Part Number: AM5728
I have this reference board SItara AM572x Rev 1.2A
I am using http://software-dl.ti.com/processor-sdk-linux/esd/AM57X/latest/index_FDS.html
I built the kernel, just typing make.
I am flashing the sdcard wit the slightly modified sdcard_create faulty script.
Command (m for help): p Disk /dev/mmcblk0: 14.6 GiB, 15653142528 bytes, 30572544 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xee4090c3 Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 * 63 144584 144522 70.6M c W95 FAT32 (LBA) /dev/mmcblk0p2 160650 30572543 30411894 14.5G 83 Linux Command (m for help):
All the files seems to be ok on the sdcard
The boot stops:
Trying to boot Linux from eMMC ...
switch to partitions #0, OK
mmc1(part 0) is current device
SD/MMC found on device 1
** No partition table - mmc 1 **
Trying to boot Android from eMMC ...
mmc - MMC sub system
Usage:
mmc info - display info of the current MMC device
mmc read addr blk# cnt
mmc write addr blk# cnt
mmc erase blk# cnt
mmc rescan
mmc part - lists available partition on current mmc device
mmc dev [dev] [part] - show or set current mmc device [partition]
mmc list - lists available devices
mmc hwpartition [args...] - does hardware partitioning
arguments (sizes in 512-byte blocks):
[user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
[gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
[check|set|complete] - mode, complete set partitioning completed
WARNING: Partitioning is a write-once setting once it is set to complete.
Power cycling is required to initialize partitions after set to complete.
mmc bootbus dev boot_bus_width reset_boot_bus_width boot_mode
- Set the BOOT_BUS_WIDTH field of the specified device
mmc bootpart-resize <dev> <boot part size MB> <RPMB part size MB>
- Change sizes of boot and RPMB partitions of specified device
mmc partconf dev [boot_ack boot_partition partition_access]
- Show or change the bits of the PARTITION_CONFIG field of the specified device
mmc rst-function dev value
- Change the RST_n_FUNCTION field of the specified device
WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.
mmc setdsr <value> - set DSR register value
Usage:
mmc erase blk# cnt
mmc rescan
Usage:
mmc erase blk# cnt
mmc rescan
Wrong Image Format for bootm command
ERROR: can't get kernel image!
//////////////// some extra info
=> mmc list
OMAP SD/MMC: 0
OMAP SD/MMC: 1 (eMMC)
=> mmc part
## Unknown partition table type 0
=> mmc info
Device: OMAP SD/MMC
Manufacturer ID: 70
OEM: 100
Bus Speed: 48000000
Mode : MMC DDR52 (52MHz)
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 14.6 GiB
Bus Width: 8-bit DDR
Erase Group Size: 512 KiB
HC WP Group Size: 16 MiB
User Capacity: 14.6 GiB
Boot Capacity: 4 MiB ENH
RPMB Capacity: 4 MiB ENH
What I am missing.
