66AK2H12: Compatible NAND devices
Part Number: 66AK2H12
We're using the Keystone II 66AK2H12 on a custom board.    For several years, we've successfully been using the MT29F8G08ADBDAH4-IT:D NAND device (8Gb, x8) with the 66AK2H12.     Now this NAND part is  obsolete, and Micron recommended using the  MT29F8G08ABBCAH4-IT:C as a replacement.    However, the newer part has different internal organization --  4k vs 2k page size, 8 vs 4 bit ECC, etc.    Note: it appears that the 66AK2H12 doesn't support 8 bit ECC.  We're currently attempting to use the newer part, but have had to make some uboot, linux kernel changes to get it to work -- disable h/w ECC, and use s/w BCH.
What NAND devices does TI recommend for the 66AK2H12?
There is an automotive grade version of the older part still available,  MT29F8G08ADBDAH4-AAT:D, but it has slightly different specs than the IT version -- It's 'Read page' time is 45 us (AAT) vs 25 us (IT).      Do you think the slower 'read page' time will affect normal operation of the NAND with the Keystone?
thanks for your help,
Scott
