Part Number: AM5728
I am using PROCESSOR-SDK-RTOS-AM57X - pdk_am57xx_1_0_7.
We had a query in forum about using the McSPI for mutiple devices, but we didn't get any solution so am opening the thread for the same.
https://e2e.ti.com/support/processors/f/791/t/754225
We are stuck in the issue that we are not able to access the two devices on the same Spi bus.
When we tried to access the device, other device chip select is also asserting.
we tried with all suggestions we got from forum in the above link mentioned.
And when we tried to configure both channels as MCSPI_MULTI_CH, we are observing that both the channels are not working.
Can you please test the multi channel example from your side and suggest us another example for multi-channel.
for exmple; when we tried to use the SPI_BUS1 which has two devices. CS0->device_1 and CS1->device_2.
when we tired to use CS0, CS1 also active and vice versa.
Please take this one as higher priority, this is blocker for the further work.
Thanks in advance.
Ranganath V N
