Other Parts Discussed in Thread: CODECOMPOSER
Hello
on a fresh configured PC (Win7) with a clean installation of CCS 6.1.1.00022 I discovered the following issue:
When trying to test the connection to the emulator in the following dialog:
I get the following error message:
I guess the reason for this is that the %boarddatafile% variable points to the default directory location somewhere in "C:\Users\sber\AppData\Local\Texas Instruments\CCS" and this path contains a white space...
(The configuration is saved in another directory without any white spaces in the path)
Is there a way to manually change this default path?
Thanks a lot,
Bernd
