TDA2EVM5777: Camera 6 has no output
Part Number: TDA2EVM5777
   I use UC_lvds_vip_multi_cam_vpe_enc_null in PROCESSOR_SDK_VISION_03_06_00_00,
    gChains_usecaseCfg.numLvdsCh = 6; NDK_PROC_TO_USE=none;
    Do "make -s -j depend_ndk_fatfs;make -s -j" to do an incremental build with modified settings.
   Camera 6 has no output。How should I set it up?
   Camera capture status is as follows
[HOST] [IPU2  ]    168.398798 s:  CAPTURE: VIP1 Slice0 PortA FRAME MODE
 [HOST] [IPU2  ]    168.398889 s:  CAPTURE: VIP1 Slice1 PortA FRAME MODE
 [HOST] [IPU2  ]    168.398981 s:  CAPTURE: VIP2 Slice0 PortA FRAME MODE
 [HOST] [IPU2  ]    168.399072 s:  CAPTURE: VIP3 Slice0 PortA FRAME MODE
 [HOST] [IPU2  ]    168.399133 s:  CAPTURE: VIP3 Slice1 PortA FRAME MODE
 [HOST] [IPU2  ]    168.399255 s:  CAPTURE: VIP2 Slice1 PortB FRAME MODE
 [HOST] [IPU2  ]    168.399347 s:
 [HOST] [IPU2  ]    168.399408 s:  [ CAPTURE ] Link Statistics,
 [HOST] [IPU2  ]    168.399469 s:  ******************************
 [HOST] [IPU2  ]    168.399530 s:
 [HOST] [IPU2  ]    168.399591 s:  Elapsed time       = 76951 msec
 [HOST] [IPU2  ]    168.399652 s:
 [HOST] [IPU2  ]    168.399713 s:  New data Recv      = 150.57 fps
 [HOST] [IPU2  ]    168.399804 s:  Get Full Buf Cb    = 150.48 fps
 [HOST] [IPU2  ]    168.399896 s:  Put Empty Buf Cb   = 150.47 fps
 [HOST] [IPU2  ]    168.399957 s:  Driver/Notify Cb   = 150.57 fps
 [HOST] [IPU2  ]    168.400048 s:
 [HOST] [IPU2  ]    168.400109 s:  Input Statistics,
 [HOST] [IPU2  ]    168.400170 s:
 [HOST] [IPU2  ]    168.400231 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [IPU2  ]    168.400323 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [IPU2  ]    168.400384 s:  --------------------------------------------------
 [HOST] [IPU2  ]    168.400475 s:   0 |  30.31      0. 0      0. 0          30.31
 [HOST] [IPU2  ]    168.400628 s:   1 |  30. 7      0. 0      0. 0          30. 7
 [HOST] [IPU2  ]    168.400780 s:   2 |  30. 5      0. 0      0. 0          30. 5
 [HOST] [IPU2  ]    168.400902 s:   3 |  30. 5      0. 0      0. 0          30. 5
 [HOST] [IPU2  ]    168.401055 s:   4 |  30. 5      0. 0      0. 0          30. 5
 [HOST] [IPU2  ]    168.401299 s:
 [HOST] [IPU2  ]    168.401360 s:  Output Statistics,
 [HOST] [IPU2  ]    168.401421 s:
 [HOST] [IPU2  ]    168.401451 s:  CH | Out | Out     | Out Drop | Out User Drop
 [HOST] [IPU2  ]    168.401543 s:     | ID  | FPS     | FPS      | FPS
 [HOST] [IPU2  ]    168.401604 s:  ---------------------------------------------
 [HOST] [IPU2  ]    168.401695 s:   0 |  0     30.31     0. 0      0. 0
 [HOST] [IPU2  ]    168.401817 s:   1 |  0     30. 7     0. 0      0. 0
 [HOST] [IPU2  ]    168.401939 s:   2 |  0     30. 5     0. 0      0. 0
 [HOST] [IPU2  ]    168.402061 s:   3 |  0     30. 7     0. 0      0. 0
 [HOST] [IPU2  ]    168.402214 s:   4 |  0     30. 7     0. 0      0. 0
 [HOST] [IPU2  ]    168.402397 s:
 [HOST] [IPU2  ]    168.402458 s:  [VIP1 Slice0 PortA] Statistics
 [HOST] [IPU2  ]    168.402519 s:  ==============================
 [HOST] [IPU2  ]    168.402580 s:  Number of request queued  : 2334
 [HOST] [IPU2  ]    168.402671 s:  Number of request dequeued: 2333
 [HOST] [IPU2  ]    168.402732 s:  Overflow Count            : 0
 [HOST] [IPU2  ]    168.402793 s:
 [HOST] [IPU2  ]    168.402854 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
 [HOST] [IPU2  ]    168.402976 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
 [HOST] [IPU2  ]    168.403129 s:  ---------------------------------------------------------------------------------------------------------------------------
 [HOST] [IPU2  ]    168.403495 s:   00.0.00 |    2339    2333    2333    2333       0     30    30     0     1/1280     35/720         0       0       0     0
 [HOST] [IPU2  ]    168.403708 s:
 [HOST] [IPU2  ]    168.403769 s:
 [HOST] [IPU2  ]    168.403800 s:  [VIP1 Slice1 PortA] Statistics
 [HOST] [IPU2  ]    168.403861 s:  ==============================
 [HOST] [IPU2  ]    168.403922 s:  Number of request queued  : 2315
 [HOST] [IPU2  ]    168.403983 s:  Number of request dequeued: 2314
 [HOST] [IPU2  ]    168.404074 s:  Overflow Count            : 0
 [HOST] [IPU2  ]    168.404135 s:
 [HOST] [IPU2  ]    168.404196 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
 [HOST] [IPU2  ]    168.404318 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
 [HOST] [IPU2  ]    168.404471 s:  ---------------------------------------------------------------------------------------------------------------------------
 [HOST] [IPU2  ]    168.404776 s:   02.0.00 |    2320    2314    2314    2314       0     30    30     0  1280/1280    720/720         0       0       0     0
 [HOST] [IPU2  ]    168.404898 s:
 [HOST] [IPU2  ]    168.404928 s:
 [HOST] [IPU2  ]    168.404989 s:  [VIP2 Slice0 PortA] Statistics
 [HOST] [IPU2  ]    168.405050 s:  ==============================
 [HOST] [IPU2  ]    168.405111 s:  Number of request queued  : 2314
 [HOST] [IPU2  ]    168.405203 s:  Number of request dequeued: 2313
 [HOST] [IPU2  ]    168.405264 s:  Overflow Count            : 0
 [HOST] [IPU2  ]    168.405325 s:
 [HOST] [IPU2  ]    168.405386 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
 [HOST] [IPU2  ]    168.405508 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
 [HOST] [IPU2  ]    168.405630 s:  ---------------------------------------------------------------------------------------------------------------------------
 [HOST] [IPU2  ]    168.405935 s:   04.0.00 |    2319    2313    2313    2313       0     30    30     0  1280/1280    720/720         0       0       0     0
 [HOST] [IPU2  ]    168.406057 s:
 [HOST] [IPU2  ]    168.406118 s:
 [HOST] [IPU2  ]    168.406179 s:  [VIP3 Slice0 PortA] Statistics
 [HOST] [IPU2  ]    168.406240 s:  ==============================
 [HOST] [IPU2  ]    168.406301 s:  Number of request queued  : 2314
 [HOST] [IPU2  ]    168.406514 s:  Number of request dequeued: 2314
 [HOST] [IPU2  ]    168.406575 s:  Overflow Count            : 0
 [HOST] [IPU2  ]    168.406636 s:
 [HOST] [IPU2  ]    168.406697 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
 [HOST] [IPU2  ]    168.406819 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
 [HOST] [IPU2  ]    168.406941 s:  ---------------------------------------------------------------------------------------------------------------------------
 [HOST] [IPU2  ]    168.407277 s:   08.0.00 |    2319    2314    2314    2314       0     30    30     0  1280/1280    720/720         0       0       0     0
 [HOST] [IPU2  ]    168.407430 s:
 [HOST] [IPU2  ]    168.407460 s:
 [HOST] [IPU2  ]    168.407521 s:  [VIP3 Slice1 PortA] Statistics
 [HOST] [IPU2  ]    168.407582 s:  ==============================
 [HOST] [IPU2  ]    168.407643 s:  Number of request queued  : 2314
 [HOST] [IPU2  ]    168.407704 s:  Number of request dequeued: 2314
 [HOST] [IPU2  ]    168.407765 s:  Overflow Count            : 0
 [HOST] [IPU2  ]    168.407857 s:
 [HOST] [IPU2  ]    168.407887 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
 [HOST] [IPU2  ]    168.408009 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
 [HOST] [IPU2  ]    168.408131 s:  ---------------------------------------------------------------------------------------------------------------------------
 [HOST] [IPU2  ]    168.408467 s:   10.0.00 |    2319    2314    2314    2314       0     30    30     0  1280/1280    720/720         0       0       0     0
 [HOST] [IPU2  ]    168.408589 s:
 [HOST] [IPU2  ]    168.408650 s:
 [HOST] [IPU2  ]    168.408680 s:  [VIP2 Slice1 PortB] Statistics
 [HOST] [IPU2  ]    168.408741 s:  ==============================
 [HOST] [IPU2  ]    168.408924 s:  Number of request queued  : 1
 [HOST] [IPU2  ]    168.408985 s:  Number of request dequeued: 0
 [HOST] [IPU2  ]    168.409046 s:  Overflow Count            : 0
 [HOST] [IPU2  ]    168.409138 s:
 [HOST] [IPU2  ]    168.409199 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
 [HOST] [IPU2  ]    168.409321 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
 [HOST] [IPU2  ]    168.409473 s:  ---------------------------------------------------------------------------------------------------------------------------
 [HOST] [IPU2  ]    168.409778 s:   07.0.00 |       6       0       0       0       0      0     0     0     0/0         0/0           0       0       0     0
 [HOST] [IPU2  ]    168.409900 s:
