Part Number: TDA4VM
Hi Lucas,
I'd looked at the tutorial, but a review helped.
After a vxGraphDequeue I have a pointer to the vx_image buffer (out_capture_frames) available. Can I then use tivxMapRawImagePatch or tivxCopyRawImagePatch (what's the difference) to copy the buffer and provide to another application. I did not see where this buffer is unmapped in the single cam example.
Also vxGraphParameterDequeueDoneRef(obj->graph, graph_parameter_num, (vx_reference*)&out_capture_frames, 1, &num_refs_capture); Is this the output of the camera (VISS) without any processing or the input to the display?
The multi-cam use case pipelines one frame at a time so is it using an array to handle multiple camera inputs within one frame cycle?
Please advise.
