Part Number: 66AK2G12
I want to load the out file into DSP using MPMCL in linux.
I put the code in DDR(DDR3_DSP_CODE) as shown below. (I used 2GB DDR memory)
name origin length used unused attr fill ---------------------- -------- --------- -------- -------- ---- -------- MSMCSRAM 0c000000 00100000 00020010 000dfff0 RW X L2SRAM 10800000 00100000 0003d00c 000c2ff4 RW X DDR3_DSP_CODE a0000000 10000000 0050f1ea 0faf0e16 RW X DDR3 b0000000 50000000 075d9278 48a26d88 RW X
run origin load origin length init length attrs members ---------- ----------- ---------- ----------- ----- ------- a0000000 a0000000 00343660 00000000 rw- a0000000 a0000000 0028364c 00000000 rw- .fardata a0283650 a0283650 00080000 00000000 rw- .section_DDR2_CODE a0303650 a0303650 00040000 00000000 rw- .stack a0343650 a0343650 00000010 00000000 rw- .far.1 a0343660 a0343660 0002be20 0002be20 r-x a0343660 a0343660 0002be20 0002be20 r-x .text a036f480 a036f480 00003f1c 00000000 rw- a036f480 a036f480 00003f1c 00000000 rw- .far.2 a03733a0 a03733a0 000031a4 000031a4 r-- a03733a0 a03733a0 00002c62 00002c62 r-- .const a0376004 a0376004 00000540 00000540 r-- .switch a0376548 a0376548 00000224 00000000 rw- a0376548 a0376548 00000120 00000000 rw- .cio a0376668 a0376668 00000014 00000000 rw- .bss a0376680 a0376680 000000ec 00000000 rw- .neardata a037676c a037676c 00000024 00000024 r-- a037676c a037676c 00000024 00000024 r-- .init_array a0376800 a0376800 00198a68 00198a68 r-x a0376800 a0376800 00000200 00000200 r-x .vecs a0376a00 a0376a00 00198868 00198868 r-- .cinit b26fed68 b26fed68 04cda510 00000000 rw- b26fed68 b26fed68 04cda510 00000000 rw- .section_DDR2
And I modified the evm.dts file
form
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
dsp_common_memory: dsp-common-memory@81d000000 {
compatible = "ti,keystone-dsp-mem-pool";
reg = <0x00000008 0x1d000000 0x00000000 0x2800000>;
reusable;
status = "okay";
dsp_common_memory: dsp-common-memory@81f800000 {
compatible = "shared-dma-pool";
reg = <0x00000008 0x1f800000 0x00000000 0x800000>;
reusable;
status = "okay";
to
reserved-memory {
#size-cells = <2>;
ranges;
dsp_common_mpm_memory: dsp-common-mpm-memory@a00000000 {
reg = <0x0000000A 0x00000000 0x00000000 0x10000000>;
no-map;
status = "okay";
dsp_common_memory: dsp-common-memory@b0000000 {
reg = <0x0000000b 0x00000000 0x00000000 0x50000000>;
reusable;
status = "okay";
but occurs error -104 when mpmcl load.
ex
:~# mpmcl reset dsp0
reset succeeded
:~# mpmcl load dsp0 thunderDSP.out
load failed (error: -104)
Feb 27 08:22:27 k2g-evm daemon.info mpmsrv[325]: mpmsrv.c:134:mpm_server: received load command for dsp0 filename /home/root/ETS10DSP.out
Feb 27 08:22:27 k2g-evm daemon.err mpmsrv[325]: mpmdlif.c:197:map_and_copy_segment: transport mmap failed for addr 0xa0000000 size 3421792 (err: No such file or directory)
Feb 27 08:22:27 k2g-evm daemon.err mpmsrv[325]: mpmdlif.c:1279:DLIF_allocate: map and copy failed for image /home/root/ETS10DSP.out with addr 0xa0000000, size 0x343660
Feb 27 08:22:27 k2g-evm daemon.err mpmsrv[325]: mpmdlif.c:1442:DLIF_error: << D L O A D >> ERROR:
Feb 27 08:22:27 k2g-evm daemon.err mpmsrv[325]: mpmdlif.c:1445:DLIF_error: Failed to allocate target memory for static executable.
Feb 27 08:22:27 k2g-evm daemon.err mpmsrv[325]: mpmdlif.c:864:mpm_dlif_load: Image loading failed for file /home/root/ETS10DSP.out
Feb 27 08:22:27 k2g-evm daemon.err mpmsrv[325]: mpmssm.c:510:mpm_load_slave: Image loading failed for dsp0 : image
Feb 27 08:22:27 k2g-evm daemon.err mpmsrv[325]: mpmssm.c:419:mpm_ssm_state_error: entered error state for dsp0
Feb 27 08:22:27 k2g-evm daemon.info mpmsrv[325]: mpmsrv.c:77:mpm_server: waiting for slave message
Is there anything else I need to do ? or Did I correct it wrong?
DG
