Other Parts Discussed in Thread: UNIFLASH, SYSBIOS
Hi experts,
I'm working on a custom board of TDA4VM and the boot flow is SBL -> SPL(Main A72) -> U-Boot - > Linux.
Due to product demand of AVM, linux boot time need to be reduced to 4s and now is about 15s.
I find that it takes a long time(about 6s) for A72 to communicate with R5fs and DSPs. My question is how to optimize it or is there any reference design? Log is attached.
BTW, I'm using SDK 7.2.
Thanks.
root@buildroot:~# root@buildroot:~# reboot [ OK ] Stopped target Multi-User System. [ Stopping Serial Getty on ttyS2... Stopping OpenSSH server daemon... [ OK ] Stopped D-Bus System Message Bus. [ OK ] Stopped System Logging Service. [ OK ] Stopped Serial Getty on ttyS2. [ OK ] Stopped OpenSSH server daemon. [ OK ] Removed slice system-serial\x2dgetty.slice. [ OK ] Stopped target Basic System. [ OK ] Stopped target Network. [ OK ] Stopped target Paths. [ OK ] Stopped Dispatch Password ��ts to Console Directory Watch. [ OK ] Stopped Forward Password R��uests to Wall Directory Watch. [ OK ] Stopped target Slices. [ OK ] Stopped target Sockets. [ OK ] Closed D-Bus System Message Bus Socket. [ OK ] Stopped target System Initialization. [ OK ] Closed Syslog Socket. Stopping Raise network interfaces... Stopping Network Name Resolution... [ 275.273145] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: unregister_ipv4 rpmsg - fail -5 [ OK ] Stopped Network Name Resolution. [ OK ] Stopped Create Volatile Files and Directories. [ 275.397417] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac stopped [ OK ] Stopped Raise network interfaces. [ OK ] Stopped target Local File Systems. [ OK ] Stopped target Local File Systems (Pre). Unmounting Temporary Directory (/tmp)... [ OK ] Stopped Remount Root and Kernel File Systems. [ OK ] Stopped Apply Kernel Variables. [ OK ] Stopped Load Kernel Modules. [ OK ] Stopped Create Static Device Nodes in /dev. [ OK ] Unmounted Temporary Directory (/tmp). [ OK ] Stopped target Swap. [ OK ] Reached target Shutdown. [ OK ] Reached target Unmount All Filesystems. [ OK ] Reached target Final Step. [ OK ] Finished Reboot. [ OK ] Reached target Reboot. [ 275.726641] systemd-shutdown[1]: Syncing filesystems and block devices. [ 276.034969] systemd-shutdown[1]: Sending SIGTERM to remaining processes... [ 276.123188] systemd-shutdown[1]: Sending SIGKILL to remaining processes... [ 276.135958] systemd-shutdown[1]: Unmounting file systems. [ 276.144326] [310]: Remounting '/' read-only in with options '(null)'. [ 276.159841] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 276.167795] systemd-shutdown[1]: All filesystems unmounted. [ 276.174765] systemd-shutdown[1]: Deactivating swaps. [ 276.181603] systemd-shutdown[1]: All swaps deactivated. [ 276.188151] systemd-shutdown[1]: Detaching loop devices. [ 276.196819] systemd-shutdown[1]: All loop devices detached. [ 276.203780] systemd-shutdown[1]: Detaching DM devices. [ 276.210335] systemd-shutdown[1]: All DM devices detached. [ 276.217073] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached. [ 276.238922] systemd-shutdown[1]: Syncing filesystems and block devices. [ 276.247328] systemd-shutdown[1]: Rebooting. [ 276.295477] reboot: Restarting system NOTICE: BL31: v2.3():07.01.00.006-dirty NOTICE: BL31: Built : 03:49:38, Jan 25 2021 U-Boot SPL 2020.01 (Apr 16 2021 - 01:46:06 -0400) SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.7--v2020.08d (Terrific Lla') Reading on-board EEPROM at 0x50 failed -19 K3_PRIMARY_BOOTMODE bootmode = 0x3 spl_boot_device from SPI Trying to boot from SPI WARN: PHY calibration failed: -2 U-Boot 2020.01 (Apr 16 2021 - 01:46:06 -0400) SoC: J721E SR1.0 Model: Texas Instruments K3 J721E SoC Reading on-board EEPROM at 0x50 failed -19 Board: J721EX-PM1-SOM rev E2 DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from MMC... MMC: block number 0x3500 exceeds max(0x2000) MMC: block number 0x3600 exceeds max(0x2000) *** Error - No Valid Environment Area found *** Warning - bad env area, using default environment In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Reading on-board EEPROM at 0x50 failed 1 Net: No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device SD/MMC found on device 0 175 bytes read in 2 ms (85 KiB/s) Loaded env from uEnv.txt Importing environment from mmc0 ... 22787812 bytes read in 617 ms (35.2 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 22787812 bytes: Success! 13976760 bytes read in 380 ms (35.1 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 13976760 bytes: Success! 5627164 bytes read in 156 ms (34.4 MiB/s) Load Remote Processor 4 with data@addr=0x82000000 5627164 bytes: Success! 5627164 bytes read in 157 ms (34.2 MiB/s) Load Remote Processor 5 with data@addr=0x82000000 5627164 bytes: Success! 12100128 bytes read in 329 ms (35.1 MiB/s) Load Remote Processor 6 with data@addr=0x82000000 12100128 bytes: Success! 12100176 bytes read in 330 ms (35 MiB/s) Load Remote Processor 7 with data@addr=0x82000000 12100176 bytes: Success! 17784560 bytes read in 483 ms (35.1 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 17784560 bytes: Success! 16797704 bytes read in 454 ms (35.3 MiB/s) 42834 bytes read in 3 ms (13.6 MiB/s) WARN: PHY calibration failed: -2 SF: Detected mt35xu256aba with page size 256 Bytes, erase size 128 KiB, total 32 MiB ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 ERROR: reserving fdt memory region failed (addr=a1000000 size=100000) ERROR: reserving fdt memory region failed (addr=a1100000 size=1f00000) ERROR: reserving fdt memory region failed (addr=a3100000 size=1f00000) ERROR: reserving fdt memory region failed (addr=a5000000 size=100000) ERROR: reserving fdt memory region failed (addr=a5100000 size=700000) ERROR: reserving fdt memory region failed (addr=a5800000 size=100000) ERROR: reserving fdt memory region failed (addr=a5900000 size=700000) Loading Device Tree to 000000008fef2000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.4.74-ACU-1.2.0.1-g9574bba32a (huojianyu@sixi) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #2 SMP PREEMPT Fri Apr 9 05:21:01 EDT 2021 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] r5f-dma-memory@a1000000 (0x00000000a1000000--0x00000000a1100000) overlaps with vision_apps-r5f-dma-memory@a1000000 (0x00000000a1000000--0x00000000a1100000) [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] r5f-memory@a1100000 (0x00000000a1100000--0x00000000a2000000) overlaps with vision_apps-r5f-memory@a1100000 (0x00000000a1100000--0x00000000a3000000) [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] vision_apps-r5f-memory@a1100000 (0x00000000a1100000--0x00000000a3000000) overlaps with r5f-dma-memory@a2000000 (0x00000000a2000000--0x00000000a2100000) [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] vision_apps-r5f-memory@a3100000 (0x00000000a3100000--0x00000000a5000000) overlaps with r5f-memory@a3100000 (0x00000000a3100000--0x00000000a4000000) [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] r5f-dma-memory@a5000000 (0x00000000a5000000--0x00000000a5100000) overlaps with vision_apps-r5f-dma-memory@a5000000 (0x00000000a5000000--0x00000000a5100000) [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] vision_apps-r5f-memory@a5100000 (0x00000000a5100000--0x00000000a5800000) overlaps with r5f-memory@a5100000 (0x00000000a5100000--0x00000000a6000000) [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] r5f-memory@a5100000 (0x00000000a5100000--0x00000000a6000000) overlaps with vision_apps-r5f-dma-memory@a5800000 (0x00000000a5800000--0x00000000a5900000) [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 7 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5900000, size 7 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5900000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ac000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 720 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@ce000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@fb000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@fb100000, compatible id shared-dma-pool [ 0.000000] cma: Failed to reserve 512 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 35779 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.sbl),512k(ospi.tifs),768k(ospi.mcufw),6m(ospi.atf_optee),1m(ospi.u-boot-spl),2m(ospi.u-boot),13568k(ospi.reserved),8m(ospi.mcudata) root=PARTUUID=00000000-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB) [ 0.000000] Memory: 2584128K/2293760K available (9662K kernel code, 852K rwdata, 3840K rodata, 1664K init, 704K bss, 18446744073709261248K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c00c0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000 [ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x43c with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.010362] Console: colour dummy device 80x25 [ 0.016064] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.029399] pid_max: default: 32768 minimum: 301 [ 0.035335] LSM: Security Framework initializing [ 0.041273] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.050737] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.062142] ASID allocator initialised with 32768 entries [ 0.069125] rcu: Hierarchical SRCU implementation. [ 0.075405] Platform MSI: gic-its@1820000 domain created [ 0.082304] PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created [ 0.093299] smp: Bringing up secondary CPUs ... [ 0.099915] Detected PIPT I-cache on CPU1 [ 0.099942] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.099955] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000 [ 0.099987] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.100047] smp: Brought up 1 node, 2 CPUs [ 0.136726] SMP: Total of 2 processors activated. [ 0.142731] CPU features: detected: 32-bit EL0 Support [ 0.149297] CPU features: detected: CRC32 instructions [ 0.164175] CPU: All CPU(s) started at EL2 [ 0.169413] alternatives: patching kernel code [ 0.175842] devtmpfs: initialized [ 0.182891] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.195351] futex hash table entries: 512 (order: -1, 32768 bytes, linear) [ 0.204520] pinctrl core: initialized pinctrl subsystem [ 0.211743] NET: Registered protocol family 16 [ 0.217666] DMA: preallocated 256 KiB pool for atomic allocations [ 0.225784] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.241293] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages [ 0.249859] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.258305] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.268346] cryptd: max_cpu_qlen set to 1000 [ 0.276012] iommu: Default domain type: Translated [ 0.282448] SCSI subsystem initialized [ 0.287368] mc: Linux media interface: v0.10 [ 0.292827] videodev: Linux video capture interface: v2.00 [ 0.299841] pps_core: LinuxPPS API ver. 1 registered [ 0.306177] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.317847] PTP clock support registered [ 0.322859] EDAC MC: Ver: 3.0.0 [ 0.327480] FPGA manager framework [ 0.331869] Advanced Linux Sound Architecture Driver Initialized. [ 0.340141] clocksource: Switched to clocksource arch_sys_counter [ 0.348096] VFS: Disk quotas dquot_6.6.0 [ 0.353154] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [ 0.364983] Carveout Heap: Exported 512 MiB at 0x00000000ae000000 [ 0.372792] thermal_sys: Registered thermal governor 'step_wise' [ 0.372793] thermal_sys: Registered thermal governor 'power_allocator' [ 0.380693] NET: Registered protocol family 2 [ 0.394930] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear) [ 0.405882] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear) [ 0.416123] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear) [ 0.425837] TCP: Hash tables configured (established 32768 bind 32768) [ 0.434257] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.442870] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.452117] NET: Registered protocol family 1 [ 0.458015] RPC: Registered named UNIX socket transport module. [ 0.465581] RPC: Registered udp transport module. [ 0.471585] RPC: Registered tcp transport module. [ 0.477587] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.485817] PCI: CLS 0 bytes, default 64 [ 0.491221] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.503562] Initialise system trusted keyrings [ 0.509333] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [ 0.520038] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.527843] NFS: Registering the id_resolver key type [ 0.534309] Key type id_resolver registered [ 0.539647] Key type id_legacy registered [ 0.544767] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.553476] 9p: Installing v9fs 9p2000 file system support [ 0.569403] Key type asymmetric registered [ 0.574636] Asymmetric key parser 'x509' registered [ 0.580886] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.590335] io scheduler mq-deadline registered [ 0.596117] io scheduler kyber registered [ 0.602131] pinctrl-single 4301c000.pinmux: 94 pins, size 376 [ 0.609701] pinctrl-single 11c000.pinmux: 173 pins, size 692 [ 0.618723] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.626546] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.634432] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.642445] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.652462] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.660475] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.670377] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.678390] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.688287] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.696189] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.706079] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.713981] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.725390] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.739369] brd: module loaded [ 0.747028] loop: module loaded [ 0.751104] mtip32xx Version 1.3.1 [ 0.755786] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys' [ 0.765687] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.74-ACU-1.2.0.1-g9574bba32a #2 [ 0.775906] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 0.783349] Call trace: [ 0.786470] dump_backtrace+0x0/0x140 [ 0.791138] show_stack+0x14/0x20 [ 0.795366] dump_stack+0xb4/0x114 [ 0.799705] sysfs_warn_dup+0x5c/0x78 [ 0.804372] sysfs_create_dir_ns+0xd8/0xf0 [ 0.809595] kobject_add_internal+0x94/0x280 [ 0.815039] kobject_add+0x90/0xf8 [ 0.819376] device_add+0xdc/0x600 [ 0.823711] platform_device_add+0xfc/0x228 [ 0.829044] platform_device_register_full+0xc8/0x140 [ 0.835494] dma_buf_phys_init+0x68/0x94 [ 0.840495] do_one_initcall+0x50/0x1a8 [ 0.845387] kernel_init_freeable+0x194/0x23c [ 0.850947] kernel_init+0x10/0xfc [ 0.855281] ret_from_fork+0x10/0x1c [ 0.859850] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory. [ 0.877084] libphy: Fixed MDIO Bus: probed [ 0.882562] tun: Universal TUN/TAP device driver, 1.6 [ 0.889225] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 0.899230] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.906808] sky2: driver version 1.30 [ 0.911864] VFIO - User Level meta-driver version: 0.3 [ 0.918797] i2c /dev entries driver [ 0.923472] Error: Driver 'k3-soc-thermal' is already registered, aborting... [ 0.932782] sdhci: Secure Digital Host Controller Interface driver [ 0.940675] sdhci: Copyright(c) Pierre Ossman [ 0.946407] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.953984] ledtrig-cpu: registered to indicate activity on CPUs [ 0.962306] optee: probing for conduit method from DT. [ 0.968897] optee: revision 3.8 (199fca17) [ 0.969280] optee: initialized driver [ 0.979770] NET: Registered protocol family 17 [ 0.985537] 9pnet: Installing 9P2000 support [ 0.991023] Key type dns_resolver registered [ 0.996654] registered taskstats version 1 [ 1.001889] Loading compiled-in X.509 certificates [ 1.010290] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 1.018196] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 1.027171] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0014 '20.8.7--v2020.08d (Terrific Lla') [ 1.049218] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created [ 1.061956] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.073595] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 1.085937] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.094386] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.105468] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 1.118150] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.126599] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.136449] printk: console [ttyS2] disabled [ 1.141929] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 11, base_baud = 3000000) is a 8250 [ 1.152851] printk: console [ttyS2] enabled [ 1.152851] printk: console [ttyS2] enabled [ 1.163401] printk: bootconsole [ns16550a0] disabled [ 1.163401] printk: bootconsole [ns16550a0] disabled [ 1.176287] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 1.188064] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq [ 1.200713] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq [ 1.210460] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs [ 1.221310] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 1.234450] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 1.247139] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 1.259938] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 1.273317] scsi host0: ufshcd [ 1.280333] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:250000000, add_val:3 pps:0 [ 1.291010] mmc0: CQHCI version 5.10 [ 1.336336] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit [ 1.346577] mmc1: CQHCI version 5.10 [ 1.411531] mmc0: new MMC card at address 0001 [ 1.417477] mmcblk0: mmc0:0001 MMC32G 29.1 GiB [ 1.423371] mmcblk0boot0: mmc0:0001 MMC32G partition 1 4.00 MiB [ 1.431031] mmcblk0boot1: mmc0:0001 MMC32G partition 2 4.00 MiB [ 1.438569] mmcblk0rpmb: mmc0:0001 MMC32G partition 3 4.00 MiB, chardev (240:0) [ 1.452806] mmcblk0: p1 p2 [ 1.785631] cdns-ufshcd 4e84000.ufs: link startup failed 1 [ 1.792483] cdns-ufshcd 4e84000.ufs: UFS Host state=0 [ 1.798781] cdns-ufshcd 4e84000.ufs: lrb in use=0x0, outstanding reqs=0x0 tasks=0x0 [ 1.808328] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0 [ 1.816358] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0 [ 1.824930] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0 [ 1.833177] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0 [ 1.841097] cdns-ufshcd 4e84000.ufs: Clk gate=1 [ 1.846745] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0 [ 1.856074] cdns-ufshcd 4e84000.ufs: Host capabilities=0x1587031f, caps=0x0 [ 1.864755] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0 [ 1.872246] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0 [ 1.887448] host_regs: 00000000: 1587031f 00000000 00000210 00000000 [ 1.895372] host_regs: 00000010: 00000000 00000000 00000000 00000000 [ 1.903292] host_regs: 00000020: 00000000 00000470 00000000 00000000 [ 1.911214] host_regs: 00000030: 00000008 00000001 00000000 00000000 [ 1.919135] host_regs: 00000040: 00000000 00000000 00000000 00000000 [ 1.927057] host_regs: 00000050: 00000000 00000000 00000000 00000000 [ 1.934977] host_regs: 00000060: 00000000 00000000 00000000 00000000 [ 1.942897] host_regs: 00000070: 00000000 00000000 00000000 00000000 [ 1.950842] host_regs: 00000080: 00000000 00000000 00000000 00000000 [ 1.958766] host_regs: 00000090: 00000000 00000000 00000000 00000000 [ 1.966689] cdns-ufshcd 4e84000.ufs: hba->ufs_version = 0x210, hba->capabilities = 0x1587031f [ 1.977319] cdns-ufshcd 4e84000.ufs: hba->outstanding_reqs = 0x0, hba->outstanding_tasks = 0x0 [ 1.988058] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt = 0 [ 1.998474] cdns-ufshcd 4e84000.ufs: No record of pa_err errors [ 2.005855] cdns-ufshcd 4e84000.ufs: No record of dl_err errors [ 2.013234] cdns-ufshcd 4e84000.ufs: No record of nl_err errors [ 2.020615] cdns-ufshcd 4e84000.ufs: No record of tl_err errors [ 2.027994] cdns-ufshcd 4e84000.ufs: No record of dme_err errors [ 2.035482] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err errors [ 2.043947] cdns-ufshcd 4e84000.ufs: No record of fatal_err errors [ 2.051653] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1661492 us [ 2.060549] cdns-ufshcd 4e84000.ufs: No record of resume_fail errors [ 2.068473] cdns-ufshcd 4e84000.ufs: No record of suspend_fail errors [ 2.076503] cdns-ufshcd 4e84000.ufs: No record of dev_reset errors [ 2.084209] cdns-ufshcd 4e84000.ufs: No record of host_reset errors [ 2.092023] cdns-ufshcd 4e84000.ufs: No record of task_abort errors [ 2.099837] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000 [ 2.107652] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000 [ 2.115247] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000 [ 2.671220] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit [ 2.681543] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 2.690225] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 2.698736] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 2.707269] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 2.715766] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 2.724713] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 2.736500] random: fast init done [ 2.741680] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16) [ 2.770905] cadence-qspi 47040000.spi: PHY calibration failed: -2 [ 2.778527] spi-nor spi0.0: mt35xu256aba (32768 Kbytes) [ 2.785072] 8 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 2.793352] Creating 8 MTD partitions on "47040000.spi.0": [ 2.800210] 0x000000000000-0x000000080000 : "ospi.sbl" [ 2.807323] 0x000000080000-0x000000100000 : "ospi.tifs" [ 2.813989] mmc1: new SDHC card at address aaaa [ 2.820239] mmcblk1: mmc1:aaaa SC32G 29.7 GiB [ 2.826259] 0x000000100000-0x0000001c0000 : "ospi.mcufw" [ 2.834255] 0x0000001c0000-0x0000007c0000 : "ospi.atf_optee" [ 2.841789] 0x0000007c0000-0x0000008c0000 : "ospi.u-boot-spl" [ 2.849040] mmcblk1: p1 p2 [ 2.853454] 0x0000008c0000-0x000000ac0000 : "ospi.u-boot" [ 2.860720] 0x000000ac0000-0x000001800000 : "ospi.reserved" [ 2.868126] 0x000001800000-0x000002000000 : "ospi.mcudata" [ 2.876116] hctosys: unable to open rtc device (rtc0) [ 2.885854] ALSA device list: [ 2.889554] No soundcards found. [ 2.914814] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.924965] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 2.941086] devtmpfs: mounted [ 2.945381] Freeing unused kernel memory: 1664K [ 2.951064] Run /sbin/init as init process [ 3.380838] systemd[1]: System time before build time, advancing clock. [ 3.505563] NET: Registered protocol family 10 [ 3.511623] Segment Routing with IPv6 [ 3.550336] systemd[1]: systemd 246 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK -SYSVINIT -UTMP -LIBCRYPTSETUP +GCRYPT +GNUTLS -ACL +XZ -LZ4 -ZSTD -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.577889] systemd[1]: Detected architecture arm64. Welcome to Buildroot 2020.11.2! [ 3.620863] systemd[1]: Set hostname to <buildroot>. [ 3.881559] systemd[1]: Queued start job for default target Multi-User System. [ 3.891059] random: systemd: uninitialized urandom read (16 bytes read) [ 3.899409] systemd[1]: system-serial\x2dgetty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling. [ 3.915898] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [ 3.928080] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 3.948310] random: systemd: uninitialized urandom read (16 bytes read) [ 3.956691] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password ��ts to Console Directory Watch. [ 3.984203] random: systemd: uninitialized urandom read (16 bytes read) [ 3.992554] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R��uests to Wall Directory Watch. [ 4.020328] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 4.036214] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 4.056198] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 4.072226] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 4.088519] systemd[1]: Listening on Syslog Socket. [ OK ] Listening on Syslog Socket. [ 4.126471] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 4.136935] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 4.156490] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 4.176556] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 4.196406] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 4.219586] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 4.239951] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.263462] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 4.280523] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 4.294308] systemd[1]: Mounting Temporary Directory (/tmp)... Mounting Temporary Directory (/tmp)... [ 4.324414] systemd[1]: Starting Create list of static device nodes for the current kernel... Starting Create list of st��odes for the current kernel... [ 4.357096] systemd[1]: Starting Journal Service... Starting Journal Service... [ 4.385685] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 4.409654] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 4.430939] cryptodev: loading out-of-tree module taints kernel. [ 4.433908] systemd[1]: Starting Coldplug All udev Devices... [ 4.446638] cryptodev: driver 1.10 loaded. Starting Coldplug All udev Devices... [ 4.467260] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Finished Create list of st�� nodes for the current kernel. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Remount Root and Kernel File Systems. Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Coldplug All udev Devices. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). [ OK ] Reached target Local File Systems. Starting Rule-based Manage��for Device Events and Files... [ OK ] Finished Flush Journal to Persistent Storage. Starting Create Volatile Files and Directories... [ OK ] Finished Create Volatile Files and Directories. [ OK ] Started Rule-based Manager for Device Events and Files. Starting Network Name Resolution... [ OK ] Reached target System Initialization. [ OK ] Started Periodic ext4 Onli��ata Check for All Filesystems. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on D-Bus System Message Bus Socket. [ 5.412583] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000 [ OK ] Reached target Sockets. [ 5.438744] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode [ OK ] Reached target Basic System. [ OK ] Started D-Bus System Message Busemoteproc remoteproc0: 4d80800000.dsp is available m. [ 5.486844] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000 Starting Remove Stale Onli��t4 Metadata Check[ 5.513377] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode Snapshots... [ 5.528034] remoteproc remoteproc1: 4d81800000.dsp is available Starting System Logging Service... [ OK ] Found device /dev/ttyS2. [ 5.572054] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000 [ 5.633163] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 5.654707] platform 41000000.r5f: ti-sci processor request failed: -19 [ 5.668287] remoteproc remoteproc2: 64800000.dsp is available [ OK ] [ 5.681378] platform 41000000.r5f: ti_sci_proc_request failed, ret = -19 Reached target Login Prompts. [ 5.691990] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: k3_r5_core_of_init failed, ret = -19 [ 5.707942] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: k3_r5_cluster_of_init failed, ret = -19 [ 5.737134] platform 5c00000.r5f: configured R5F for IPC-only mode [ 5.764264] PVR_K: 157: Read BVNC 22.104.208.318 from HW device registers [ 5.768371] platform 5c00000.r5f: assigned reserved memory node vision_apps-r5f-dma-memory@a1000000 [ 5.776643] PVR_K: 157: RGX Device initialised with BVNC 22.104.208.318 [ 5.793384] [drm] Initialized pvr 1.10.5371573 20170530 for 4e20000000.gpu on minor 0 [ 5.804753] remoteproc remoteproc3: 5c00000.r5f is available [ 5.814850] platform 5d00000.r5f: configured R5F for IPC-only mode [ 5.826041] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000 [ 5.852799] remoteproc remoteproc4: 5d00000.r5f is available [ 5.869552] platform 5e00000.r5f: configured R5F for IPC-only mode [ 5.878248] platform 5e00000.r5f: assigned reserved memory node vision_apps-r5f-dma-memory@a5000000 [ 5.890939] remoteproc remoteproc5: 5e00000.r5f is available [ 5.899411] platform 5f00000.r5f: configured R5F for IPC-only mode [ 5.908018] platform 5f00000.r5f: assigned reserved memory node vision_apps-r5f-dma-memory@a5800000 [ 5.920305] remoteproc remoteproc6: 5f00000.r5f is available [ 7.361757] remoteproc remoteproc7: b034000.pru is available [ 7.368908] pru-rproc b034000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@34000 probed successfully [ 7.381125] remoteproc remoteproc8: b004000.rtu is available [ 7.388295] pru-rproc b004000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@4000 probed successfully [ 7.400380] pru-rproc b00a000.txpru: IRQ vring not found [ 7.407043] pru-rproc b00a000.txpru: IRQ kick not found [ 7.413653] remoteproc remoteproc9: b00a000.txpru is available [ 7.421039] pru-rproc b00a000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@a000 probed successfully [ 7.434235] remoteproc remoteproc10: b038000.pru is available [ 7.441483] pru-rproc b038000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@38000 probed successfully [ 7.453652] remoteproc remoteproc11: b006000.rtu is available [ 7.461509] pru-rproc b006000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@6000 probed successfully [ 7.473529] pru-rproc b00c000.txpru: IRQ vring not found [ 7.480169] pru-rproc b00c000.txpru: IRQ kick not found [ 7.487283] remoteproc remoteproc12: b00c000.txpru is available [ 7.494749] pru-rproc b00c000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@c000 probed successfully [ 7.507286] remoteproc remoteproc13: b134000.pru is available [ 7.515102] pru-rproc b134000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@34000 probed successfully [ 7.527343] remoteproc remoteproc14: b104000.rtu is available [ 7.534566] pru-rproc b104000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@4000 probed successfully [ 7.547118] pru-rproc b10a000.txpru: IRQ vring not found [ 7.553770] pru-rproc b10a000.txpru: IRQ kick not found [ 7.560390] remoteproc remoteproc15: b10a000.txpru is available [ 7.567827] pru-rproc b10a000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@a000 probed successfully [ 7.581096] remoteproc remoteproc16: b138000.pru is available [ 7.588392] pru-rproc b138000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@38000 probed successfully [ 7.601240] remoteproc remoteproc17: b106000.rtu is available [ 7.608509] pru-rproc b106000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@6000 probed successfully [ 7.620480] pru-rproc b10c000.txpru: IRQ vring not found [ 7.627120] pru-rproc b10c000.txpru: IRQ kick not found [ 7.634339] remoteproc remoteproc18: b10c000.txpru is available [ 7.641806] pru-rproc b10c000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@c000 probed successfully [ 8.626894] remoteproc remoteproc5: powering up 5e00000.r5f [ 8.633892] remoteproc remoteproc5: Booting fw image j7-main-r5f1_0-fw, size 5627164 [ 8.643787] platform 5e00000.r5f: R5F core initialized in IPC-only mode [ 8.652065] remoteproc5#vdev0buffer: assigned reserved memory node vision_apps-r5f-dma-memory@a5000000 [ 8.664415] remoteproc5#vdev0buffer: registered virtio0 (type 7) [ 8.672062] remoteproc remoteproc5: remote processor 5e00000.r5f is now up [ 8.685126] remoteproc remoteproc6: powering up 5f00000.r5f [ 8.692184] remoteproc remoteproc6: Booting fw image j7-main-r5f1_1-fw, size 5627164 [ 8.702098] platform 5f00000.r5f: R5F core initialized in IPC-only mode [ 8.710488] remoteproc6#vdev0buffer: assigned reserved memory node vision_apps-r5f-dma-memory@a5800000 [ 8.722439] remoteproc6#vdev0buffer: registered virtio1 (type 7) [ 8.730161] remoteproc remoteproc6: remote processor 5f00000.r5f is now up [ 9.033224] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ 9.036175] random: crng init done [ 9.045756] random: 7 urandom warning(s) missed due to ratelimiting [ 9.366127] virtio_rpmsg_bus virtio0: rpmsg host is online [ 9.374057] virtio_rpmsg_bus virtio1: rpmsg host is online [ 9.380955] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 9.390105] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 9.740553] remoteproc remoteproc0: powering up 4d80800000.dsp [ 9.747908] remoteproc remoteproc1: powering up 4d81800000.dsp [ 9.755202] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 12100176 [ 9.764357] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 12100128 [ 9.774135] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode [ 9.782715] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode [ 9.791209] remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000 [ 9.802107] remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000 [ 9.815177] virtio_rpmsg_bus virtio3: rpmsg host is online [ 9.819690] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 9.822282] virtio_rpmsg_bus virtio2: rpmsg host is online [ 9.833188] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd [ 9.838719] remoteproc1#vdev0buffer: registered virtio3 (type 7) [ 9.854203] remoteproc0#vdev0buffer: registered virtio2 (type 7) [ 9.861852] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up [ 9.870774] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up [ 10.521556] remoteproc remoteproc4: powering up 5d00000.r5f [ 10.528610] remoteproc remoteproc4: Booting fw image j7-main-r5f0_1-fw, size 13976760 [ 10.538603] platform 5d00000.r5f: R5F core initialized in IPC-only mode [ 10.546871] remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000 [ 10.559321] virtio_rpmsg_bus virtio4: rpmsg host is online [ 10.566229] remoteproc4#vdev0buffer: registered virtio4 (type 7) [ 10.573841] remoteproc remoteproc4: remote processor 5d00000.r5f is now up [ 10.582568] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 10.820041] remoteproc remoteproc2: powering up 64800000.dsp [ 10.827137] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 17784560 [ 10.836447] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ 10.844725] remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000 [ 10.855996] virtio_rpmsg_bus virtio5: rpmsg host is online [ 10.858563] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd [ 10.862901] remoteproc2#vdev0buffer: registered virtio5 (type 7) [ 10.879261] remoteproc remoteproc2: remote processor 64800000.dsp is now up [ 11.247809] remoteproc remoteproc3: powering up 5c00000.r5f [ 11.254879] remoteproc remoteproc3: Booting fw image j7-main-r5f0_0-fw, size 22787812 [ 11.264866] platform 5c00000.r5f: R5F core initialized in IPC-only mode [ 11.273180] remoteproc3#vdev0buffer: assigned reserved memory node vision_apps-r5f-dma-memory@a1000000 [ 11.286647] virtio_rpmsg_bus virtio6: rpmsg host is online [ 11.293655] remoteproc3#vdev0buffer: registered virtio6 (type 7) [ 11.301359] remoteproc remoteproc3: remote processor 5c00000.r5f is now up [ 11.310261] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd [ 11.319393] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15 [ 11.328982] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15 [ 11.338224] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe [ 11.347725] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 11.356978] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 11.366480] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15 [ 11.375689] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe [ 11.385180] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 11.394355] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 11.518178] virtio_rpmsg_bus virtio6: creating channel ti.ethfw.notifyservice addr 0x1e [ 11.528352] virtio_rpmsg_bus virtio6: creating channel rpmsg-kdrv addr 0x1a [ 11.537526] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: Device info: permissions: 07FFFFFF uart_id: 2 [ 11.551186] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: FW ver 0.1 (rev 1) 1/Feb/2021 SHA:a9b626ae [ 11.574031] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded [ 11.584185] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:00000003 rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 [ 11.599283] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1 [ 11.638884] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe [ 11.662933] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: register_ipv4 rpmsg - fail -5 [ 11.681717] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started [ 11.779711] 123123213123213 Welcome to Buildroot
