how should I handle not connected pins like VCCP2/D2-, FAN1/AIN1 etc for this device?
floating/grounding?
Thanks for your quick help,
Marion
floating/grounding?
Marion
HI Marion,
Grounding or floating these pins may cause undesired faults/interrupts. You can use the respective masks bits in the mask registers to disable the interrupts.
David
Hi David,
thanks for your quick reply,
Should then we terminate these pins to VCC or where to?
Kind regards,
Marion
Marion,
Terminating these pins to VCC will also cause faults/interrupts. I would see if connecting to ground and using the the respective masks bits for the interrupts that occur from those pins will work for your application.
David
