Part Number: TDA2SX
Dear Champs,
My customer is trying to develop their own DL algorithm using Jacinto-Caffe, and they tried to convert pre-trained network found at below GIT directory.
But, when they convert pre-trained network of JDETNET 768x320 found at GIT without any modification, they faced DSP hang and they can run it after modifying 'SYSN_THRESHOLD' value and found to run it at 2fps only.
I attached the log when DSP hang occurred as below. Could you please check below log and let me know what is the issue causing DSP hang?.
They can run it by changing 'SYNC_THRESHOLD' as below and they found 2fps at this time.
And also, they found the C66x DSP load is only 20% when they run JDETNET 768x320 included in visionSDK, and Please let me know how they can achieve similar performance using Jacinto-Caffe.
Thanks and Best Regards,
SI.
