Part Number: TDA2PXEVM
I am trying to boot TDA2px using SD card by following step-by-step instructions mentioned in the ProcessorSDKRadar_UserGuide pdf. However, after i copy MLO and AppImage into SD card (after formatting it to FAT32 allocation with 512 unit size), when I put the SD card into the memory slot and open Teraterm with 115200 baud rate Serial port, I observe that the Tera Term remains blank most of the times. However, if I keep repeating it for few times, it sometimes starts working/ booting up. Do you know what might be the issue here?
Thank you.
Nishant
