Hi team,
I'm using our Capon CPD demo and the Matlab GUI runs well on appimage.
I want to load Capon CPD out file by CCS and the empty.release.bin has been flashed into 6432 firstly. The cfg file can be sent by GUI while there is no TLV feedback from 6432. The cfg file is as same as used in appimage.
The SDK version is 5401, can you help look into this issue?
Shawn
Hi team,
I stop the CCS project and it's at DebugP
XDS110 shows debug stack like below.
Is there anything wrong with RF frontend?
Hey Shawn,
Please give us some time to look into this issue. For now, this may be an issue with there not being a high enough frame periodicity for the demo to finish processing a frame. Try to increase the frame periodicity of the frameCfg and see if that resolves the issue.
Kristien
Hi, Shawn:
Can you confirm that you are rebuilt with release mode instead of debug mode?
Zigang
Hi Kristien, the cfg file run well with appimage. Do we need to set different frame periodicity between appimage and out file?
HI, Shawn:
Please give me one more day to look into this problem.
Zigang
HI, Shawn:
You can find the steps for CCS lauching at xWRL6432 MMWAVE-L-SDK: CCS Launch, Load and Run
You will need to check your switch setting. You can find the documentation at radar toolbox at:
https://dev.ti.com/tirex/explore/node?node=A__ACzleIuZ4g1GuBmtlq-cGg__radar_toolbox__1AslXXD__LATEST
Let me know if it solves your problem.
Zigang
Zigang
Hi Zigang,
I believe I set a wrong SOP mode. My S1.3 is ON and I turn it to Off, it works.
Shawn
