Other Parts Discussed in Thread: TS5USBA224
Hello E2E,
I have a customer who found that the amplitude of the audio signal is limited to whatever the Vaudio pin Voltage is. For example, he was feeding a 4Vpp audio signals into the switch chip's R and L input pins and getting a squashed/distorted 3Vpp audio signals out of the D+/R and D-/L output pins when using a 3.3V supply. This went away when he switched to a 5V supply.
From the datasheet block diagram, it looks like Vaudio is just connected to control logic, but the system seems to mimic behavior of an op-amp. Why does the TS5USBA224 limit the audio signal swing to whatever the Vaudio pin Voltage is? We thought there were just simple FET switches inside.
Thank you very much!
Russell
