I want to use the sensor configuration tool to see the result of the post-processing of the signal and here is my mmWave Studio window:
I followed the steps on the mmWave Studio Guide, but when I set the Frame I got this output:
GM: Constructor
GM: Thu Dec 20 18:26:35 2018
RSTD.Transmit("/Settings")
[18:26:36]
[18:26:36] ### Running Startup script: "D:\mmwave_studio_01_00_00_00\mmWaveStudio\Scripts\Startup.lua" ###
[18:26:36] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[18:26:36] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[18:26:36] Scripter ignored: Attempt to UnBuild() again or before Build.
[18:26:36] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "D:\\mmwave_studio_01_00_00_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[18:26:36] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[18:26:36] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[18:26:36] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[18:26:36] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[18:26:36] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[18:26:36] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "D:\\mmwave_studio_01_00_00_00\\mmWaveStudio\\RunTime\\SAL.dll")
[18:26:36] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[18:26:36] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[18:26:36] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[18:26:36] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[18:26:36] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[18:26:36] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[18:26:36] RSTD.Transmit("/")
[18:26:36] RSTD.SaveSettings(): Settings saved to "C:\Users\HP\AppData\Roaming\RSTD\config.xml"
[18:26:36] RSTD.Build()
[18:26:36] RSTD.AL_Build()
[18:26:36] RSTD.AL_LoadXml()
[18:26:36] RSTD.AL_Init()
[18:26:36] RSTD.Clients_Build()
[18:26:36] GM: Init
[18:26:36] GM: Loaded 'D:\mmwave_studio_01_00_00_00\mmWaveStudio\Clients\\LabClient.dll'
[18:26:36] GM: 1 Guest (s) init
[18:26:36] GM: 1 Module(s) init
[18:26:36] GM: 2 Tab (s) init
[18:26:36] RSTD.Client_LoadXml()
[18:26:37] [RadarAPI]: Starting Matlab Engine..
[18:26:58] [RadarAPI]: Matlab Engine Started!
[18:27:02] [RadarAPI]: ar1.LoadSettings('C:\Users\HP\AppData\Roaming\RSTD\ar1gui.ini')
[18:27:02] TESTING = false
[18:27:02]
[18:27:02] ***Script completed successfully.***
[18:27:05] [RadarAPI]: Opening Gpio Control Port()
[18:27:05] [RadarAPI]: Status: Passed
[18:27:05] [RadarAPI]: Opening Board Control Port()
[18:27:07] [RadarAPI]: ar1.FullReset()
[18:27:07] [RadarAPI]: Status: Passed
[18:27:07] [RadarAPI]: Closing Board Control Port()
[18:27:07] [RadarAPI]: Closing Gpio Control Port()
[18:27:07] [RadarAPI]: ar1.SOPControl(2)
[18:27:08] [RadarAPI]: ar1.Connect(3,921600,1000)
[18:27:11] [RadarAPI]: Warning: Connected with baudrate 115200
[18:27:12] [RadarAPI]: Warning: Disconnected existing BaudRate
[18:27:12] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[18:27:13] [RadarAPI]: ar1.Calling_IsConnected()
[18:27:14] [RadarAPI]: ar1.SelectChipVersion("XWR1443")
[18:27:14] [RadarAPI]: Status: Passed
[18:27:15] [RadarAPI]: ar1.SelectChipVersion("XWR1443")
[18:27:15] [RadarAPI]: Status: Passed
[18:27:16] [RadarAPI]: ar1.SaveSettings('C:\Users\HP\AppData\Roaming\RSTD\ar1gui.ini')
[18:27:17] [RadarAPI]: ar1.DownloadBSSFw("D:\\mmwave_studio_01_00_00_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\radarss\\xwr12xx_xwr14xx_radarss_ES2.0.bin")
[18:27:17] [RadarAPI]: Downloading BSS ROM Legacy Binary..
[18:27:24] [RadarAPI]: ar1.DownloadMSSFw("D:\\mmwave_studio_01_00_00_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\masterss\\xwr12xx_xwr14xx_masterss_ES2.0.bin")
[18:27:24] [RadarAPI]: Downloading MSS Legacy Binary..
[18:27:29] MSS power up done async event received!
[18:27:29] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[18:27:29] [RadarAPI]: Status: Passed
[18:27:29] [RadarAPI]: ar1.SaveSettings('C:\Users\HP\AppData\Roaming\RSTD\ar1gui.ini')
[18:27:30] BSS power up done async event received!
[18:27:30] [RadarAPI]: ar1.RfEnable()
[18:27:30] [RadarAPI]: Status: Passed
[18:27:32] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[18:27:32] [RadarAPI]: passed
[18:27:32] [RadarAPI]: StatusDCCard Event Registered
[18:27:33] [RadarAPI]: Status: Passed
[18:27:33] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[18:27:33] [RadarAPI]: SYSTEM_CONNECT_CMD_CODE Async event recieved(9)
[18:27:33] [RadarAPI]: ConnectRFDCCard Status: Passed
[18:27:33] [RadarAPI]: ReadRFDCCarFpgaVersion Status: Passed
[18:27:33] [RadarAPI]: READ_FPGA_VERSION_CMD_CODE event recieved(14)
[18:27:33] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 1, 1, 2, 3, 0)
[18:27:33] [RadarAPI]: CONFIG_FPGA_GEN_CMD_CODE Async event recieved(3)
[18:27:33] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[18:27:33] [RadarAPI]: CONFIG_PACKET_DATA_CMD_CODE Async event recieved(11)
[18:27:38] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 2, 0)
[18:27:38] [RadarAPI]: Status: Passed
[18:27:39] [RadarAPI]: ar1.LPModConfig(0, 0)
[18:27:39] [RadarAPI]: Status: Passed
[18:27:40] [RadarAPI]: ar1.RfInit()
[18:27:40] RF Init async event received!
[18:27:40] [RadarAPI]: Time stamp, Temperture: 10209,54; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[18:27:40] [RadarAPI]: Status: Passed
[18:27:40] [RadarAPI]: ar1.RfSetCalMonFreqTxPowLimitConfig(76, 76, 76, 81, 81, 81, 0, 0, 0)
[18:27:43] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[18:27:43] [RadarAPI]: Status: Passed
[18:27:44] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[18:27:44] [RadarAPI]: Status: Passed
[18:27:45] [RadarAPI]: ar1.SetTestPatternConfig(0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0)
[18:27:45] [RadarAPI]: Status: Passed
[18:27:51] [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 0, 30)
[18:27:51] [RadarAPI]: Status: Passed
[18:27:55] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[18:27:55] [RadarAPI]: Status: Passed
[18:27:59] [RadarAPI]: ar1.DisableTestSource(0)
[18:27:59] [RadarAPI]: Status: Passed
[18:27:59] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 1)
[18:27:59] [RadarAPI]: Matlab process exception
[18:27:59] [RadarAPI]: Error:
[18:27:59]
[18:27:59] ... MWMCR::EvaluateFunction error ...
[18:27:59] Reference to non-existent field 'LaneConfig'.
[18:27:59] Error in => IsConfigInvalid.m at line 41.
[18:27:59]
[18:27:59] ... Matlab M-code Stack Trace ...
[18:27:59] at
[18:27:59] file C:\Users\HP\AppData\Local\Temp\HP\mcrCache8.5.1\Matlab1\Processing_functions\prepare_frame.m, name compute_size_per_burst_size, line 64.
[18:27:59] at
[18:27:59] file C:\Users\HP\AppData\Local\Temp\HP\mcrCache8.5.1\Matlab1\Processing_functions\prepare_frame.m, name compute_frame_sizes, line 45.
[18:27:59] at
[18:27:59] file C:\Users\HP\AppData\Local\Temp\HP\mcrCache8.5.1\Matlab1\Processing_functions\prepare_frame.m, name prepare_frame, line 19.
[18:27:59] at
[18:27:59] file C:\Users\HP\AppData\Local\Temp\HP\mcrCache8.5.1\Matlab1\Processing_functions\create_current_burst_config.m, name create_current_burst_config, line 5.
[18:27:59] at
[18:27:59] file C:\Users\HP\AppData\Local\Temp\HP\mcrCache8.5.1\Matlab1\Processing_functions\populate_current_burst_constants.m, name populate_current_burst_constants, line 11.
[18:27:59] at
[18:27:59] file C:\Users\HP\AppData\Local\Temp\HP\mcrCache8.5.1\Matlab1\MatlabPostPr\IsConfigInvalid.m, name IsConfigInvalid, line 41.
[18:27:59]
[18:27:59]
[18:27:59] Trace:
[18:27:59] 在 MathWorks.MATLAB.NET.Utility.MWMCR.EvaluateFunction(String functionName, Int32 numArgsOut, Int32 numArgsIn, MWArray[] argsIn)
[18:27:59] 在 MathWorks.MATLAB.NET.Utility.MWMCR.EvaluateFunction(String functionName, MWArray[] argsIn)
[18:27:59] 在 MatlabPostProcGui.MatlabPostProcGUIClass.IsConfigInvalid()
[18:27:59] 在 AR1xController.ScriptOps.iSetFrameConfig_Impl(Boolean is_starting_op, Boolean is_ending_op)
When I used Continuous Stream Tool the same problem showed up. I'm a beginner at mmWave Studio and I don`t know what's going on. I hope you can help me with this problem and thank you so much.
Elsie
