Part Number: AM3358
It appears the related question was resolved.
Did it get resolved and working?
And please how did it resolved?
Code samples?
Part Number: AM3358
Code samples?
Unfortunately, the FBDEV driver is no longer supported and in the new DRM driver, the 1-, 2-, 4-, and 8-bpp modes are palette modes and are not supported by the tilcdc driver. Here is the ref doucment: https://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components/Kernel/Kernel_Drivers/Display/LCDC.html#am335x-lcdc-drm-display-driver
Krunal
Hi Krunal,
What is required to get FBDEV (or similar alternate) working?
We use (at present) EL 1 BPP display for low temperature reasons.
Does the BBB support displays via SPI?
The FBDEV is enabled by default in our filesystems but the community does not maintain the driver. I have reached out to Brad to check if the solution was documented.
With regards to SPI, could you please share your configuration requirements? I am wondering if the following document is similar to your use case.
Krunal
