Tool/software: TI-RTOS
Hi everybody ,
I have a customer not able to run PDK compiling examples successfully , we are on two PCs ( win10 , and 7 ) , while same procdeure working on mine .
here is the installation flow we did and as you can see we are in default directories :
1) Install CCS version 8.0.0 in default path as admin
2) Unzip SDK in default path as admin
3) Go to “C:\ti\pdk_am57xx_1_0_8\packages” in a DOS shell as admin
4) Call “pdksetupenv.bat” in a DOS shell as admin ( see in attach PATH result )
5) Call “gmake clean” in a DOS shell as admin. SUCCESS
6) Call “gmake all” in a DOS shell as admin. SUCCESS
now I am using this command as admin : pdkProjectCreate.bat AM572x idkAM572x little
( This command is working fine on 2 of my pcs , but not on customer )
The log in is my PS and is true on all examples : Where am I wrong ?
thank you
regards
Carlo
here is the log :
c:\ti\PDK_AM~1\packages>pdkProjectCreate.bat AM572x idkAM572x little
Configuration:
SOC : AM572x
BOARD : idkAM572x
ENDIAN : little
MODULE : all
PROJECT_TYPE : all
PROCESSOR : arm
PDK_SHORT_NAME : c:\ti\PDK_AM~1\packages\
Checking Configuration...
Complete
PDK_PARTNO : AM572X
PDK_ECLIPSE_ID : com.ti.pdk.am57xx
RTSC_PLATFORM_NAME : ti.platforms.idkAM572X
RTSC_TARGET : gnu.targets.arm.A15F
CCS_DEVICE : "Cortex A.AM5728_RevA"
Detecting all projects in PDK and importing them in the workspace c:\ti\PDK_AM~1
\packages\\MyExampleProjects
Detected Test Project: EMAC_BasicExample_idkAM572x_armBiosExampleProject
The system cannot find the path specified.
Copying macro.ini
0 file(s) copied.
Detected Test Project: GPIO_LedBlink_idkAM572x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: I2C_BasicExample_callback_mode_idkAM572x_armExampleProjec
t
Copying macro.ini
0 file(s) copied.
Detected Test Project: I2C_BasicExample_idkAM572x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: I2C_BasicExample_idkAM572x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: I2C_Master_idkAM572x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: I2C_Slave_idkAM572x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: ICSS_EMAC_BasicExamplePoll_idkAM572x_wSoCLib_armTestproje
ct
Copying macro.ini
0 file(s) copied.
Detected Test Project: ICSS_EMAC_BasicExample_idkAM572x_wSoCFile_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: ICSS_EMAC_BasicExample_idkAM572x_wSoCLib_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: ICSS_EMAC_SwitchExample_idkAM572x_wSoCFile_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: ICSS_EMAC_SwitchExample_idkAM572x_wSoCLib_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_FatfsConsole_idkAM572x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_FatfsConsole_idkAM572x_DMA_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_idkAM572x_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_idkAM572x_DMA_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_idkAM572x_EMMC_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_idkAM572x_EMMC_DMA_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: PCIE_idkAM572x_wSoCFile_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: PCIE_idkAM572x_wSoCLib_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: PRUSS_BasicExample_idkAM572x_wSoCFile_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: PRUSS_BasicExample_idkAM572x_wSoCLib_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_BasicExample_idkAM572x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_SlaveMode_MasterExample_idkAM572x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_SlaveMode_SlaveExample_idkAM572x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: QSPI_BasicExample_idkAM572x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_BasicExample_Dma_idkAM572x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_BasicExample_idkAM572x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: QSPI_BasicExample_idkAM572x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: UART_BasicExample_idkAM572x_armExampleProject
