Other Parts Discussed in Thread: TMUX1209
Hi team,
Could you check if the unit for tON(EN) is correct for TMUX1574?
My customer thinks the unit should be ns order, not us.
Itoh
Hi Itoh,
As Clemens mentioned, Figures 17/18/19 confirm that tON(EN) is in the microsecond range. The exact tON/tOFF time will be influenced by the load on the signal path.
Tyler
Hi Clemens-san, Tyler-san,
Thank you for your reply.
TMUX1209's tON(EN) is in ns order with similar load.
Could you let me know what is the cause of this huge difference?
Itoh
The TMUX1209 does not allow signal voltages above VDD.
The TMUX1574 uses a charge pump to double the power supply voltage. Such a switching power supply needs some time to start up.
