Linux: Yocto rootfs customization
Hi, all
I build minial rootfs according to https://e2e.ti.com/support/arm/sitara_arm/f/791/t/670081
I want to ask some question:
1.I do not want to use qtwebkit and qtwebengine, and remove them by adding PACKAGECONFIG_remove="qtwebengine qtwebkit", but no use. How to remove?
2.I want to remove other packages that useless in my system, but I do not know how to remove?
3.Is there any tool to config which package to build?
4.The minimal rootfs seems not support opencl, how to add? IMAGE_INSTALL += opencl? PACKAGECONFIG_append="opencl"?
  • Hello jinhu,
    Removing the qtwebengine is precisely explained in this post.
    Please, read this thread.
    Yes, there is a Yocto Toaster.
    IMAGE_INSTALL += " opencl" or IMAGE_INSTALL_append = " opencl"
    Note: Please, watch the Customizing the Yocto Training Series, complete these Getting_Started_with_Openembedded labs and read the Yocto Mega-Manual first. You will most probably find the answers you are looking for in these documents.
    Kemal
  • Thanks to reply.
    yes, I am very new in this field.
    My confusing is How to know the name to config package. ie QT5_ESSENTIALS to "qtwebengine-qmlplugins", using grep?
  • You cannot know that without looking into <tisdk>/sources/meta-arago/meta-arago-distro/recipes-core/packagegroups/packagegroup-arago-qte.bb and see that the qtwebengine-qmlplugins is under control of QT5_ESSENTIALS. Please, learn the usage of grep and regular expressions from here.
