Compiler/LDC1101: LDC1101
Part Number: LDC1101
After setting and taking data using EVM of LDC1101, LDC1101 is connected to this CPU and controlled.
After setting, you can get RP_DATA only the first time. The rest will be 0.
The power supply voltage is 3.3V.
The content of STATUS is 0x1C, but 2 bytes from DATA_LSB (0x21) is 0.
I want to convert and read data continuously. What is the cause?
    Can you share your schematic and sensor details? It would be very helpful to have the following information:
    1. Rp measurement of your coil at the resonant frequency of your LC tank. See here for instructions.
    2. Oscilloscope captures of your sensor oscillations.
  • Thank you very much.
    We will send data using LDC1101EVM.
    There are three types of coils, tests, and capacitors.
    Tested with this circuit with the same content and a voltage of 3.3
    The data cannot be retrieved successfully. Do I need to change the setting by changing the voltage?
    差出人: Kristin Jones93 <bounce-4996845@mail.e2e.ti.com>
    送信日時: 2019年10月26日 3:33
    宛先: mmwave_sensors_forum@mail.e2e.ti.com <mmwave_sensors_forum@mail.e2e.ti.com>
    件名: Sensors forum: Compiler/LDC1101: LDC1101
    A Message from the TI E2E™ support forums
    Texas Instruments
    Kristin Jones93 replied to Compiler/LDC1101: LDC1101.
    Kristin Jones
    Current and Position Sensing
    Applications Engineer
    For more information, check out the Inductive Sensing FAQ
    You received this notification because you subscribed to the forum.  To unsubscribe from only this thread, go here.
    Flag this post as spam/abuse.
    refid:7bc8f94c-e3ca-4457-9cec-ac313b49f9a4
  • I'm sorry. It was a malfunction due to a defective new cable. It was confirmed that it works by replacing the cable.
    Texas Instruments
    Kristin Jones
  • I'm glad to hear that you were able to solve your issue!
