Dear TI team
How can I configure CAN filter to achieve range filter function.
In example of mcan which is located in MMWAVE_L_SDK_05_01_00_04\examples\drivers\mcan\mcan_external_loopback_rx_interrupt,
I changed source as below.
ASIS
static void App_mcanInitStdFilterElemParams(MCAN_StdMsgIDFilterElement *stdFiltElem, uint32_t bufNum) { /* sfid1 defines the ID of the standard message to be stored. */ stdFiltElem->sfid1 = APP_MCAN_STD_ID; /* As buffer mode is selected, sfid2 should be bufNum[0 - 63] */ stdFiltElem->sfid2 = bufNum; /* Store message in buffer */ stdFiltElem->sfec = MCAN_STD_FILT_ELEM_BUFFER; /* Below configuration is ignored if message is stored in buffer */ stdFiltElem->sft = MCAN_STD_FILT_TYPE_RANGE; return; }
AFTER CHANGE
static void App_mcanInitStdFilterElemParams(MCAN_StdMsgIDFilterElement *stdFiltElem, uint32_t bufNum) { /* sfid1 defines the ID of the standard message to be stored. */ stdFiltElem->sfid1 = 0xC0; /* . */ stdFiltElem->sfid2 = 0xCF; /* Store message in FIFO0 */ stdFiltElem->sfec = MCAN_STD_FILT_ELEM_FIFO0; /* Below configuration is ignored if message is stored in buffer */ stdFiltElem->sft = MCAN_STD_FILT_TYPE_RANGE; return; }
I intended to receive CAN message of which message id is betwenn 0xC0 to 0xCF, but failed.
( Only 0xC0 can be received )
check this please.
Best and Regards
Choi
