Other Parts Discussed in Thread: TPS65910, TPS65218D0, TPS65217
My customer reported AM3354 power-up failure when the device is power-off then power-up again.
PMIC_POWER_EN signal from AM3354 is not asserted when the issue happens.
Please see attached excel for details.
AM3354_powerOn_failure.xlsx
I found similar issue reported below E2E, but it was not clear if the issue was understood and solved.
It discussed VRTC and RTC_PORZ timing.
https://e2e.ti.com/support/processors/f/791/t/768660
As you can see the sheet#3 in the attachment, RTC_PORZ is driven to high as soon as VRTC is on in customer’s system.
Does it cause an issue?
Thanks and regards,
Koichiro Tashiro
