Other Parts Discussed in Thread: FDC1004, LDC1101, LDC1612, LDC1312
Hello team,
Let me ask if there is any good application note or recommendation design examples in the following use case.
1) I think the sensor input pair should be twist paired as far as possible to avoid unlike noise effect, but it there is a physical isolation to make it difficult like an attached image, is there any good use case example?
2) When the PCB mounted the FDC is battery powered and isolated to the host, is there any limitation or application notice?
Thanks in advance.
S.Sawamoto
