IPNC DM365 V2.0.0 build Error
when i  run "IPNC Application Build Procedure", In /IPNC dir, type "make sysall" commond, the Error is this:
alg_vidEnc.c: In function ‘ALG_vidEncCreate’:
alg_vidEnc.c:156: error: ‘IH264VENC_Params’ has no member named ‘sliceMode’
alg_vidEnc.c:157: error: ‘IH264VENC_Params’ has no member named ‘outputDataMode’
alg_vidEnc.c:157: error: ‘IH264VENC_TI_ENTIREFRAME’ undeclared (first use in this function)
alg_vidEnc.c:157: error: (Each undeclared identifier is reported only once
alg_vidEnc.c:157: error: for each function it appears in.)
alg_vidEnc.c:158: error: ‘IH264VENC_Params’ has no member named ‘sliceFormat’
alg_vidEnc.c:158: error: ‘IH264VENC_TI_BYTESTREAM’ undeclared (first use in this function)
alg_vidEnc.c: In function ‘ALG_vidEncSetDynamicParams’:
alg_vidEnc.c:254: error: ‘IH264VENC_DynamicParams’ has no member named ‘rcQMinI’
alg_vidEnc.c:255: error: ‘IH264VENC_DynamicParams’ has no member named ‘rcQMaxI’
alg_vidEnc.c:260: error: ‘IH264VENC_DynamicParams’ has no member named ‘disableMVDCostFactor’
alg_vidEnc.c:261: error: ‘IH264VENC_DynamicParams’ has no member named ‘putDataGetSpaceFxn’
alg_vidEnc.c:262: error: ‘IH264VENC_DynamicParams’ has no member named ‘dataSyncHandle’
alg_vidEnc.c: In function ‘ALG_vidEncRun’:
alg_vidEnc.c:631: warning: pointer targets in passing argument 2 of ‘OSA_fileWriteVideoData’ differ in signedness
alg_vidEnc.c:631: warning: pointer targets in passing argument 3 of ‘OSA_fileWriteVideoData’ differ in signedness
alg_vidEnc.c:638: warning: dereferencing type-punned pointer will break strict-aliasing rules
alg_vidEnc.c:648: warning: assignment from incompatible pointer type
alg_vidEnc.c:690: error: ‘IH264VENC_InArgs’ has no member named ‘numOutputDataUnits’
alg_vidEnc.c:715: warning: passing argument 4 of ‘VIDENC1_process’ from incompatible pointer type
make[6]: *** [alg_vidEnc.o] Error 1
make[6]: Leaving directory `/opt/ipnc/av_capture/framework/alg/src'
make[5]: *** [xdc] Error 2
make[5]: Leaving directory `/opt/ipnc/av_capture/framework/alg/src'
make[4]: *** [libs] Error 2
make[4]: Leaving directory `/opt/ipnc/av_capture/framework'
make[3]: *** [libs] Error 2
make[3]: Leaving directory `/opt/ipnc'
make[2]: *** [exe] Error 2
make[2]: Leaving directory `/opt/ipnc'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/opt/ipnc'
make: *** [sysall] Error 2
    Looks like your codec libraries dont exist in the correct path or it did not get build through the XDC tools. Can you please provide the complete build log point the exact error?
    Regards.
    Anshuman
    PS: Please mark the post as verified, if you think it has answered your question. Thanks.
  • Thanks for the detailed reply by Anshuman. I re-installed the DVSDK_2_10_01_18, in / IPNC directory, run make sysall instruction, the error is as follows:
    ======== Building alg_config ======== Configuring application using alg_server.cfg XDCPATH="/opt/dvsdk_2_10_01_18/codec_engine_2_24/examples;/opt/dvsdk_2_10_01_18/dm365_codecs_01_00_06/packages;/opt/dvsdk_2_10_01_18/codec_engine_2_24/packages;/opt/dvsdk_2_10_01_18/xdais_6_24/packages;/opt/dvsdk_2_10_01_18/framework_components_2_25_00_04/packages;/opt/dvsdk_2_10_01_18/edma3_lld_1_06_00_01/packages;/opt/dvsdk_2_10_01_18/linuxutils_2_24_03/packages" /opt/dvsdk_2_10_01_18/xdctools_3_15_01_59/xs xdc.tools.configuro -c /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le -o alg_config -t gnu.targets.MVArm9 -p ti.platforms.evmDM365 alg_server.cfg making package.mak (because of package.bld) ... generating interfaces for package alg_config (because package/package.xdc.inc is older than package.xdc) ... configuring alg_server.x470MV from package/cfg/alg_server_x470MV.cfg ... js: "/opt/ipnc/av_capture/framework/alg/src/alg_server.cfg", line 74: xdc.services.global.XDCException: xdc.PACKAGE_NOT_FOUND: can't locate the package 'ti.sdo.codecs.iprun.ce' along the path: '/opt/dvsdk_2_10_01_18/codec_engine_2_24/examples;/opt/dvsdk_2_10_01_18/dm365_codecs_01_00_06/packages;/opt/dvsdk_2_10_01_18/codec_engine_2_24/packages;/opt/dvsdk_2_10_01_18/xdais_6_24/packages;/opt/dvsdk_2_10_01_18/framework_components_2_25_00_04/packages;/opt/dvsdk_2_10_01_18/edma3_lld_1_06_00_01/packages;/opt/dvsdk_2_10_01_18/linuxutils_2_24_03/packages;/opt/dvsdk_2_10_01_18/xdctools_3_15_01_59/packages;..;'. Ensure that the package path is set correctly. "./package/cfg/alg_server_x470MV.cfg", line 474 "./package/cfg/alg_server_x470MV.cfg", line 429 gmake: *** [package/cfg/alg_server_x470MV.c]
     Error 1 js: "/opt/dvsdk_2_10_01_18/xdctools_3_15_01_59/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
    make[6]: *** [alg_config] Error 1 make[6]: Leaving directory `/opt/ipnc/av_capture/framework/alg/src' make[5]: *** [xdc] Error 2 make[5]: Leaving directory `/opt/ipnc/av_capture/framework/alg/src' make[4]: *** [libs] Error 2 make[4]: Leaving directory `/opt/ipnc/av_capture/framework' make[3]: *** [libs] Error 2 make[3]: Leaving directory `/opt/ipnc' make[2]: *** [exe] Error 2 make[2]: Leaving directory `/opt/ipnc' make[1]: *** [all] Error 2 make[1]: Leaving directory `/opt/ipnc' make: *** [sysall] Error 2
  • In /opt/ipnc ,the rules.make file is this:
    # This make variable must be set before the demos or examples
    # can be built.  It must be set to either dm355 or dm6446
    MVTOOL_DIR := /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le
    BASE_HOME := /opt
    HOME := $(BASE_HOME)/ipnc
    DVSDK_BASE_DIR := $(BASE_HOME)/dvsdk_2_10_01_18
    TARGET_FS := $(HOME)/target/filesys
    KERNELDIR := $(HOME)/ti-davinci
    BASE_DIR := $(HOME)/av_capture/build
    TFTP_HOME := $(HOME)/tftp
    #SYSTEM := DVR
    #SYSTEM := EVM
    SYSTEM := IPNC
    HARDWARE :=DM365
    #HARDWARE :=DM368
    CONFIG :=
    include $(DVSDK_BASE_DIR)/Rules.make
    # Where to copy the resulting executables and data to (when executing 'make
    # install') in a proper file structure. This EXEC_DIR should either be visible
    # from the target, or you will have to copy this (whole) directory onto the
    # target filesystem.
    EXEC_DIR=$(TARGET_FS)/opt/ipnc
    # The directory that points to the IPNC software package
    IPNC_DIR=$(HOME)/ipnc_app
    # The directory to application interface
    IPNC_INTERFACE_DIR=$(IPNC_DIR)/interface
    # The directory to application interface include files
    PUBLIC_INCLUDE_DIR=$(IPNC_INTERFACE_DIR)/inc
    # The directory to application interface library files
    APP_LIB_DIR=$(IPNC_INTERFACE_DIR)/lib
    # The directory to root file system
    ROOT_FILE_SYS = $(TARGET_FS)
    AEWB_LIBS :=
    ifeq ($(SYSTEM), DVR)
    BOARD_ID := BOARD_UD_DVR
    IMGS_ID := IMGS_NONE
    TARGET_FS_DIR := $(TARGET_FS)/opt/dvr
    AEWB_ID := AEWB_NONE
    endif
    ifeq ($(SYSTEM), IPNC)
    BOARD_ID := BOARD_AP_IPNC
    IMGS_ID := IMGS_MICRON_MT9P031_5MP
    TARGET_FS_DIR := $(TARGET_FS)/opt/ipnc
    AEWB_ID := AEWB_ENABLE
    endif
    ifeq ($(SYSTEM), EVM)
    BOARD_ID := BOARD_TI_EVM
    endif
    export IPNC_DIR
    export PUBLIC_INCLUDE_DIR
    export APP_LIB_DIR
    export TARGET_FS
    export SYSTEM
    export LINUXKERNEL_INSTALL_DIR
    export EXEC_DIR
    export TARGET_FS_DIR
    export KERNELDIR
    export BASE_DIR
    export CONFIG
    export DVSDK_BASE_DIR
    export CMEM_INSTALL_DIR
    export MVTOOL_PREFIX
    export IMGS_ID
    export BOARD_ID
    export DVSDK_DEMOS_DIR
    export AEWB_ID
    export AEWB_LIBS
    export MVTOOL_DIR
    Thanks for reply.
  • Thanks Anshuman's coaching. The reason is not my DVSDK installed version, right now, thank you!
    f hs
    I have the same error!
    Reading the previous posts isn't clear, which is the solution?
    regards
  • I found, I used the dvsdk and xdctools downloaded from here which versions are the same of the dvsdk inside IPNC 2.0 pakage ... but the xdctools content is not the same
    with IPNC 2.0 dvsdk I can compile without errors
    regards
  • I assume you are using the DVSDK that comes with IPNC release ver 2.0
    If you are still facing problem, please share the alg_server.cfg file
    Anshuman
    PS: Please mark this post as verified, if you think it has answered your question. Thanks.
  • I have the same error,too!
    This is my alg_server.cfg
    Please help me!!
    var osalGlobal = xdc.useModule('ti.sdo.ce.osal.Global');
    osalGlobal.runtimeEnv = osalGlobal.LINUX;
    environment['xdc.cfg.check.fatal'] = 'false';
    var RMAN = xdc.useModule('ti.sdo.fc.rman.RMAN');
    RMAN.useDSKT2 = false;
    RMAN.persistentAllocFxn = "__ALG_allocMemory";
    RMAN.persistentFreeFxn = "__ALG_freeMemory";
    RMAN.semCreateFxn = "Sem_create";
    RMAN.semDeleteFxn = "Sem_delete";
    RMAN.semPendFxn = "Sem_pend";
    RMAN.semPostFxn = "Sem_post";
    RMAN.tableSize = 10;
    RMAN.trace = true;
    RMAN.debug = true;
    var EDMA3 = xdc.useModule('ti.sdo.fc.edma3.Settings');
    EDMA3.globalInit = true;
    EDMA3.maxQdmaChannels = [10,10,10,10];
    EDMA3.trace = false;
    EDMA3.debug = false;
    EDMA3.maxRequests = 128;
    var vicp = xdc.useModule('ti.sdo.linuxutils.vicp.VICP');
    vicp.debug = false;
    var HDVICP = xdc.useModule('ti.sdo.fc.ires.hdvicp.HDVICP');
    HDVICP.trace = false;
    HDVICP.debug = false;
    //Change this to VICP if the chip is not DM355
    var VICP = xdc.useModule('ti.sdo.fc.ires.vicp.VICP2');
    VICP.debug = true;
    var VICPSYNC = xdc.useModule('ti.sdo.fc.vicpsync.VICPSYNC');
    VICPSYNC.debug = false;
    var HDVICPSYNC = xdc.useModule('ti.sdo.fc.hdvicpsync.HDVICPSYNC');
    HDVICPSYNC.debug = false;
    HDVICPSYNC.trace = false;
    var VICP = xdc.useModule('ti.sdo.fc.memutils.MEMUTILS');
    ADDRSPACE = xdc.useModule('ti.sdo.fc.ires.addrspace.ADDRSPACE');
    var MEMTCM = xdc.useModule('ti.sdo.fc.ires.memtcm.MEMTCM');
    MEMTCM.cmemBlockId = 1; //Since we use _1 in our insmod command.
    var EDMA3CHAN = xdc.useModule('ti.sdo.fc.ires.edma3chan.EDMA3CHAN');
    EDMA3CHAN.trace = false;
    EDMA3CHAN.debug = false;
    var LSP = xdc.useModule('ti.sdo.linuxutils.edma.EDMA');
    LSP.debug = false;
    var CMEM = xdc.useModule('ti.sdo.linuxutils.cmem.CMEM');
    var ALG_MEM = xdc.useModule('ti.sdo.ce.alg.Settings');
    ALG_MEM.useHeap = true;
    ALG_MEM.useCache = true;
    xdc.loadPackage("ti.sdo.ce.video2");
    xdc.loadPackage("ti.sdo.fc.hdvicpsync");
     *  ======== Engine Configuration ========
    var KTNF = xdc.useModule('ti.sdo.codecs.ktnf.ce.KTNF');
    var MPEG4ENC = xdc.useModule('ti.sdo.codecs.mpeg4enc.ce.MPEG4ENC');
    var H264ENC = xdc.useModule('ti.sdo.codecs.h264enc.ce.H264ENC');
    var JPEGENC = xdc.useModule('ti.sdo.codecs.jpegenc.ce.JPEGENC');
    var G711ENC = xdc.useModule('ti.sdo.ce.examples.codecs.g711.G711ENC');
    var Engine = xdc.useModule('ti.sdo.ce.Engine');
    var myEngine = Engine.create("alg_server", [
        {name: "g711enc", mod: G711ENC, local: true, groupId: 1},
        {name: "mpeg4enc", mod: MPEG4ENC, local: true, groupId: 1},
        {name: "jpegenc", mod: JPEGENC, local: true, groupId: 1},
        {name: "ktnf", mod: KTNF, local: true, groupId: 2},
        {name: "h264enc", mod: H264ENC, local: true, groupId: 1},
    Program.main = null;
