Hello everybody
I'm Taeyeop from Seoul, Korea. I'm sorry to be poor at English.
I have been used TRF3702EVM(I/Q modulator) for WCDMA applications. In datasheet of TRF3702, the best performance of ACLR is 71 dBc using single-carrier WCDMA at -14 dBm channel power. The measurement set-up for this is combination of DAC5686(16 bit resolution) and TRF3702.
By the way, I use 14-bit AWG(Aribtrary waveform generator). Differences are below.
Datasheet : 16-bit DAC, differential input of TRF3702, measurement @ 2.14 GHz, Optimization of measurement circuit.
My case : 14-bit DAC, single-ended input of TRF3702, measurement @ 1.85 GHz, Using TRF3702EVM(Evaluaton board) through 0.5m cables(Both I and Q) from AWG.
These are main 4 items of difference between datasheet and my set-up. Any other set-ups are almost same and I replace proper balun for 1.85 GHz applications. I also replace some resistors with proper value. As a result, ACLR measurement value of my case is 57 dBc by Spectrum Analyzer(LG Innotek SA 930).
The problem is that I cannot retain sufficient ACLR value like datasheet, 71 dBc. If there are no any other difference from datasheet, what can I do for better linearity?
Is it possible for degradation of chip performance cause difference of set-up mentioned above?? If possible, then which part is suspicious ?
This is very important part of my research. Any kind of advises will be helpful for me.
I thank you in advance for your concern.
