Other Parts Discussed in Thread: TMDSEMU110-U
Does AWR1843BOOST work with external TI XDS110 debug probe (TMDSEMU110-u)? I could not find the manual in AWR1843Boost Manual guide.
Why do you want to use an external probe? You can connect directly to the USB port to access JTAG for debugging via the on-board emulator.
There is not really an easy way to use an external debugger with the AWR1843BOOST. The JTAG is only brought out to the 60-pin header. You would need some adapter to bring these pins out for easy access, such as a ZEBAX ZX100QTH adapter. Then you could connect your debugger to the JTAG pins brought out to the adapter.
Adrian
