I couldn't reply in the previous thread, so I created a new thread.
> Above the normal lower value, and below the normal upper value the DAC will respond based on the input and your calibration coefficients. Below the normal lower value, and above the normal upper value the DAC will be set to the lower clamping value or the upper clamping value respectively. Please refer to the Clamping section of the datasheet for more detailed descriptions.
Thank you. I understood the normal pressure lower / upper value and the clamping value.
> If you read the EEPROM data from the EEPROM read/write page, does it change in any way between the two scenarios you show in your post?
I haven't confirmed it yet, but should I read the EEPROM values before and after the change in the set values after calibration on the EEPROM page and compare them?
Should I check the EEPROM settings such as LOW_CLAMP and NORMAL_LOW on the Low Level Configuration Page?
