Other Parts Discussed in Thread: TS5A21366
I am looking for a solution for I2C Muxing between SoC and MCU.
When the SoC is on, it is master to both MCU’s I2Cs. But when SoC is powered off, switch would flip and have the MCUs be able to communicate; like MCU1 becoming master to MCU2 - The SOC will likely pull the lines low when it’s off - See block diagram below:
- Can I use the TMUX1574 since one of their main careabouts is size?
- Will the TMUX1574 work with open drain signals?
- Do you know how this could be implemented more robustly?
