RTOS/AM5728: SMP processing on EtherCAT-Master reference design(TIDEP0079)
Guru 10235 points
Part Number: AM5728
Other Parts Discussed in Thread: TIDEP0079, , SYSBIOS
Tool/software: TI-RTOS
Hello, TI Experts,
Our customer sent us questions about SMP processing on EtherCAT-Master reference design(TIDEP0079).
https://www.ti.com/tool/TIDEP0079
They want to know how to use SMP processing with dual-A15 of AM5728 including the PCIE function and EtherCAT-Master under below tools.
 1:SDK(RTOS) :ti\pdk_am57xx_1_0_9
                                ti\bios_6_52_00_12
 2:CCS:8.2.0.00007
 3:Acontis-EC-Master: 3.0.1.12
But sysbios including SMP function of this SDK seems to still have some problem like the below E2E thread.
https://e2e.ti.com/support/processors/f/791/t/754044#pi320966=2
https://e2e.ti.com/support/processors/f/791/t/800302
Question:
   Are there our customer's tool & software combination proper to continue to develop their product by using AM572x?
We would appreciate if you tell us recommended way or guide about how to use SMP processing with dual-A15 of AM5728
for the PCIE function and EtherCAT-Master integration including proper tool & software combination for SMP software development.
1: SDK(RTOS)
2: CCS
3: Acontis-EC-Master
    For the PCIE SMP, I thought we sent out some note how to do this on AM572x A15.
    PCI-E:
    In pcie_sample.c,
    change
    #include <ti/sysbios/family/arm/a15/Cache.h>
    to
    #include <ti/sysbios/family/arm/a15/smp/Cache.h>
    Comment out the following lines in main() of pcie_sample.c:
    /* Add MMU entries for MMR's required for PCIE example */
    Mmu_DescriptorAttrs attrs;
    extern char ti_sysbios_family_arm_a15_Mmu_Module_State_0_secondLevelTableBuf_0__A;
    extern char ti_sysbios_family_arm_a15_Mmu_Module_State_0_secondLevelTableBuf_1__A;
    uint32_t addr0 = (uint32_t)&ti_sysbios_family_arm_a15_Mmu_Module_State_0_secondLevelTableBuf_0__A;
    uint32_t addr1 = (uint32_t)&ti_sysbios_family_arm_a15_Mmu_Module_State_0_secondLevelTableBuf_1__A;
    Mmu_initDescAttrs(&attrs);
    attrs.type = Mmu_DescriptorType_TABLE;
    attrs.shareable = 0;           // non-shareable
    attrs.accPerm = 1;             // read/write at any privelege level
    attrs.attrIndx = 0;             // Use MAIR0 Register Byte 3 for
                                   // determining the memory attributes
                                   // for each MMU entry
    // Update the first level table's MMU entry for 0x00000000 with the
    // new attributes.
    Mmu_setFirstLevelDesc((Ptr)0x00000000, (UInt64)addr0, &attrs);
    // Update the first level table's MMU entry for 0x40000000 with the
    // new attributes.
    Mmu_setFirstLevelDesc((Ptr)0x40000000, (UInt64)addr1, &attrs);
    Add the following lines to pcie_sample_wSoCFile.cfg:
    // descriptor attribute structure
    var peripheralAttrs1 = new Mmu.DescriptorAttrs();
    Mmu.initDescAttrsMeta(peripheralAttrs1);
    peripheralAttrs1.type = Mmu.DescriptorType_TABLE;
    peripheralAttrs1.accPerm = 1;                   // read/write at any PL
    peripheralAttrs1.shareable = 0;                 // non-shareable
    peripheralAttrs1.attrIndx = 0;                   // Use MAIR0 Register Byte 3 for
                                                     // for each MMU entry                           Mmu.setFirstLevelDescMeta(0x00000000, 0x80001000, peripheralAttrs1);
    Mmu.setFirstLevelDescMeta(0x40000000, 0x80002000, peripheralAttrs1);
    For project integration of Ethercat and PCIE, you can refer to the RTOS template app as the starting point. http://software-dl.ti.com/processor-sdk-rtos/esd/docs/latest/rtos/index_examples_demos.html
    For SMP on Ethercat, I don't think you raised this request before and I am not the expert on Ethercat, please open a new E2E.
    Regards, Eric
    Thank you very much for your kindness.
    I really appreciate your help.
    We 'd like to answer to the customer like belows based on your information.
    - modification guide of pcie_sample.c
    - refer RTOS template such as "9.3. POSIX-SMP Demo" for SMP integration
    And I'd like to create new E2E-thread for SMP on Ethercat
  • Part Number: AM5728
    Hello, TI Experts,
    We have additional question from below E2E-thread.
    https://e2e.ti.com/support/processors/f/791/p/802183/2969223#2969223
    We got the feedback about how to use SMP processing for PCIE.
    And we also want to know how to realize SMP processing with dual-A15 of AM5728
    for the EtherCAT-Master including proper/recommended tools & software version combination.
    We wrote the detail on the above E2E-thread including the customers development tools & software like below;
                                          ti\bios_6_52_00_12
     2:CCS:8.2.0.00007
    Question:
    1: SDK(RTOS)
    2: CCS
    Best regards
    I looked at the two E2E you mentioned, those are TI RTOS topics and reported issues were fixed in SYSBIOS 6.75.01, there is no plan to fix that in 6.52, as communicated in the individual E2E.
    So, using PRSDK 5.3 release (with SYSBIOS 6.75.02) is the way to develop your SMP applications, please suggest customer move to this latest release. Tool set:
    1:SDK(RTOS) :ti\pdk_am57xx_1_0_14
    ti\bios_6_75_02_00
     2:CCS:8.3.0.00009
    If Acontis-EC-Master: 3.0.1.12 (is this the latest?) has any issue with above toolset, please open a new E2E for that.
    Regards, Eric
    I will send the answer to the customer.
