Hello E2E Experts,
Good day.
I plan to work with the IWR6843AOP radar sensor and planning to use its ROS driver for data integration. I have a few questions regarding its timing characteristics:
Data latency: How long does it typically take for the radar to process the reflected electromagnetic waves and send the processed data to the computer? I understand that this involves the onboard computation time of the radar. Is there an average or estimated value for this delay?
ROS timestamps: When using the ROS driver for the IWR6843AOP, does the driver assign the computer’s clock timestamp to the messages (e.g., when reading from the serial/USB port)? If so, I guess then that timestamps do not reflect the "real" timestamps of data arrival. Is there an average or estimated value for this delay?
IMU synchronization: I want to hardware-trigger the radar in sync with an IMU. Is there any guidance or best practice for achieving precise synchronization in such a setup, considering the potential processing and communication latencies of the radar?
Any insights into the average radar processing time and the behavior of the ROS driver regarding timestamps would be greatly appreciated!
TICSC
