RTOS/AM5728: Automated firmware testing
Hi Rahul,
I got files. Thank a lot.
I read that DFU requires target USB port configuration.
So the question now "Will DFU work with Industrial IDK?!" www.ti.com/.../sprw282a.pdf
The DFU/FW download requirement that we are discussing is for automating system testing during development or for production environment. We need any simple way to download test firmware to a EVB and then to the target board. It is OK to modify hardware and change boot options if required.
I'd like to go the same way as your system team, JTAG, UART or USB. Everything that can workout, even if it not optimal.
Rasty
  • Rasty,
    I split the thread from the DFU related thread to discuss test automation as we discussed offline.
    We have a couple of methods that our system test team deploys to automate SDK test:
    Automate loading code over JTAG:  The CCS package supports debug server scripting that allows you to load binaries and test the code in an automated way. The CCS installation comes with some examples but we can check with system test team if they can provide some reference scripts. Details and examples of debug scripting is provided in the article Debug Server scripting
    http://processors.wiki.ti.com/index.php/Debug_Server_Scripting
    // factory_defaults dss script
    // Import the DSS packages into our namespace to save on typing
    importPackage(Packages.com.ti.debug.engine.scripting);
    importPackage(Packages.com.ti.ccstudio.scripting.environment);
    importPackage(Packages.java.lang);
    importPackage(Packages.java.io);
    importPackage(Packages.java.util);
    // Create our scripting environment object - which is the main entry point into
    // any script and the factory for creating other Scriptable ervers and Sessions
    var script = ScriptingEnvironment.instance()
    var debugScriptEnv = ScriptingEnvironment.instance();
    // program_evm environment.
    testEnv = {};
    // Get the Debug Server and start a Debug Session
    var debugServer = script.getServer("DebugServer.1");
    //***************Functions define***************************
    function isFile(path)
    	try
    		file = new java.io.FileReader(path);
    	catch (ex)
    		return false;
    	return true;
    //****************Get New Time Stamp***********************
    function localTime()
    	// get time stamp
    	var currentTime = new Date();
    	var year = currentTime.getFullYear();
    	var month = currentTime.getMonth() + 1;
    	month = month + "";
    	if (month.length == 1)
    		month = "0" + month;
    	var day = currentTime.getDate();
    	var hour = currentTime.getHours();
    	var minute = currentTime.getMinutes();
    	minute = minute + "";
    	if (minute.length == 1)
    		minute = "0" + minute;
    	var second = currentTime.getSeconds();
    	second = second + "";
    	if (second.length == 1)
    		second = "0" + second;
    	return (year+"_"+month+"_"+day+"_"+hour+minute+second);
     * Get error code from the given exception.
     * @param {exception} The exception from which to get the error code.
    function getErrorCode(exception)
    	var ex2 = exception.javaException;
    	if (ex2 instanceof Packages.com.ti.ccstudio.scripting.environment.ScriptingException) {
    		return ex2.getErrorID();
    	return 0;
    function fileCopy(source,destination)
    	inputFile = new File(source);
        outputFile = new File(destination);
        infile = new  java.io.FileReader(inputFile);
        out = new java.io.FileWriter(outputFile);
        var c;
        while ((c = infile.read()) != -1)
          out.write(c);
        infile.close();
        out.close();
    function pausecomp(millis)
      var date = new Date();
      var curDate = null;
      do { curDate = new Date(); }
      while(curDate-date < millis)
      //print("Waiting "+millis+"ms...\r\n")
    // Declarations and Inititalizations
    var nandwriter_dir    = java.lang.System.getProperty("user.dir");
    var dss_script_dir    = java.lang.System.getenv("DSS_SCRIPT_DIR");
    var host_os           = "";
    var script_logs    = nandwriter_dir+"/logs/";
    var script_configs = nandwriter_dir+"/configs/";
    var script_binaries = "../prebuilt-images/";
    var targetConfig = "";
    var writeAll = false;
    var writerImages = "";
    var big_endian = false;
    var targetFlag = "unknown";
    var targetConfig = "unknown";
    var emul560 = false;
    var xds200 = false;
    var emulation_spec = "onboard XDS100";
    testEnv.cioFile = null;
    if (java.lang.System.getProperty("os.name").match(/Linux/i))
            host_os = "-linuxhost";
    // Parse the arguments
    if (arguments.length > 0 && arguments.length < 3)
        // parse the board spec
        var board_spec = arguments[0].toLowerCase();
        board_spec = board_spec.replace(/^tmd(x|s)/, "");
        board_spec = board_spec.replace(/^evmc/, "evm");
        // find endian, user wants
        if (board_spec.match(/-be$/))
            big_endian = true;
            board_spec = board_spec.replace(/-be$/, "");
        else
            board_spec = board_spec.replace(/-le$/, "");
        // find onboard emulation option for this board
        if (board_spec.match(/lx?e$/))
            emul560 = true;
    	emulation_spec = "XDS560 mezzanine";
            board_spec = board_spec.replace(/e$/, "");
        if (board_spec.match(/ls$/))
            xds200 = true;
    	emulation_spec = "XDS200 emulator";
            board_spec = board_spec.replace(/ls$/, "l");
        if (board_spec.match(/k2h$/) || board_spec.match(/k2e$/) || board_spec.match(/k2l$/) || board_spec.match(/k2g$/))
            emulation_spec = "XDS2xx emulator";
    	// for now, use the same software for lx and l variants
        board_spec = board_spec.replace(/lx$/, "l");
        // for now, treat evm6618l as an alias for evm6670l
        board_spec = board_spec.replace(/evm6618/, "evm6670");
        targetFlag = board_spec;
        endian_spec = (big_endian ? "-be" : "");
        board_binaries = script_binaries;
        targetConfig = java.lang.System.getenv("PROGRAM_EVM_TARGET_CONFIG_FILE");
        if (!targetConfig)
            targetConfig = script_configs + targetFlag + "/" + targetFlag + (emul560 ? "e" : "") + (xds200 ? "s" : "") + host_os + ".ccxml";
        print("board: " + targetFlag);
        print("endian: " + (big_endian ? "Big" : "Little"));
        print("emulation: " + emulation_spec);
        print("binaries: " + board_binaries);
        print("ccxml: " + targetConfig);
        var dir = new File(board_binaries);
        if (!dir.exists())
            print("board binaries directory not found");
            java.lang.System.exit(2);
        if(arguments[1])
            writerImages = arguments[1];
        else
            writeAll = true;
    else
      print("Syntax error in command line");
    	print("Syntax: program_evm.js [tmdx|tmds]evm[c](<device>)l[x][e][-le|-be] [images_to_write]")
    	print("    tmdx: TMDX type EVM")
    	print("    tmds: TMDS type EVM")
    	print("    c: Not used, for backward compatibility")
    	print("    <device> is the board name e.g 6472,6678 etc")
    	print("    l: Low cost EVM")
    	print("    x: EVM supports encryption")
    	print("    e: EVM uses 560 Mezzanine Emulator daughter card")
    	print("    le: Little Endian")
    	print("    be: Big Endian")
    	print("    example: TMDXEVM6678L-le")
    	print("    [images_to_write] OPTIONAL is a list of the images to be written")
    	print("    example: eeprom50,nor")
    	print("    If not specified all (eeprom50,eeprom51,nand,nor) will be written")
    	java.lang.System.exit(0);
    var i2cwriterbinary = board_binaries + "eepromwriter_" + targetFlag + ".out";
    var nandwriterbinary = board_binaries + "nandwriter_" + targetFlag + ".out";
    var norwriterbinary = board_binaries + "norwriter_" + targetFlag + ".out";
    var eepromwriter_input51 = board_binaries + "eepromwriter_input51.txt";
    var eepromwriter_input50 = board_binaries + "eepromwriter_input50.txt";
    var eepromwriter_input = board_binaries + "eepromwriter_input.txt";
    var eeprom50 = board_binaries + "eeprom50.bin";
    var eeprom51 = board_binaries + "eeprom51.bin";
    var nand = board_binaries + "nand.bin";
    var nor = board_binaries + "nor.bin";
    var custom_config = script_configs+targetFlag+"/program_evm_config";
    if (isFile(custom_config))
    	file = new java.io.BufferedReader(new java.io.FileReader(custom_config))
    	while((line = file.readLine()) != null) {
    		params = line.split("\\s+");
    		if (params[1] == undefined) continue;
    		if ("board_binaries" == params[0]) board_binaries = params[1];
    		else if ("norwriterbinary" == params[0]) norwriterbinary = board_binaries + params[1];
    		else if ("nandwriterbinary" == params[0]) nandwriterbinary = board_binaries + params[1];
    		else if ("i2cwriterbinary" == params[0]) i2cwriterbinary = board_binaries + params[1];
    		else if ("nand" == params[0]) nand = board_binaries + params[1];
    		else if ("nor" == params[0]) nor = board_binaries + params[1];
    	file.close();
    // Note: nAddress is the load address for using eepromwriter.
    //       nandNorAddress is the address used for nandwriter and norwriter.
    switch (targetFlag)
    	case "evm6457l":
    		cpu_id = "C64XP_1";
    		var nAddress = 0x800000;
    		var nandNorAddress = nAddress;
    		var iblByteSwap = false;
    		break;
    	case "evm6474l":
    		cpu_id = "C64XP_0";
    		break;
    	case "evm6455":
    		cpu_id = "C64XP_0";
    		break;
    	case "evm6474":
    		cpu_id = "C64XP_1A";
    		break;
    	case "evm6472l":
    		cpu_id = "C64XP_A";
    		break;
    	case "evm6670l":
    		cpu_id = "C66xx_0";
    		var nAddress = 0x0C000000;
    		var nandNorAddress = 0x80000000;
    		break;
    	case "evm6678l":
    		cpu_id = "C66xx_0";
    		break;
    	case "evm6657l":
    		cpu_id = "C66xx_0";
    		break;
    	case "evmk2h":
    		cpu_id = "C66xx_0";
            break;
    	case "evmk2e":
    		cpu_id = "C66xx_0";
            break;
    	case "evmk2l":
    		cpu_id = "C66xx_0";
            break;
    	case "evmk2g":
    		cpu_id = "C66xx_0";
            break;
    	default:
    		script.traceWrite("Could not file cpu id for target " + targetFlag + "\n");
    start = localTime();
    testEnv.cioFile = script_logs+targetFlag+"_"+start+"-cio"+".txt";
    // Create a log file in the current directory to log script execution
    script.traceBegin(script_logs+targetFlag+"_"+start+"-trace"+".txt")
    // Configure target
    debugServer.setConfig(targetConfig);
    pausecomp(1000);
    debugSession = debugServer.openSession("*",cpu_id);
    if (testEnv.cioFile != null)
    	debugSession.beginCIOLogging(testEnv.cioFile);
    pausecomp(1000);
    debugSession.target.connect();
    pausecomp(1000);
    debugSession.target.reset();
    pausecomp(1000);
    //POST
    if(writeAll || writerImages.match(/eeprom50/))
    	//Write EEPROM
    	script.traceWrite("Start writing eeprom50");
    	script.traceWrite("Writer:" + i2cwriterbinary + "\r\n");
    	script.traceWrite("Image:" + eeprom50 + "\r\n");
    	if (isFile(i2cwriterbinary) && isFile(eeprom50))
    		fileCopy(eepromwriter_input50,eepromwriter_input);
    		debugSession.memory.loadProgram(i2cwriterbinary);
    		var nPage = 0x0;
    	//	var nAddress = 0x80000000;
    		var sFilename = eeprom50 ;
    		var nTypeSize = 32;
    		var bByteSwap = false;
    		try
    			debugSession.memory.loadRaw(nPage, nAddress, sFilename, nTypeSize, bByteSwap);
    		catch (ex)
    		   errCode = getErrorCode(ex);
    		   script.traceWrite("Error code #" + errCode + ", could not load file " + sFilename +
    					" to target memory!");
    		debugSession.target.run()
    		end = localTime();
    	else
    		script.traceWrite("Required EEPROM50 files do not exist in " + board_binaries + "\n");
    //IBL
    if(writeAll || writerImages.match(/eeprom51/))
    	script.traceWrite("Start writing eeprom51");
    	script.traceWrite("Image:" + eeprom51 + "\r\n");
    	if (isFile(i2cwriterbinary) && isFile(eeprom51))
    		fileCopy(eepromwriter_input51,eepromwriter_input);
    		var nPage = 0x0;
    		var sFilename = eeprom51;
    		var nTypeSize = 32;
    		var bByteSwap = iblByteSwap;
    		try
    		catch (ex)
    		end = localTime();
    	else
    		script.traceWrite("Required EEPROM51 files do not exist in " + board_binaries + "\n");
    //NAND
    if(writeAll || writerImages.match(/nand/))
        if (writerImages.match(/format/))
           /* No action is taken for NAND since it is format*/
    	else
        	start_nand = localTime();
        	script.traceWrite("Writer:" + nandwriterbinary + "\r\n");
        	script.traceWrite("NAND:" + nand + "\r\n");
        	if (isFile(nand) && isFile(nandwriterbinary))
        		debugSession.memory.loadProgram(nandwriterbinary);
        		var nPage = 0x0;
        		var sFilename = nand;
        		var nTypeSize = 32;
        		try
        			script.traceWrite("Start loading nand.bin");
        			debugSession.memory.loadRaw(nPage, nandNorAddress, sFilename, nTypeSize, bByteSwap);
        		catch (ex)
        		script.traceWrite("Start programming NAND");
        		script.traceWrite("End programming NAND");
        		end_nand = localTime();
        	else
        		script.traceWrite("Required NAND files does not exist in " + board_binaries + "\n");
    //FORMAT the flash
    //NAND Erase all
        if (writerImages.match(/nand/))
        	if (isFile(nandwriterbinary))
        		var nPage = 0x0;
        		var nValue = 0x12345678;
        		try
        			script.traceWrite("Formatting NAND device ... Initiated");
        			// Get the address of that symbol
        			var flag_address = debugSession.symbol.getAddress("nand_erase_flag")
        			debugSession.memory.writeWord(nPage, flag_address, nValue);
        		catch (ex)
        		   script.traceWrite("Error code #" + errCode + ", could not set the nandwriter for erasing all nand blocks! ");
        		script.traceWrite("Formatting NAND device ...Completed");
        	else
        		script.traceWrite("Required NAND binary does not exist in " + board_binaries + "\n");
    	else
    	  /* No action is taken */
    	  script.traceWrite("FLASH FORMAT - No Action is taken, please provide the supported format command string, e.g., format-nand");
        	// Stop CIO logging.
        	debugSession.endCIOLogging();
        debugSession.terminate();
        debugServer.stop()
        // Stop logging and exit.
        script.traceEnd();
    //NOR
    if(writeAll || writerImages.match(/nor/))
    	start_nor = localTime();
    	script.traceWrite("Writer:" + norwriterbinary + "\r\n");
    	script.traceWrite("NOR:" + nor + "\r\n");
    	if (isFile(nor) && isFile(norwriterbinary))
    		debugSession.memory.loadProgram(norwriterbinary);
    		var nPage = 0x0;
    		var sFilename = nor ;
    		var nTypeSize = 32;
    		try
    			script.traceWrite("Start loading nor.bin");
    		catch (ex)
    		script.traceWrite("Start programming NOR");
    		script.traceWrite(localTime());
    		script.traceWrite("End programming NOR");
    		end_nor = localTime();
    	else
    		script.traceWrite("Required NOR files does not exist in " + board_binaries + "\n");
    debugServer.stop()
    script.traceEnd();
    Serial loader or SD card loading: Serial loader loads application over UART on boards that support UART booting. On Sitara boards which support SD card booting, the system test team has a custom muxed SD HW that allows them to load built application binaries from host into SD card and then switch the mux so that target access the files.
    Location in Processor SDK RTOS 5.0:
    pdk_am57xx_1_0_11\packages\ti\board\utils\uartAppLoader
    This has been described here:
    http://software-dl.ti.com/processor-sdk-rtos/esd/docs/latest/rtos/Foundational_Components.html#uart-apploader
    1. Copy PRSDK MLO and uart apploader app to sdcard
    2. Insert sdcard into sd slot of idkAM572x board
    3. Power cycle the board
    4. Transfer application image to be tested over UART using xmodem protocol.
    Example output:
    HW used in test automation:
    Here is a link to the network-enabled power switch we use:
    https://dlidirect.com/products/web-power-switch-7
     Here are API links:  https://www.digital-loggers.com/rest.htmlhttps://www.digital-loggers.com/scripts.html
    Rahul
  • Rasty,
    Examples of debug Server scripting are provided here:
    Load TI utility: http://processors.wiki.ti.com/index.php/Loadti
    Program EVM script : http://processors.wiki.ti.com/index.php/Program_EVM_UG#Sample_DSS_Script_Output
    testEnv = {};
    	try
    	catch (ex)
    		return false;
    	return true;
    	// get time stamp
    	month = month + "";
    	return 0;
        var c;
          out.write(c);
        infile.close();
        out.close();
      var curDate = null;
    var host_os           = "";
    var xds200 = false;
            big_endian = true;
        else
            emul560 = true;
            xds200 = true;
        if (!targetConfig)
        if (!dir.exists())
        if(arguments[1])
        else
            writeAll = true;
    else
    	file.close();
    switch (targetFlag)
    	case "evm6457l":
    		cpu_id = "C64XP_1";
    		break;
    	case "evm6474l":
    		cpu_id = "C64XP_0";
    		break;
    	case "evm6455":
    		cpu_id = "C64XP_0";
    		break;
    	case "evm6474":
    		break;
    	case "evm6472l":
    		cpu_id = "C64XP_A";
    		break;
    	case "evm6670l":
    		cpu_id = "C66xx_0";
    		break;
    	case "evm6678l":
    		cpu_id = "C66xx_0";
    		break;
    	case "evm6657l":
    		cpu_id = "C66xx_0";
    		break;
    	case "evmk2h":
    		cpu_id = "C66xx_0";
            break;
    	case "evmk2e":
    		cpu_id = "C66xx_0";
            break;
    	case "evmk2l":
    		cpu_id = "C66xx_0";
            break;
    	case "evmk2g":
    		cpu_id = "C66xx_0";
            break;
    	default:
    // Configure target
    pausecomp(1000);
    pausecomp(1000);
    pausecomp(1000);
    pausecomp(1000);
    //POST
    	//Write EEPROM
    		var nPage = 0x0;
    		var nTypeSize = 32;
    		try
    		catch (ex)
    		end = localTime();
    	else
    //IBL
    		var nPage = 0x0;
    		var nTypeSize = 32;
    		try
    		catch (ex)
    		end = localTime();
    	else
    //NAND
    	else
        		var nPage = 0x0;
        		var nTypeSize = 32;
        		try
        		catch (ex)
        	else
    //FORMAT the flash
    //NAND Erase all
        		var nPage = 0x0;
        		try
        		catch (ex)
        	else
    	else
        debugServer.stop()
        script.traceEnd();
    //NOR
    		var nPage = 0x0;
    		var nTypeSize = 32;
    		try
    		catch (ex)
    	else
    debugServer.stop()
    script.traceEnd();
    Example output:
    Rahul
