help me to resolve this issue.
Thanks and Regards
Aslam
U-Boot SPL 2017.01-00360-g9f4b0ab-dirty (Nov 04 2017 - 14:49:54) DRA752-GP ES2.0 Trying to boot from MMC1 reading uboot.env ** Unable to read "uboot.env" from mmc0:1 ** Using default environment reading u-boot.img reading u-boot.img U-Boot 2017.01-00360-g9f4b0ab-dirty (Nov 04 2017 - 14:49:54 +0530) CPU : DRA752-GP ES2.0 Model: TI AM5728 IDK Board: UNKNOWN(BeagleBoard X15?) REV UNKNOWN DRAM: 2 GiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 reading uboot.env ** Unable to read "uboot.env" from mmc0:1 ** Using default environment I2C chip 50: requested alen 2 does not match chip offset_len 1 SCSI: SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst scanning bus for devices... Found 0 device(s). Net: <ethaddr> not set. Validating first E-fuse MAC cpsw Hit any key to stop autoboot: 2 1 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 reading boot.scr ** Unable to read file boot.scr ** reading uEnv.txt 574 bytes read in 3 ms (186.5 KiB/s) Loaded env from uEnv.txt Importing environment from mmc0 ... switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 3736632 bytes read in 203 ms (17.6 MiB/s) 103245 bytes read in 41 ms (2.4 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8ffe3000, end 8ffff34c ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.9.41-ge3a80a1c5c (tctl@tctl-Lenovo-G50-80) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #4 SMP PREEMPT Sat Nov 4 15:34:54 IST 2017 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt:Machine model: TI AM5728 BeagleBoard-X15 [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB [ 0.000000] OF: reserved mem: initialized node ipu2_cma@95800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node dsp1_cma@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier [ 0.000000] DRA752 ES2.0 [ 0.000000] percpu: Embedded 13 pages/cpu @eed36000 s22156 r8192 d22900 u53248 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 472640 [ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=0002685f-02 rw rootfstype=ext4 rootwait [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 1675680K/1897472K available (8192K kernel code, 315K rwdata, 2420K rodata, 2048K init, 304K bss, 33376K reserved, 188416K cma-reserved, 1283072K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB) [ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB) [ 0.000000] .data : 0xc1000000 - 0xc104ed60 ( 316 kB) [ 0.000000] .bss : 0xc1050000 - 0xc109c0f0 ( 305 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 6.14MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [ 0.000017] Switching to timer-based delay loop, resolution 162ns [ 0.000319] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000327] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000726] Console: colour dummy device 80x30 [ 0.000742] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2' [ 0.000749] This ensures that you still see kernel messages. Please [ 0.000755] update your kernel commandline. [ 0.000772] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [ 0.000786] pid_max: default: 32768 minimum: 301 [ 0.000888] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000899] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001506] CPU: Testing write buffer coherency: ok [ 0.001712] /cpus/cpu@0 missing clock-frequency property [ 0.001728] /cpus/cpu@1 missing clock-frequency property [ 0.001740] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.001757] Setting up static identity map for 0x80200000 - 0x80200060 [ 0.080074] EFI services will not be available. [ 0.170262] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.170350] Brought up 2 CPUs [ 0.170363] SMP: Total of 2 processors activated (24.59 BogoMIPS). [ 0.170371] CPU: All CPU(s) started in HYP mode. [ 0.170377] CPU: Virtualization extensions available. [ 0.170878] devtmpfs: initialized [ 0.197378] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.197619] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.197636] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.200998] pinctrl core: initialized pinctrl subsystem [ 0.201800] NET: Registered protocol family 16 [ 0.202648] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.203640] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.315962] omap_hwmod: dcan1: _wait_target_disable failed [ 0.450399] cpuidle: using governor ladder [ 0.490435] cpuidle: using governor menu [ 0.500179] OMAP GPIO hardware version 0.1 [ 0.514806] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 ! [ 0.539037] No ATAGs? [ 0.539063] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.539073] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.539422] omap4_sram_init:Unable to allocate sram needed to handle errata I688 [ 0.539432] omap4_sram_init:Unable to get sram pool needed to handle errata I688 [ 0.539955] OMAP DMA hardware revision 0.0 [ 0.581549] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [ 0.582787] edma 43300000.edma: memcpy is disabled [ 0.587584] edma 43300000.edma: TI EDMA DMA engine driver [ 0.591544] omap-iommu 40d01000.mmu: 40d01000.mmu registered [ 0.591725] omap-iommu 40d02000.mmu: 40d02000.mmu registered [ 0.591883] omap-iommu 58882000.mmu: 58882000.mmu registered [ 0.592036] omap-iommu 55082000.mmu: 55082000.mmu registered [ 0.592289] omap-iommu 41501000.mmu: 41501000.mmu registered [ 0.592473] omap-iommu 41502000.mmu: 41502000.mmu registered [ 0.594994] palmas 0-0058: Irq flag is 0x00000008 [ 0.622780] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0 [ 0.626602] vtt_fixed: supplied by smps3 [ 0.651652] random: fast init done [ 0.701930] vdd_3v3: supplied by regen1 [ 0.702151] aic_dvdd_fixed: supplied by vdd_3v3 [ 0.705321] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [ 0.705818] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz [ 0.705996] media: Linux media interface: v0.10 [ 0.706041] Linux video capture interface: v2.00 [ 0.706079] pps_core: LinuxPPS API ver. 1 registered [ 0.706086] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.706106] PTP clock support registered [ 0.706137] EDAC MC: Ver: 3.0.0 [ 0.706831] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400 [ 0.707113] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400 [ 0.707405] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 0.707687] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 0.708022] Advanced Linux Sound Architecture Driver Initialized. [ 0.708810] clocksource: Switched to clocksource arch_sys_counter [ 0.719456] NET: Registered protocol family 2 [ 0.719955] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.720018] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.720144] TCP: Hash tables configured (established 8192 bind 8192) [ 0.720190] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.720220] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.720410] NET: Registered protocol family 1 [ 0.720726] RPC: Registered named UNIX socket transport module. [ 0.720735] RPC: Registered udp transport module. [ 0.720741] RPC: Registered tcp transport module. [ 0.720748] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.721629] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.724578] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.732108] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.732826] NFS: Registering the id_resolver key type [ 0.732847] Key type id_resolver registered [ 0.732855] Key type id_legacy registered [ 0.732895] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.734080] bounce: pool size: 64 pages [ 0.734228] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.734238] io scheduler noop registered [ 0.734247] io scheduler deadline registered [ 0.734379] io scheduler cfq registered (default) [ 0.739263] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128 [ 0.741813] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.3 [ 0.742130] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges: [ 0.742142] OF: PCI: No bus range found for /ocp/axi@0/pcie@51000000, using [bus 00-ff] [ 0.742176] OF: PCI: IO 0x20003000..0x20012fff -> 0x00000000 [ 0.742198] OF: PCI: MEM 0x20013000..0x2fffffff -> 0x20013000 [ 1.743590] dra7-pcie 51000000.pcie: phy link never came up [ 1.743753] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00 [ 1.743767] pci_bus 0000:00: root bus resource [bus 00-ff] [ 1.743778] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 1.743789] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff] [ 1.744162] PCI: bus0: Fast back to back transfers disabled [ 1.744275] PCI: bus1: Fast back to back transfers enabled [ 1.744396] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff] [ 1.744411] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff] [ 1.744426] pci 0000:00:00.0: PCI bridge to [bus 01] [ 1.744646] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [ 1.807671] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 1.811088] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250 [ 2.770349] console [ttyS2] enabled [ 2.775672] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20 [ 2.782445] [drm] Initialized [ 2.787154] OMAP DSS rev 6.1 [ 2.790523] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops) [ 2.798965] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops) [ 2.889540] brd: module loaded [ 2.947894] loop: module loaded [ 2.951660] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write [ 2.961198] libphy: Fixed MDIO Bus: probed [ 3.018846] davinci_mdio 48485000.mdio: davinci mdio revision 1.6 [ 3.024971] libphy: 48485000.mdio: probed [ 3.031838] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY [ 3.042076] cpsw 48484000.ethernet: Detected MACID = d4:36:39:fb:6e:14 [ 3.048719] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies) [ 3.057031] cpsw 48484000.ethernet: cpsw: Detected MACID = d4:36:39:fb:6e:15 [ 3.065478] mousedev: PS/2 mouse device common for all mice [ 3.071382] i2c /dev entries driver [ 3.077527] gpio-fan gpio_fan: GPIO fan initialized [ 3.082973] tmp102 0-0048: error reading config register [ 3.088403] tmp102: probe of 0-0048 failed with error -121 [ 3.098906] omap_hsmmc 4809c000.mmc: Got CD GPIO [ 3.169187] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode [ 3.175567] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode [ 3.259672] ledtrig-cpu: registered to indicate activity on CPUs [ 3.272108] omap_hwmod: mcasp3: _wait_target_ready failed: -16 [ 3.277967] davinci-mcasp 48468000.mcasp: use pm_runtime_put_sync_suspend() in driver? [ 3.285932] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000 [ 3.285937] ------------[ cut here ]------------ [ 3.285948] WARNING: CPU: 0 PID: 20 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x36c [ 3.285951] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access [ 3.285955] Modules linked in: [ 3.285960] CPU: 0 PID: 20 Comm: kworker/0:1 Not tainted 4.9.41-ge3a80a1c5c #4 [ 3.285962] Hardware name: Generic DRA74X (Flattened Device Tree) [ 3.285970] Workqueue: events_freezable mmc_rescan [ 3.285973] Backtrace: [ 3.285982] [<c020b29c>] (dump_backtrace) from [<c020b558>] (show_stack+0x18/0x1c) [ 3.285988] r7:00000009 r6:60000193 r5:00000000 r4:c10225d0 [ 3.285994] [<c020b540>] (show_stack) from [<c04cce80>] (dump_stack+0x8c/0xa0) [ 3.285999] [<c04ccdf4>] (dump_stack) from [<c022e3e8>] (__warn+0xec/0x104) [ 3.286002] r7:00000009 r6:c0bc00e8 r5:00000000 r4:eea53ae0 [ 3.286007] [<c022e2fc>] (__warn) from [<c022e440>] (warn_slowpath_fmt+0x40/0x48) [ 3.286012] r9:0000001a r8:eea1b0d0 r7:c0bbff54 r6:00000002 r5:c0bc0014 r4:c0bc00b8 [ 3.286017] [<c022e404>] (warn_slowpath_fmt) from [<c04fcd30>] (l3_interrupt_handler+0x25c/0x36c) [ 3.286019] r3:eea14f00 r2:c0bc00b8 [ 3.286021] r4:80080003 [ 3.286027] [<c04fcad4>] (l3_interrupt_handler) from [<c027fc50>] (__handle_irq_event_percpu+0xb4/0x138) [ 3.286032] r10:c101a4af r9:eea17300 r8:00000017 r7:eea53c04 r6:00000000 r5:eea17300 [ 3.286034] r4:eea1b440 [ 3.286039] [<c027fb9c>] (__handle_irq_event_percpu) from [<c027fcf8>] (handle_irq_event_percpu+0x24/0x60) [ 3.286043] r10:00000034 r9:eea52000 r8:ee808000 r7:00000000 r6:c1008c34 r5:eea17300 [ 3.286044] r4:eea17300 [ 3.286049] [<c027fcd4>] (handle_irq_event_percpu) from [<c027fd74>] (handle_irq_event+0x40/0x64) [ 3.286051] r5:eea17360 r4:eea17300 [ 3.286057] [<c027fd34>] (handle_irq_event) from [<c0283420>] (handle_fasteoi_irq+0xc0/0x190) [ 3.286060] r7:00000000 r6:c1008c34 r5:eea17360 r4:eea17300 [ 3.286065] [<c0283360>] (handle_fasteoi_irq) from [<c027ee78>] (generic_handle_irq+0x2c/0x3c) [ 3.286068] r7:00000000 r6:00000000 r5:00000017 r4:c0e5cde0 [ 3.286072] [<c027ee4c>] (generic_handle_irq) from [<c027f400>] (__handle_domain_irq+0x64/0xbc) [ 3.286077] [<c027f39c>] (__handle_domain_irq) from [<c02014a0>] (gic_handle_irq+0x40/0x7c) [ 3.286081] r9:eea52000 r8:fa213000 r7:fa212000 r6:eea53cc0 r5:fa21200c r4:c1003424 [ 3.286085] [<c0201460>] (gic_handle_irq) from [<c020c0f8>] (__irq_svc+0x58/0x8c) [ 3.286087] Exception stack(0xeea53cc0 to 0xeea53d08) [ 3.286091] 3cc0: c1050268 00000000 bea9ce20 c073b950 c1087120 00001803 03adbfe7 0ccccb60 [ 3.286095] 3ce0: c0c16360 00000001 00000034 eea53d1c eea53d20 eea53d10 c020f20c c073b960 [ 3.286097] 3d00: a0000013 ffffffff [ 3.286101] r9:eea52000 r8:c0c16360 r7:eea53cf4 r6:ffffffff r5:a0000013 r4:c073b960 [ 3.286110] [<c073b950>] (arch_counter_get_cntpct) from [<c020f20c>] (arch_timer_read_counter_long+0x1c/0x20) [ 3.286115] [<c020f1f0>] (arch_timer_read_counter_long) from [<c04cabfc>] (__timer_delay+0x50/0x60) [ 3.286119] [<c04cabac>] (__timer_delay) from [<c04cac34>] (__timer_const_udelay+0x28/0x2c) [ 3.286123] r7:0ccccb60 r6:eea53dc4 r5:00000187 r4:ee05e800 [ 3.286127] [<c04cac0c>] (__timer_const_udelay) from [<c071b21c>] (__mmc_start_request+0x90/0xe8) [ 3.286131] [<c071b18c>] (__mmc_start_request) from [<c071b36c>] (mmc_start_request+0xf8/0x120) [ 3.286135] r9:00000001 r8:00000000 r7:00000000 r6:ee05e800 r5:ee05e800 r4:eea53dc4 [ 3.286138] [<c071b274>] (mmc_start_request) from [<c071b970>] (mmc_wait_for_req+0x8c/0xf4) [ 3.286141] r5:eea53de4 r4:eea53dc4 [ 3.286145] [<c071b8e4>] (mmc_wait_for_req) from [<c071ba38>] (mmc_wait_for_cmd+0x60/0x80) [ 3.286147] r7:ee05e800 r6:00000000 r5:ee05e800 r4:eea53e24 [ 3.286154] [<c071b9d8>] (mmc_wait_for_cmd) from [<c0726ab8>] (mmc_io_rw_direct_host+0x98/0x12c) [ 3.286156] r6:eea53e97 r5:00000c00 r4:00000c00 [ 3.286162] [<c0726a20>] (mmc_io_rw_direct_host) from [<c0726f6c>] (sdio_reset+0x2c/0x64) [ 3.286166] r10:eea3d300 r9:00000000 r8:c0a64728 r7:c0a6471c r6:ee05e800 r5:00061a80 [ 3.286168] r4:ee05e800 [ 3.286173] [<c0726f40>] (sdio_reset) from [<c071e370>] (mmc_rescan+0x33c/0x380) [ 3.286175] r4:ee05ea6c [ 3.286180] [<c071e034>] (mmc_rescan) from [<c0244d84>] (process_one_work+0x1dc/0x3f8) [ 3.286184] r9:00000000 r8:eed3e000 r7:00000000 r6:eed3a600 r5:eea3d300 r4:ee05ea6c [ 3.286188] [<c0244ba8>] (process_one_work) from [<c02459dc>] (worker_thread+0x58/0x574) [ 3.286192] r10:eea3d300 r9:eea52000 r8:eed3a618 r7:c1002d00 r6:00000008 r5:eea3d318 [ 3.286193] r4:eed3a600 [ 3.286198] [<c0245984>] (worker_thread) from [<c024ad14>] (kthread+0x100/0x118) [ 3.286202] r10:00000000 r9:00000000 r8:c0245984 r7:eea3d300 r6:eea52000 r5:eea396c0 [ 3.286204] r4:00000000 [ 3.286210] [<c024ac14>] (kthread) from [<c0207c88>] (ret_from_fork+0x14/0x2c) [ 3.286213] r8:00000000 r7:00000000 r6:00000000 r5:c024ac14 r4:eea396c0 [ 3.286218] ---[ end trace bdea3cd7e1ac962a ]--- [ 3.748971] pgd = c0003000 [ 3.751687] [00000000] *pgd=80000080004003, *pmd=00000000 [ 3.757120] Internal error: : 1211 [#1] PREEMPT SMP ARM [ 3.762364] Modules linked in: [ 3.765434] CPU: 1 PID: 1 Comm: swapper/0 Tainted: G W 4.9.41-ge3a80a1c5c #4 [ 3.773641] Hardware name: Generic DRA74X (Flattened Device Tree) [ 3.779757] task: ee890000 task.stack: ee87a000 [ 3.784307] PC is at __pm_runtime_idle+0x24/0x88 [ 3.788945] LR is at davinci_mcasp_probe+0x9cc/0xb68 [ 3.793928] pc : [<c062e094>] lr : [<c07923a4>] psr: 20000013 [ 3.793928] sp : ee87bd10 ip : ee87bd30 fp : ee87bd2c [ 3.805453] r10: 00000000 r9 : 00000000 r8 : 00000000 [ 3.810696] r7 : ee8d8710 r6 : 00000000 r5 : 00000005 r4 : eeac7a10 [ 3.817249] r3 : eeac7ae8 r2 : 00000000 r1 : 00000005 r0 : eeac7a10 [ 3.823802] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 3.830964] Control: 30c5387d Table: 80003000 DAC: 55555555 [ 3.836731] Process swapper/0 (pid: 1, stack limit = 0xee87a210) [ 3.842760] Stack: (0xee87bd10 to 0xee87c000) [ 3.847132] bd00: ee3e2410 eeac7a10 00000000 ee8d8710 [ 3.855345] bd20: ee87bdc4 ee87bd30 c07923a4 c062e07c 00002000 ee8da610 ee3e2410 c0bcabf4 [ 3.863553] bd40: 00000001 00000000 ee87bd6c 00000020 eed587f0 00000002 00000084 00000001 [ 3.871764] bd60: ee87bd8c ee8dd820 00000000 ee8dd8c0 eeab6be0 c0bd0bc0 00000001 00000000 [ 3.879975] bd80: ee87bdb4 ee87bd90 c03982f8 c03949f0 eeac7a10 00000000 eeac7a18 eeac7a10 [ 3.888183] bda0: ffffffed c1044d74 fffffdfb c1044d74 00000000 00000000 ee87bde4 ee87bdc8 [ 3.896393] bdc0: c0625a70 c07919e4 eeac7a10 c108f624 00000000 00000000 ee87be0c ee87bde8 [ 3.904604] bde0: c0623e28 c0625a24 eeac7a10 c1044d74 eeac7a44 00000000 000000b9 c0e0061c [ 3.912812] be00: ee87be2c ee87be10 c0623f88 c0623c04 00000000 c1044d74 c0623ec8 00000000 [ 3.921022] be20: ee87be54 ee87be30 c0622100 c0623ed4 ee86465c eeab52b4 ee864670 c1044d74 [ 3.929232] be40: ee8d8680 c1036108 ee87be64 ee87be58 c06237c0 c062209c ee87be8c ee87be68 [ 3.937439] be60: c06232f8 c06237a8 c0c0ad8c ee87be78 c1044d74 ffffe000 c0e58ad0 c0e48834 [ 3.945649] be80: ee87bea4 ee87be90 c0624910 c06231f4 c1036108 ffffe000 ee87bebc ee87bea8 [ 3.953857] bea0: c06259cc c062489c c0e36f60 ffffe000 ee87becc ee87bec0 c0e36f7c c0625990 [ 3.962070] bec0: ee87bf4c ee87bed0 c02017bc c0e36f6c ee87bef4 ee87bee0 c024a1f4 c04d3754 [ 3.970277] bee0: effff600 c0a22644 ee87bf4c ee87bef8 c024a504 c0e00628 ee87bf34 c0b9c78c [ 3.978486] bf00: c0b9c044 c0ba6450 00000006 00000006 00000000 c0c5bc94 c0bed63c 00000000 [ 3.986694] bf20: 000004dc c1050000 c1050000 c0e58ad0 c0e48834 000000b9 c0e0061c 00000007 [ 3.994904] bf40: ee87bf94 ee87bf50 c0e00f64 c020177c 00000006 00000006 00000000 c0e0061c [ 4.003113] bf60: 00000000 c0c5bc94 00000000 00000000 c08c7148 00000000 00000000 00000000 [ 4.011324] bf80: 00000000 00000000 ee87bfac ee87bf98 c08c7158 c0e00d98 00000000 c08c7148 [ 4.019533] bfa0: 00000000 ee87bfb0 c0207c88 c08c7154 00000000 00000000 00000000 00000000 [ 4.027743] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 4.035953] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000 [ 4.044158] Backtrace: [ 4.046622] [<c062e070>] (__pm_runtime_idle) from [<c07923a4>] (davinci_mcasp_probe+0x9cc/0xb68) [ 4.055441] r7:ee8d8710 r6:00000000 r5:eeac7a10 r4:ee3e2410 [ 4.061126] [<c07919d8>] (davinci_mcasp_probe) from [<c0625a70>] (platform_drv_probe+0x58/0xb8) [ 4.069860] r10:00000000 r9:00000000 r8:c1044d74 r7:fffffdfb r6:c1044d74 r5:ffffffed [ 4.077717] r4:eeac7a10 [ 4.080263] [<c0625a18>] (platform_drv_probe) from [<c0623e28>] (driver_probe_device+0x230/0x2d0) [ 4.089169] r7:00000000 r6:00000000 r5:c108f624 r4:eeac7a10 [ 4.094853] [<c0623bf8>] (driver_probe_device) from [<c0623f88>] (__driver_attach+0xc0/0xc4) [ 4.103323] r9:c0e0061c r8:000000b9 r7:00000000 r6:eeac7a44 r5:c1044d74 r4:eeac7a10 [ 4.111101] [<c0623ec8>] (__driver_attach) from [<c0622100>] (bus_for_each_dev+0x70/0xa4) [ 4.119312] r7:00000000 r6:c0623ec8 r5:c1044d74 r4:00000000 [ 4.124995] [<c0622090>] (bus_for_each_dev) from [<c06237c0>] (driver_attach+0x24/0x28) [ 4.133028] r6:c1036108 r5:ee8d8680 r4:c1044d74 [ 4.137665] [<c062379c>] (driver_attach) from [<c06232f8>] (bus_add_driver+0x110/0x21c) [ 4.145704] [<c06231e8>] (bus_add_driver) from [<c0624910>] (driver_register+0x80/0xfc) [ 4.153740] r7:c0e48834 r6:c0e58ad0 r5:ffffe000 r4:c1044d74 [ 4.159420] [<c0624890>] (driver_register) from [<c06259cc>] (__platform_driver_register+0x48/0x50) [ 4.168500] r5:ffffe000 r4:c1036108 [ 4.172092] [<c0625984>] (__platform_driver_register) from [<c0e36f7c>] (davinci_mcasp_driver_init+0x1c/0x20) [ 4.182043] r5:ffffe000 r4:c0e36f60 [ 4.185631] [<c0e36f60>] (davinci_mcasp_driver_init) from [<c02017bc>] (do_one_initcall+0x4c/0x178) [ 4.194719] [<c0201770>] (do_one_initcall) from [<c0e00f64>] (kernel_init_freeable+0x1d8/0x268) [ 4.203453] r10:00000007 r9:c0e0061c r8:000000b9 r7:c0e48834 r6:c0e58ad0 r5:c1050000 [ 4.211312] r4:c1050000 [ 4.213859] [<c0e00d8c>] (kernel_init_freeable) from [<c08c7158>] (kernel_init+0x10/0x110) [ 4.215596] mmc0: host does not support reading read-only switch, assuming write-enable [ 4.217379] mmc0: new high speed SDHC card at address 0001 [ 4.235687] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c08c7148 [ 4.243546] r4:00000000 [ 4.246093] [<c08c7148>] (kernel_init) from [<c0207c88>] (ret_from_fork+0x14/0x2c) [ 4.253692] r5:c08c7148 r4:00000000 [ 4.257281] Code: e1a04000 0a00000a f57ff05b e28030d8 (f593f000) [ 4.263403] ---[ end trace bdea3cd7e1ac962b ]--- [ 4.268110] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 4.268110] [ 4.268118] mmcblk0: mmc0:0001 BB1QT 29.8 GiB [ 4.281738] CPU0: stopping [ 4.284457] CPU: 0 PID: 4 Comm: kworker/0:0 Tainted: G D W 4.9.41-ge3a80a1c5c #4 [ 4.292838] Hardware name: Generic DRA74X (Flattened Device Tree) [ 4.298956] Workqueue: events_freezable mmc_rescan [ 4.303768] Backtrace: [ 4.306232] [<c020b29c>] (dump_backtrace) from [<c020b558>] (show_stack+0x18/0x1c) [ 4.313830] r7:ee8a3cc0 r6:20000193 r5:00000000 r4:c10225d0 [ 4.319514] [<c020b540>] (show_stack) from [<c04cce80>] (dump_stack+0x8c/0xa0) [ 4.326767] [<c04ccdf4>] (dump_stack) from [<c020e7b8>] (handle_IPI+0x170/0x184) [ 4.334191] r7:ee8a3cc0 r6:00000000 r5:00000000 r4:c0e5cde0 [ 4.339871] [<c020e648>] (handle_IPI) from [<c02014d8>] (gic_handle_irq+0x78/0x7c) [ 4.347470] r7:fa212000 r6:ee8a3cc0 r5:fa21200c r4:c1003424 [ 4.353150] [<c0201460>] (gic_handle_irq) from [<c020c0f8>] (__irq_svc+0x58/0x8c) [ 4.360659] Exception stack(0xee8a3cc0 to 0xee8a3d08) [ 4.365731] 3cc0: c1050268 00000000 bea9ce20 c073b950 c1087120 00001803 040b26af 0ccccb60 [ 4.373939] 3ce0: c0c16360 00000001 00000034 ee8a3d1c ee8a3d20 ee8a3d10 c020f20c c073b960 [ 4.382146] 3d00: a0000013 ffffffff [ 4.385646] r9:ee8a2000 r8:c0c16360 r7:ee8a3cf4 r6:ffffffff r5:a0000013 r4:c073b960 [ 4.393425] [<c073b950>] (arch_counter_get_cntpct) from [<c020f20c>] (arch_timer_read_counter_long+0x1c/0x20) [ 4.403379] [<c020f1f0>] (arch_timer_read_counter_long) from [<c04cabfc>] (__timer_delay+0x50/0x60) [ 4.412463] [<c04cabac>] (__timer_delay) from [<c04cac34>] (__timer_const_udelay+0x28/0x2c) [ 4.420846] r7:0ccccb60 r6:ee8a3dc4 r5:00000195 r4:ee05f000 [ 4.426527] [<c04cac0c>] (__timer_const_udelay) from [<c071b21c>] (__mmc_start_request+0x90/0xe8) [ 4.435435] [<c071b18c>] (__mmc_start_request) from [<c071b36c>] (mmc_start_request+0xf8/0x120) [ 4.444167] r9:00000001 r8:00000000 r7:00000000 r6:ee05f000 r5:ee05f000 r4:ee8a3dc4 [ 4.451941] [<c071b274>] (mmc_start_request) from [<c071b970>] (mmc_wait_for_req+0x8c/0xf4) [ 4.460323] r5:ee8a3de4 r4:ee8a3dc4 [ 4.463911] [<c071b8e4>] (mmc_wait_for_req) from [<c071ba38>] (mmc_wait_for_cmd+0x60/0x80) [ 4.472207] r7:ee05f000 r6:00000000 r5:ee05f000 r4:ee8a3e24 [ 4.477889] [<c071b9d8>] (mmc_wait_for_cmd) from [<c0726ab8>] (mmc_io_rw_direct_host+0x98/0x12c) [ 4.486708] r6:ee8a3e97 r5:00000c00 r4:00000c00 [ 4.491343] [<c0726a20>] (mmc_io_rw_direct_host) from [<c0726f6c>] (sdio_reset+0x2c/0x64) [ 4.499553] r10:ee85cb80 r9:00000000 r8:c0a64728 r7:c0a6471c r6:ee05f000 r5:00061a80 [ 4.507413] r4:ee05f000 [ 4.509953] [<c0726f40>] (sdio_reset) from [<c071e370>] (mmc_rescan+0x33c/0x380) [ 4.517375] r4:ee05f26c [ 4.519918] [<c071e034>] (mmc_rescan) from [<c0244d84>] (process_one_work+0x1dc/0x3f8) [ 4.527867] r9:00000000 r8:eed3e000 r7:00000000 r6:eed3a600 r5:ee85cb80 r4:ee05f26c [ 4.535640] [<c0244ba8>] (process_one_work) from [<c02459dc>] (worker_thread+0x58/0x574) [ 4.543763] r10:ee85cb80 r9:ee8a2000 r8:eed3a618 r7:c1002d00 r6:00000008 r5:ee85cb98 [ 4.551620] r4:eed3a600 [ 4.554161] [<c0245984>] (worker_thread) from [<c024ad14>] (kthread+0x100/0x118) [ 4.561587] r10:00000000 r9:00000000 r8:c0245984 r7:ee85cb80 r6:ee8a2000 r5:ee862240 [ 4.569445] r4:00000000 [ 4.571989] [<c024ac14>] (kthread) from [<c0207c88>] (ret_from_fork+0x14/0x2c) [ 4.579237] r8:00000000 r7:00000000 r6:00000000 r5:c024ac14 r4:ee862240 [ 4.585968] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 4.585968] [ 4.595961] ------------[ cut here ]------------ [ 4.600600] WARNING: CPU: 1 PID: 18 at kernel/workqueue.c:855 wq_worker_waking_up+0x80/0x88 [ 4.608980] Modules linked in: [ 4.612050] CPU: 1 PID: 18 Comm: kdevtmpfs Tainted: G D W 4.9.41-ge3a80a1c5c #4 [ 4.620346] Hardware name: Generic DRA74X (Flattened Device Tree) [ 4.626459] Backtrace: [ 4.628920] [<c020b29c>] (dump_backtrace) from [<c020b558>] (show_stack+0x18/0x1c) [ 4.636520] r7:00000009 r6:60000193 r5:00000000 r4:c10225d0 [ 4.642202] [<c020b540>] (show_stack) from [<c04cce80>] (dump_stack+0x8c/0xa0) [ 4.649452] [<c04ccdf4>] (dump_stack) from [<c022e3e8>] (__warn+0xec/0x104) [ 4.656441] r7:00000009 r6:c0b9c080 r5:00000000 r4:00000000 [ 4.662123] [<c022e2fc>] (__warn) from [<c022e4b8>] (warn_slowpath_null+0x28/0x30) [ 4.669723] r9:eed47a80 r8:00000001 r7:00000004 r6:00000004 r5:00000001 r4:eea3d300 [ 4.677496] [<c022e490>] (warn_slowpath_null) from [<c0245f78>] (wq_worker_waking_up+0x80/0x88) [ 4.686233] [<c0245ef8>] (wq_worker_waking_up) from [<c02525c4>] (ttwu_do_activate+0x5c/0x70) [ 4.694789] r5:eed47a80 r4:eea58000 [ 4.698379] [<c0252568>] (ttwu_do_activate) from [<c0254240>] (try_to_wake_up+0x19c/0x2b0) [ 4.706673] r7:00000004 r6:20000193 r5:eea584e0 r4:eea58000 [ 4.712356] [<c02540a4>] (try_to_wake_up) from [<c0254424>] (default_wake_function+0x14/0x18) [ 4.720915] r10:00000003 r9:00000000 r8:00000000 r7:eea53be0 r6:00000001 r5:c0254410 [ 4.728772] r4:eea53bd4 [ 4.731315] [<c0254410>] (default_wake_function) from [<c026dbf8>] (__wake_up_common+0x58/0x94) [ 4.740048] [<c026dba0>] (__wake_up_common) from [<c026dca4>] (__wake_up_locked+0x1c/0x24) [ 4.748344] r10:ee8da000 r9:eea53bd4 r8:ee38ec68 r7:ee43b5d8 r6:60000113 r5:eea53bd8 [ 4.756203] r4:eea53bdc [ 4.758744] [<c026dc88>] (__wake_up_locked) from [<c026e634>] (complete+0x3c/0x4c) [ 4.766346] [<c026e5f8>] (complete) from [<c062aa90>] (devtmpfsd+0x124/0x310) [ 4.773509] r7:ee43b5d8 r6:00000000 r5:00006180 r4:00000000 [ 4.779193] [<c062a96c>] (devtmpfsd) from [<c024ad14>] (kthread+0x100/0x118) [ 4.786268] r10:00000000 r9:00000000 r8:c062a96c r7:ee87bf24 r6:ee8d4000 r5:ee862900 [ 4.794124] r4:00000000 [ 4.796667] [<c024ac14>] (kthread) from [<c0207c88>] (ret_from_fork+0x14/0x2c) [ 4.803917] r8:00000000 r7:00000000 r6:00000000 r5:c024ac14 r4:ee862900 [ 4.810641] ---[ end trace bdea3cd7e1ac962c ]--- [ 4.815414] ------------[ cut here ]------------ [ 4.820053] WARNING: CPU: 1 PID: 20 at kernel/workqueue.c:890 wq_worker_sleeping+0xd0/0xd8 [ 4.828346] Modules linked in: [ 4.831417] CPU: 1 PID: 20 Comm: kworker/0:1 Tainted: G D W 4.9.41-ge3a80a1c5c #4 [ 4.839887] Hardware name: Generic DRA74X (Flattened Device Tree) [ 4.846005] Workqueue: events_freezable mmc_rescan [ 4.850818] Backtrace: [ 4.853279] [<c020b29c>] (dump_backtrace) from [<c020b558>] (show_stack+0x18/0x1c) [ 4.860879] r7:00000009 r6:60000193 r5:00000000 r4:c10225d0 [ 4.866560] [<c020b540>] (show_stack) from [<c04cce80>] (dump_stack+0x8c/0xa0) [ 4.873810] [<c04ccdf4>] (dump_stack) from [<c022e3e8>] (__warn+0xec/0x104) [ 4.880797] r7:00000009 r6:c0b9c080 r5:00000000 r4:00000000 [ 4.886478] [<c022e2fc>] (__warn) from [<c022e4b8>] (warn_slowpath_null+0x28/0x30) [ 4.894075] r9:eed47a80 r8:eea58408 r7:c1003234 r6:c0e5da80 r5:eea58000 r4:00000000 [ 4.901851] [<c022e490>] (warn_slowpath_null) from [<c0246050>] (wq_worker_sleeping+0xd0/0xd8) [ 4.910500] [<c0245f80>] (wq_worker_sleeping) from [<c08c81bc>] (__schedule+0x470/0x63c) [ 4.918620] r5:eea58000 r4:eed47a80 [ 4.922207] [<c08c7d4c>] (__schedule) from [<c08c83dc>] (schedule+0x54/0xb8) [ 4.929284] r10:00000000 r9:c104cf00 r8:c08c8cc0 r7:7fffffff r6:00000000 r5:eed47fa0 [ 4.937141] r4:eea52000 [ 4.939685] [<c08c8388>] (schedule) from [<c08cb3e0>] (schedule_timeout+0x1d0/0x218) [ 4.947458] r5:eed47fa0 r4:7fffffff [ 4.951045] [<c08cb210>] (schedule_timeout) from [<c08c7d14>] (io_schedule_timeout+0x7c/0xb4) [ 4.959603] r9:c104cf00 r8:c08c8cc0 r7:7fffffff r6:00000000 r5:eed47fa0 r4:eed47a80 [ 4.967381] [<c08c7c98>] (io_schedule_timeout) from [<c08c8cd8>] (bit_wait_io+0x18/0x64) [ 4.975501] r7:c10027c0 r6:eea53924 r5:00000002 r4:00000002 [ 4.981180] [<c08c8cc0>] (bit_wait_io) from [<c08c892c>] (__wait_on_bit+0x88/0xc0) [ 4.988776] r5:00000002 r4:eea53918 [ 4.992369] [<c08c88a4>] (__wait_on_bit) from [<c02d61dc>] (wait_on_page_bit+0xa0/0xa8) [ 5.000402] r9:c104cf00 r8:00000000 r7:c03667fc r6:ee474174 r5:ef42e250 r4:00000000 [ 5.008178] [<c02d613c>] (wait_on_page_bit) from [<c02d6d2c>] (do_read_cache_page+0x20c/0x330) [ 5.016820] r5:00000000 r4:ef42e250 [ 5.020411] [<c02d6b20>] (do_read_cache_page) from [<c02d6e6c>] (read_cache_page+0x1c/0x24) [ 5.028794] r10:00000000 r9:ee38ec00 r8:ee3e2600 r7:00000000 r6:00000001 r5:ee474000 [ 5.036653] r4:00000000 r3:00000000 [ 5.040242] [<c02d6e50>] (read_cache_page) from [<c04bb68c>] (read_dev_sector+0x30/0xb8) [ 5.048365] [<c04bb65c>] (read_dev_sector) from [<c04bec78>] (read_lba+0x128/0x1b4) [ 5.056048] r5:ee474000 r4:00000200 [ 5.059636] [<c04beb50>] (read_lba) from [<c04bf05c>] (efi_partition+0xd4/0x984) [ 5.067058] r10:00000000 r9:00000200 r8:ee3e2600 r7:00000000 r6:ee8da780 r5:00000000 [ 5.074917] r4:c1086fe4 [ 5.077459] [<c04bef88>] (efi_partition) from [<c04bdc1c>] (check_partition+0x128/0x1f4) [ 5.085580] r10:00000000 r9:00000001 r8:ee474000 r7:00000000 r6:c0a22560 r5:c04bef88 [ 5.093438] r4:ee8da780 [ 5.095978] [<c04bdaf4>] (check_partition) from [<c04bbd80>] (rescan_partitions+0xbc/0x2e8) [ 5.104361] r9:00000001 r8:00000000 r7:ee474010 r6:00000000 r5:ee38ec00 r4:ee474000 [ 5.112139] [<c04bbcc4>] (rescan_partitions) from [<c03671bc>] (__blkdev_get+0x290/0x3c4) [ 5.120346] r10:00000000 r9:00000001 r8:00000000 r7:ee474010 r6:00000000 r5:ee38ec00 [ 5.128205] r4:ee474000 [ 5.130746] [<c0366f2c>] (__blkdev_get) from [<c0367f98>] (blkdev_get+0x114/0x354) [ 5.138344] r10:ee474000 r9:ee3ec000 r8:ee38ec0c r7:00000001 r6:00000000 r5:ee474000 [ 5.146203] r4:00000000 [ 5.148747] [<c0367e84>] (blkdev_get) from [<c04b978c>] (device_add_disk+0x338/0x448) [ 5.156606] r10:ee474000 r9:ee3ec000 r8:ee38ec0c r7:00000001 r6:ee38ec70 r5:00000000 [ 5.164462] r4:ee38ec00 [ 5.167006] [<c04b9454>] (device_add_disk) from [<c072b684>] (mmc_add_disk+0x24/0x104) [ 5.174952] r10:c1041fec r9:00000000 r8:ee38e800 r7:ee05f800 r6:ee38eac0 r5:00000001 [ 5.182812] r4:ee38e800 [ 5.185355] [<c072b660>] (mmc_add_disk) from [<c072c434>] (mmc_blk_probe+0x224/0x2e8) [ 5.193213] r7:ee05f800 r6:00000000 r5:00000001 r4:eea53cf4 [ 5.198896] [<c072c210>] (mmc_blk_probe) from [<c071e67c>] (mmc_bus_probe+0x1c/0x20) [ 5.206667] r10:c1041fec r9:00000000 r8:c10422d8 r7:00000000 r6:00000000 r5:c108f624 [ 5.214524] r4:ee05f808 [ 5.217067] [<c071e660>] (mmc_bus_probe) from [<c0623e28>] (driver_probe_device+0x230/0x2d0) [ 5.225540] [<c0623bf8>] (driver_probe_device) from [<c062402c>] (__device_attach_driver+0xa0/0xd4) [ 5.234620] r9:00000000 r8:c108f600 r7:00000001 r6:ee05f808 r5:eea53db8 r4:c10422d8 [ 5.242395] [<c0623f8c>] (__device_attach_driver) from [<c06221c0>] (bus_for_each_drv+0x68/0x9c) [ 5.251213] r7:00000001 r6:c0623f8c r5:eea53db8 r4:00000000 [ 5.256896] [<c0622158>] (bus_for_each_drv) from [<c0623ad4>] (__device_attach+0xb8/0x11c) [ 5.265193] r6:c1041d94 r5:ee05f83c r4:ee05f808 [ 5.269827] [<c0623a1c>] (__device_attach) from [<c06240ac>] (device_initial_probe+0x14/0x18) [ 5.278384] r7:00000000 r6:c1041d94 r5:ee05f808 r4:ee05f810 [ 5.284067] [<c0624098>] (device_initial_probe) from [<c06230d4>] (bus_probe_device+0x8c/0x94) [ 5.292714] [<c0623048>] (bus_probe_device) from [<c0621244>] (device_add+0x3fc/0x588) [ 5.300660] r7:00000000 r6:ee05f808 r5:ee05e808 r4:ee05f810 [ 5.306344] [<c0620e48>] (device_add) from [<c071eb50>] (mmc_add_card+0x120/0x2e0) [ 5.313942] r10:eea3d300 r9:00000000 r8:c0ba6450 r7:00000001 r6:c0ba6450 r5:ee05f808 [ 5.321801] r4:ee05f800 [ 5.324345] [<c071ea30>] (mmc_add_card) from [<c0724c6c>] (mmc_attach_sd+0xa4/0x14c) [ 5.332117] r8:c0a64728 r7:c0a6471c r6:ee05e800 r5:00000000 r4:ee05e800 [ 5.338844] [<c0724bc8>] (mmc_attach_sd) from [<c071e358>] (mmc_rescan+0x324/0x380) [ 5.346527] r5:00061a80 r4:ee05ea6c [ 5.350115] [<c071e034>] (mmc_rescan) from [<c0244d84>] (process_one_work+0x1dc/0x3f8) [ 5.358061] r9:00000000 r8:eed3e000 r7:00000000 r6:eed3a600 r5:eea3d300 r4:ee05ea6c [ 5.365834] [<c0244ba8>] (process_one_work) from [<c02459dc>] (worker_thread+0x58/0x574) [ 5.373955] r10:eea3d300 r9:eea52000 r8:eed3a618 r7:c1002d00 r6:00000008 r5:eea3d318 [ 5.381813] r4:eed3a600 [ 5.384354] [<c0245984>] (worker_thread) from [<c024ad14>] (kthread+0x100/0x118) [ 5.391778] r10:00000000 r9:00000000 r8:c0245984 r7:eea3d300 r6:eea52000 r5:eea396c0 [ 5.399635] r4:00000000 [ 5.402175] [<c024ac14>] (kthread) from [<c0207c88>] (ret_from_fork+0x14/0x2c) [ 5.409423] r8:00000000 r7:00000000 r6:00000000 r5:c024ac14 r4:eea396c0 [ 5.416149] ---[ end trace bdea3cd7e1ac962d ]---
