Part Number: TDA4VM
Hi Ti
We have added the csitx node to the application according to test_csitx_csirx.c.
But the app is stuck in the verify phase.
Params we used as followed:
Can you give some advice to handle this problem?
Best Regards
Part Number: TDA4VM
Hi Ti
Best Regards
Hi Zhang,
Can you please describe your setup in more details like how is the HW setup, SDK version?
Also, can you please elaborate more on use-case?
Thanks & Regards,
Vivek Dhande.
Texas Instruments (India) Pvt Ltd
hi Vivek
we are using SDK 7.1 , and we try this application in EVM and our own board,both stuck in verify graph.
use-case:
captureNode->CSITXNode. we use capture output raw array as csitxnode's input.
Hi Zhang,
Your setup looks like follows, right?
Sensor → CSIRX (Capture Node) → CSITX (CSITX Node) → external CSI receiver
Is "Sensor → CSIRX (TDA4VM)" path verified?
Thanks & Regards,
Vivek Dhande.
Hi Zhang,
Can we create a graph with only CSITX node? We can send any data from memory and see if CSITX is able to transmit and external receiver is able to receive it.
This will help us to verify "CSITX (CSITX Node) → external CSI receiver" path.
Thanks & Regards,
Vivek Dhande.
