Part Number: AM5728
We have an application which is transcoding motion-JPEG to H.264 using the GStreamer Ducati plugins.
Sporadically, we see errors reported from the plugin:
0:17:53.067453000 4906 0xb40680f0 WARN default gstducatividdec.c:567:codec_process: err=-1, extendedError=00000010
0:17:53.068753000 4906 0xb40680f0 ERROR default gstducati.c:61:gst_ducati_log_extended_error_info: Bit 4 (00000010): MB data error
0:17:53.088345000 4906 0xb40680f0 WARN default gstducatividdec.c:567:codec_process: err=-1, extendedError=00000010
0:17:53.089897000 4906 0xb40680f0 ERROR default gstducati.c:61:gst_ducati_log_extended_error_info: Bit 4 (00000010): MB data error
0:17:53.117345000 4906 0xb40680f0 WARN default gstducatividdec.c:567:codec_process: err=-1, extendedError=00000010
0:17:53.118458000 4906 0xb40680f0 ERROR default gstducati.c:61:gst_ducati_log_extended_error_info: Bit 4 (00000010): MB data error
0:17:53.268037000 4906 0xb40680f0 WARN default gstducatividdec.c:567:codec_process: err=-1, extendedError=00008000
0:17:53.268621000 4906 0xb40680f0 ERROR default gstducati.c:61:gst_ducati_log_extended_error_info: Bit 15 (00008000): fatal
We have so far been unable to identify any particular scenario that makes the errors more or less likely to happen: sometimes they occur immediately, sometimes after several minutes, and sometimes the application runs for several hours without errors.
How should we go about debugging these errors? My understanding from reviewing the ducati and libdce code is that the errors originate on the DSP processor and not on the primary ARM processor. Are there any tools that would allow greater visibility into what is going wrong in the DSP firmware?
