66AK2E05: 66AK2E05
Part Number: 66AK2E05
I want to use the processor 66AK2E05 in bare metal environment. Can i run all the Arm and Dsp cores in parallel. After power on Master ARM core will be booted from flash memory and loads rest Arm and Dsp cores with some applications. ARM cores are using 1G ethernet ports while Dsp core is using PCIe and 10G ethernet ports. Can i use all the mentioned interfaces? Also from where i can get examples of above mentioned?
