Compiler/TDA2PXEVM: TDA2PXEVM
Part Number: TDA2PXEVM
Hi ,
I am facing the assertion error in custom algorithm plugin creation (in rtos).
The usecase is
NullSource (A15) -> Decode ->  VPE -> Alg_MyFrameCopy (DSP1) -> Display
The output window is
[HOST] [HOST  ]     64.601476 s:  IPC_OUT_0   : Create in progress !!!
 [HOST] [HOST  ]     64.601537 s:  IPC_OUT_0   : Create Done !!!
 [HOST] [IPU2  ]     64.601720 s:  IPC_IN_0   : Create in progress !!!
 [HOST] [IPU2  ]     64.602970 s:  IPC_IN_0   : Create Done !!!
 [HOST] [IPU2  ]     64.603397 s:  DECODE: Create in progress ... !!!
 [HOST] [IPU2  ]     64.813060 s:  DECODE: Creating CH0 of 1280 x 720 [1] [0],ta
rget bitrate = 10000 Kbps ...
 [HOST] [IPU2  ]     64.813975 s:  DECODE: All CH Create ... DONE !!!
 [HOST] [IPU2  ]     64.816019 s:  DECODE: Create ... DONE !!!
 [HOST] [IPU2  ]     64.816446 s:  VPE: Create in progress !!!
 ASSERT (TF_SVS_priv.c|TF_SVS_Create|190)
 [HOST] [DSP1  ]     64.951503 s:  IPC_IN_0   : Create in progress !!!
 [HOST] [DSP1  ]     64.952144 s:  IPC_IN_0   : Create Done !!!
 [HOST] [DSP1  ]     64.952357 s:  ALG: ERROR: Invalid alg ID specified  (algId
= 43) !!!
 [HOST] [IPU2  ]     64.949978 s:  VPE: Loading Down-scaling Co-effs
 [HOST] [IPU2  ]     64.950222 s:  VPE: Co-effs Loading ... DONE !!!
 [HOST] [IPU2  ]     64.950436 s:  VPE: Create Done !!!
 [HOST] [IPU2  ]     64.950832 s:  IPC_OUT_0   : Create in progress !!!
 [HOST] [IPU2  ]     64.951168 s:  IPC_OUT_0   : Create Done !!!
In one of the TI answer links it was suggested to do
if(algId>=ALGORITHM_LINK_ALG_MAXNUM)
       Vps_printf(" ALG: ERROR: Invalid alg ID specified "
                  " (algId = %d) !!!\n", pObj->algId);
       status = SYSTEM_LINK_STATUS_EINVALID_PARAMS;
Print the value of "ALGORITHM_LINK_ALG_MAXNUM" in Vps_printf
In the above if loop, I added  Vps_printf(" ALG: ERROR: Max link number "
                   " (algId = %d) !!!\n", ALGORITHM_LINK_ALG_MAXNUM);
But in my case its found not to print anything. Even the file doesn't seem to build.
The custom algorithm plugin is reflected in system_cfg.h.
Can anyone suggest a solution?
