At the advice of TI, I upgraded from CCSv7 to v8 (uninstalling v7 as recommended).
I reloaded PDK and other supporting packages.
I rebuild PDK per the instructions.
Applications no longer build; build output is below. This app runs on the ARM for a KH2 processor; TI_RTOS based.
I had posted this question before. I finally gave up with that thread and employed a workaround (this was on a different piece of code; much smaller). I cannot do that with this project.
Why is the build unable to find __locale_ctype_ptr and also __synch_synchronize? See the error messages, in red, near the bottom of the build output.
Thank you
**** Clean-only build of configuration Debug for project panel_arm0 ****
"C:\\ti\\ccsv8\\utils\\bin\\gmake" -j 4 clean -O
cleaning ../src/utils ...
cleaning ../src/sysbios ...
DEL /F "panel_arm0.hex" "configPkg\linker.cmd" "configPkg\compiler.opt" "panel_arm0.out"
RMDIR /S/Q "configPkg\"
DEL /F "drv\accel\Accelerometer.o" "drv\flash\flashDriver.o" "drv\flash\flashLog.o" "drv\flash\flashMap.o" "drv\flash\flashParams.o" "drv\flash\nandDriver.o" "drv\netstack\network.o" "drv\netstack\nimu_cppi_qmss_iface.o" "drv\netstack\nimu_osal.o" "drv\netstack\nimu_pa_iface.o" "drv\pcie\pcieDriver.o" "drv\pcie\pcieInt.o" "drv\radar\radarDriver.o" "gpr_interface_protocol\exception.o" "gpr_interface_protocol\free_msg_q.o" "gpr_interface_protocol\gip_message.o" "gpr_interface_protocol\gip_protocol.o" "gpr_interface_protocol\gip_server.o" "panel_controller\gip\cmd_msg_hndlr.o" "panel_controller\gip\data_msg_hndlr.o" "panel_controller\gip\gip.o" "panel_controller\gip\panel_state.o" "panel_controller\gip\raw_msg_hndlr.o" "panel_controller\gip\retransmit_q.o" "panel_controller\gpr\daq_interface.o" "panel_controller\gpr\gpr.o" "panel_controller\panel_controller.o" "panel_controller\panel_network.o" "panel_controller\panel_storage\storage.o" "panel_controller\system_health\ibit.o" "panel_controller\system_health\panel_cbit.o"
DEL /F "panel_controller\system_health\pbit.o" "panel_controller\system_health\system_health.o" "panel_data_acq\panel_data_acq.o" "shared\SharedMemory.o" "storage\log_buffer.o" "storage\runtime_parameter.o" "util\crc32.o" "util\data_buffer.o" "util\data_q.o" "util\ecc.o" "util\exceptions.o" "util\string.o" "util\threads.o" "util\timesync.o" "util\worker.o"
DEL /F "drv\flash\flashDriver.d" "drv\flash\flashLog.d" "drv\flash\flashMap.d" "drv\flash\flashParams.d" "drv\flash\nandDriver.d" "drv\netstack\network.d" "drv\netstack\nimu_cppi_qmss_iface.d" "drv\netstack\nimu_osal.d" "drv\netstack\nimu_pa_iface.d" "drv\pcie\pcieDriver.d" "drv\pcie\pcieInt.d" "drv\radar\radarDriver.d" "panel_controller\panel_network.d" "util\ecc.d" "util\timesync.d"
DEL /F "drv\accel\Accelerometer.d" "gpr_interface_protocol\exception.d" "gpr_interface_protocol\free_msg_q.d" "gpr_interface_protocol\gip_message.d" "gpr_interface_protocol\gip_protocol.d" "gpr_interface_protocol\gip_server.d" "panel_controller\gip\cmd_msg_hndlr.d" "panel_controller\gip\data_msg_hndlr.d" "panel_controller\gip\gip.d" "panel_controller\gip\panel_state.d" "panel_controller\gip\raw_msg_hndlr.d" "panel_controller\gip\retransmit_q.d" "panel_controller\gpr\daq_interface.d" "panel_controller\gpr\gpr.d" "panel_controller\panel_controller.d" "panel_controller\panel_storage\storage.d" "panel_controller\system_health\ibit.d" "panel_controller\system_health\panel_cbit.d" "panel_controller\system_health\pbit.d" "panel_controller\system_health\system_health.d" "panel_data_acq\panel_data_acq.d" "shared\SharedMemory.d" "storage\log_buffer.d" "storage\runtime_parameter.d" "util\crc32.d" "util\data_buffer.d" "util\data_q.d" "util\exceptions.d" "util\string.d" "util\threads.d" "util\worker.d"
Could Not Find C:\Users\Tim Cooper\Documents\Chemring\git_panel_integ_20180727\panel_arm0\Debug\panel_arm0.hex
Could Not Find C:\Users\Tim Cooper\Documents\Chemring\git_panel_integ_20180727\panel_arm0\Debug\panel_arm0.out
Finished clean
**** Build Finished ****
**** Build of configuration Debug for project panel_arm0 ****
"C:\\ti\\ccsv8\\utils\\bin\\gmake" -j 4 all -O
Building file: "../arm0.cfg"
Invoking: XDCtools
"C:/ti/xdctools_3_50_03_33_core/xs" --xdcpath="C:/ti/bios_6_50_01_12/packages;C:/ti/ipc_3_47_01_00/packages;C:/ti/xdctools_3_50_03_33_core/packages;C:/ti/ndk_2_26_00_08/packages;C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/packages;C:/ti/edma3_lld_2_12_05_30C/packages;C:/ti/pdk_k2hk_4_0_9/packages;C:/ti/uia_2_21_02_07/packages;C:/ti/xdais_7_24_00_04/packages;C:/ti/xdais_7_24_00_04/examples;C:/ti/ccsv8/ccs_base;" xdc.tools.configuro -o configPkg -t gnu.targets.arm.A15F -p ti.platforms.evmTCI6636K2H:host -r debug -b "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared/config_panel.bld" -c "C:/ti/gcc-arm-none-eabi-6-2017-q1-update" --cfgArgs "{procList: \"host core0 core4\", profile: \"release\"}" "../arm0.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring arm0.xa15fg from package/cfg/arm0_pa15fg.cfg ...
generating custom ti.sysbios library makefile ...
generating custom ti.sdo.utils library makefile ...
Inside EDMA3 Drv Sample getLibs
will link with ti.sdo.edma3.drv.sample:lib/tci6636k2h-evm/a15/debug/edma3_lld_drv_sample.aa15fg
Linking with library ti.board:./lib/evmK2H/a15/release/ti.board.aa15fg
Linking with library ti.drv.uart:./lib/k2h/a15/release/ti.drv.uart.aa15fg
Linking with library ti.drv.i2c:./lib/k2h/a15/release/ti.drv.i2c.aa15fg
Inside EDMA3 Drv getLibs
will link with ti.sdo.edma3.drv:lib/a15/debug/edma3_lld_drv.aa15fg
Inside EDMA3 RM getLibs
will link with ti.sdo.edma3.rm:lib/tci6636k2h-evm/a15/debug/edma3_lld_rm.aa15fg
Linking with library ti.drv.pcie:./lib/a15/release/ti.drv.pcie.profiling.aa15fg
Linking with library ti.utils.profiling:./lib/a15/release/ti.utils.profiling.aa15fg
Linking with library ti.transport.ndk.nimu:./lib/k2h/a15/release/ti.transport.ndk.nimu.aa15fg
Linking with library ti.drv.pa:./lib/armv7/ti.drv.pa.aa15fg
Linking with library ti.drv.qmss:./lib/armv7/ti.drv.qmss.aa15fg
Linking with library ti.drv.cppi:./lib/armv7/ti.drv.cppi.aa15fg
Linking with library ti.osal:./lib/tirtos/k2h/a15/release/ti.osal.aa15fg
Linking with library ti.csl:./lib/k2h/a15/release/ti.csl.aa15fg
Starting build of library sources ...
making C:/Users/TIMCOO~1/Documents/Chemring/git_panel_integ_20180727/panel_arm0/src/sysbios/sysbios.aa15fg ...
gmake[1]: Entering directory `C:/Users/TIMCOO~1/Documents/Chemring/git_panel_integ_20180727/panel_arm0/src/sysbios'
asma15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/IntrinsicsSupport_asm_gnu.asm ...
asma15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/TaskSupport_asm_gnu.asm ...
asma15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/timers/timer64/Timer_asm_gnu.sv7A ...
asma15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/gic/Hwi_asm_gnu.asm ...
asma15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/exc/Exception_asm_gnu.asm ...
asma15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/systimer/Timer_asm_gnu.asm ...
asma15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/a15/Cache_asm_gnu.asm ...
asma15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/a15/Mmu_asm_gnu.asm ...
asma15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/a15/TimestampProvider_asm_gnu.asm ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/BIOS.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/IntrinsicsSupport.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/TaskSupport.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Clock.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Idle.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Intrinsics.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Event.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Mailbox.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Queue.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Semaphore.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Swi.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Swi_andn.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/knl/Task.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/hal/Cache.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/hal/Core.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/hal/Hwi.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/hal/Hwi_stack.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/hal/Hwi_startup.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/heaps/HeapMem.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/gates/GateHwi.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/gates/GateAll.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/gates/GateSwi.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/gates/GateMutexPri.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/gates/GateMutex.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/rts/gnu/ReentSupport.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/rts/gnu/SemiHostSupport.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/timers/timer64/Timer.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/gic/Hwi.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/exc/Exception.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/systimer/Timer.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/syncs/SyncSem.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/a15/Core.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/a15/Cache.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/a15/Mmu.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/a15/TimerSupport.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/family/arm/a15/TimestampProvider.c ...
cla15fg C:/ti/bios_6_50_01_12/packages/ti/sysbios/xdcruntime/GateThreadSupport.c ...
ara15fg arm_IntrinsicsSupport_asm_gnu.o arm_TaskSupport_asm_gnu.o timer64_Timer_asm_gnu.o gic_Hwi_asm_gnu.o exc_Exception_asm_gnu.o systimer_Timer_asm_gnu.o a15_Cache_asm_gnu.o a15_Mmu_asm_gnu.o a15_TimestampProvider_asm_gnu.o _BIOS.o arm_IntrinsicsSupport.o arm_TaskSupport.o knl_Clock.o knl_Idle.o knl_Intrinsics.o knl_Event.o knl_Mailbox.o knl_Queue.o knl_Semaphore.o knl_Swi.o knl_Swi_andn.o knl_Task.o hal_Cache.o hal_Core.o hal_Hwi.o hal_Hwi_stack.o hal_Hwi_startup.o heaps_HeapMem.o gates_GateHwi.o gates_GateAll.o gates_GateSwi.o gates_GateMutexPri.o gates_GateMutex.o gnu_ReentSupport.o gnu_SemiHostSupport.o timer64_Timer.o gic_Hwi.o exc_Exception.o systimer_Timer.o syncs_SyncSem.o a15_Core.o a15_Cache.o a15_Mmu.o a15_TimerSupport.o a15_TimestampProvider.o xdcruntime_GateThreadSupport.o ...
gmake[1]: Leaving directory `C:/Users/TIMCOO~1/Documents/Chemring/git_panel_integ_20180727/panel_arm0/src/sysbios'
making C:/Users/TIMCOO~1/Documents/Chemring/git_panel_integ_20180727/panel_arm0/src/utils.aa15fg ...
gmake[1]: Entering directory `C:/Users/TIMCOO~1/Documents/Chemring/git_panel_integ_20180727/panel_arm0/src/utils'
cla15fg C:/ti/ipc_3_47_01_00/packages/ti/sdo/utils/UTILS.c ...
cla15fg C:/ti/ipc_3_47_01_00/packages/ti/sdo/utils/NameServer.c ...
cla15fg C:/ti/ipc_3_47_01_00/packages/ti/sdo/utils/NameServerRemoteNull.c ...
cla15fg C:/ti/ipc_3_47_01_00/packages/ti/sdo/utils/MultiProc.c ...
cla15fg C:/ti/ipc_3_47_01_00/packages/ti/sdo/utils/List.c ...
ara15fg utils_UTILS.o utils_NameServer.o utils_NameServerRemoteNull.o utils_MultiProc.o utils_List.o ...
gmake[1]: Leaving directory `C:/Users/TIMCOO~1/Documents/Chemring/git_panel_integ_20180727/panel_arm0/src/utils'
Build of libraries done.
cla15fg package/cfg/arm0_pa15fg.c ...
Finished building: "../arm0.cfg"
1 file(s) copied.
making ../src/sysbios/sysbios.aa15fg ...
gmake[1]: Nothing to be done for 'all'.
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashLog.c"
Invoking: GNU Compiler
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/flash/flashLog.d" -MT"drv/flash/flashLog.o" @"configPkg/compiler.opt" -o"drv/flash/flashLog.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashLog.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashLog.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashDriver.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/flash/flashDriver.d" -MT"drv/flash/flashDriver.o" @"configPkg/compiler.opt" -o"drv/flash/flashDriver.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashDriver.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashDriver.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashMap.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/flash/flashMap.d" -MT"drv/flash/flashMap.o" @"configPkg/compiler.opt" -o"drv/flash/flashMap.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashMap.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashMap.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashParams.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/flash/flashParams.d" -MT"drv/flash/flashParams.o" @"configPkg/compiler.opt" -o"drv/flash/flashParams.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashParams.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/flashParams.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/nandDriver.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/flash/nandDriver.d" -MT"drv/flash/nandDriver.o" @"configPkg/compiler.opt" -o"drv/flash/nandDriver.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/nandDriver.c"
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/nandDriver.c:669:13: warning: '_nandWriteByte' defined but not used [-Wunused-function]
static void _nandWriteByte (uint8_t uchData)
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/flash/nandDriver.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/accel/Accelerometer.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/accel/Accelerometer.d" -MT"drv/accel/Accelerometer.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"drv/accel/Accelerometer.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/accel/Accelerometer.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/accel/Accelerometer.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/network.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/netstack/network.d" -MT"drv/netstack/network.o" @"configPkg/compiler.opt" -o"drv/netstack/network.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/network.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/network.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/nimu_cppi_qmss_iface.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/netstack/nimu_cppi_qmss_iface.d" -MT"drv/netstack/nimu_cppi_qmss_iface.o" @"configPkg/compiler.opt" -o"drv/netstack/nimu_cppi_qmss_iface.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/nimu_cppi_qmss_iface.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/nimu_cppi_qmss_iface.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/nimu_pa_iface.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/netstack/nimu_pa_iface.d" -MT"drv/netstack/nimu_pa_iface.o" @"configPkg/compiler.opt" -o"drv/netstack/nimu_pa_iface.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/nimu_pa_iface.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/nimu_pa_iface.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/nimu_osal.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/netstack/nimu_osal.d" -MT"drv/netstack/nimu_osal.o" @"configPkg/compiler.opt" -o"drv/netstack/nimu_osal.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/nimu_osal.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/netstack/nimu_osal.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/pcie/pcieInt.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/pcie/pcieInt.d" -MT"drv/pcie/pcieInt.o" @"configPkg/compiler.opt" -o"drv/pcie/pcieInt.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/pcie/pcieInt.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/pcie/pcieInt.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/radar/radarDriver.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/radar/radarDriver.d" -MT"drv/radar/radarDriver.o" @"configPkg/compiler.opt" -o"drv/radar/radarDriver.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/radar/radarDriver.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/radar/radarDriver.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/pcie/pcieDriver.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"drv/pcie/pcieDriver.d" -MT"drv/pcie/pcieDriver.o" @"configPkg/compiler.opt" -o"drv/pcie/pcieDriver.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/pcie/pcieDriver.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/drv/pcie/pcieDriver.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/exception.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"gpr_interface_protocol/exception.d" -MT"gpr_interface_protocol/exception.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"gpr_interface_protocol/exception.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/exception.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/exception.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_protocol.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"gpr_interface_protocol/gip_protocol.d" -MT"gpr_interface_protocol/gip_protocol.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"gpr_interface_protocol/gip_protocol.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_protocol.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_protocol.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/free_msg_q.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"gpr_interface_protocol/free_msg_q.d" -MT"gpr_interface_protocol/free_msg_q.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"gpr_interface_protocol/free_msg_q.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/free_msg_q.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/free_msg_q.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_message.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"gpr_interface_protocol/gip_message.d" -MT"gpr_interface_protocol/gip_message.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"gpr_interface_protocol/gip_message.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_message.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_message.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_server.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"gpr_interface_protocol/gip_server.d" -MT"gpr_interface_protocol/gip_server.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"gpr_interface_protocol/gip_server.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_server.cpp"
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_server.cpp:210:2: warning: #warning BUG : greeting not sent when new client connects and replaces existing client. [-Wcpp]
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_server.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/gip/cmd_msg_hndlr.d" -MT"panel_controller/gip/cmd_msg_hndlr.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/gip/cmd_msg_hndlr.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.cpp"
In file included from c:\users\tim cooper\documents\chemring\git_panel_integ_20180727\panel_controller\gpr\daq_interface.h:38:0,
from c:\users\tim cooper\documents\chemring\git_panel_integ_20180727\panel_controller\gpr\gpr_exports.h:30,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/cbit.h:29,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/gpr_interface_protocol/gip_panel_msgs.h:33,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.h:31,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.cpp:35:
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp/PDSP.h:36:2: warning: #warning setting radar to slower rate for now [-Wcpp]
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.cpp:857:2: warning: #warning How to get CPU ticks used and idle [-Wcpp]
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.cpp:880:2: warning: #warning what is CPU time Sync State? [-Wcpp]
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.cpp:885:2: warning: #warning need ptr to radar time [-Wcpp]
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.cpp:890:2: warning: #warning what is Radar time Sync State? [-Wcpp]
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.cpp:895:2: warning: #warning where do frame stacking stats come from? [-Wcpp]
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/cmd_msg_hndlr.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/data_msg_hndlr.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/gip/data_msg_hndlr.d" -MT"panel_controller/gip/data_msg_hndlr.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/gip/data_msg_hndlr.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/data_msg_hndlr.cpp"
In file included from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/data_msg_hndlr.h:33:0,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/data_msg_hndlr.cpp:33:
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp/PDSP.H:36:2: warning: #warning setting radar to slower rate for now [-Wcpp]
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/data_msg_hndlr.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/gip.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/gip/gip.d" -MT"panel_controller/gip/gip.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/gip/gip.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/gip.cpp"
In file included from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/daq_msgs.h:32:0,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/gip_exports.h:30,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/panel_state.h:31,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/gip.h:32,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/gip.cpp:33:
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/gip.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/panel_state.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/gip/panel_state.d" -MT"panel_controller/gip/panel_state.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/gip/panel_state.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/panel_state.cpp"
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/panel_state.cpp:29:
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/panel_state.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/retransmit_q.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/gip/retransmit_q.d" -MT"panel_controller/gip/retransmit_q.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/gip/retransmit_q.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/retransmit_q.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/retransmit_q.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/raw_msg_hndlr.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/gip/raw_msg_hndlr.d" -MT"panel_controller/gip/raw_msg_hndlr.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/gip/raw_msg_hndlr.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/raw_msg_hndlr.cpp"
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/raw_msg_hndlr.h:32,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/raw_msg_hndlr.cpp:37:
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gip/raw_msg_hndlr.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/daq_interface.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/gpr/daq_interface.d" -MT"panel_controller/gpr/daq_interface.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/gpr/daq_interface.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/daq_interface.cpp"
In file included from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/daq_interface.h:38:0,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/daq_interface.cpp:39:
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/daq_interface.cpp:231:2: warning: #warning Need to get frame info back from skyshot later [-Wcpp]
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/daq_interface.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_network.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/panel_network.d" -MT"panel_controller/panel_network.o" @"configPkg/compiler.opt" -o"panel_controller/panel_network.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_network.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_network.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/ibit.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/system_health/ibit.d" -MT"panel_controller/system_health/ibit.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/system_health/ibit.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/ibit.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/ibit.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/gpr/gpr.d" -MT"panel_controller/gpr/gpr.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/gpr/gpr.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp"
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp:36:
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp:474:2: warning: #warning register_parameters pdsp_residual_running_mean fails!!!! Removing for now [-Wcpp]
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp: In member function 'bool gpr::pdspGetStatus()':
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp:265:18: warning: comparison of constant '0' with boolean expression is always false [-Wbool-compare]
if ( success < 0)
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp: In member function 'bool gpr::pdspConfigure()':
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp:277:18: warning: comparison of constant '0' with boolean expression is always false [-Wbool-compare]
if ( success < 0)
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp: In member function 'bool gpr::pdspRun(PDSP_MODES)':
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp:289:18: warning: comparison of constant '0' with boolean expression is always false [-Wbool-compare]
if ( success < 0)
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp: In member function 'bool gpr::pdspStop()':
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp:301:18: warning: comparison of constant '0' with boolean expression is always false [-Wbool-compare]
if ( success < 0)
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp: In member function 'bool gpr::pdspStdFrame(timestamp)':
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp:314:18: warning: comparison of constant '0' with boolean expression is always false [-Wbool-compare]
if ( success < 0)
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp: In member function 'bool gpr::pdspStdFrame(uint32_t)':
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp:326:18: warning: comparison of constant '0' with boolean expression is always false [-Wbool-compare]
if ( success < 0)
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp: In member function 'bool gpr::pdspLgvFrame(timestamp)':
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp:338:18: warning: comparison of constant '0' with boolean expression is always false [-Wbool-compare]
if ( success < 0)
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_storage/storage.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/panel_storage/storage.d" -MT"panel_controller/panel_storage/storage.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/panel_storage/storage.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_storage/storage.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_storage/storage.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_controller.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/panel_controller.d" -MT"panel_controller/panel_controller.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/panel_controller.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_controller.cpp"
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr_exports.h:30,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/gpr/gpr.h:34,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_controller.cpp:48:
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_controller.cpp:62:2: warning: #warning What do we need to set here to get our throughput [-Wcpp]
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_controller.cpp:241:2: warning: #warning This for simulation only [-Wcpp]
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/panel_controller.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/panel_cbit.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/system_health/panel_cbit.d" -MT"panel_controller/system_health/panel_cbit.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/system_health/panel_cbit.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/panel_cbit.cpp"
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/panel_cbit.cpp:33:
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/panel_cbit.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/system_health.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/system_health/system_health.d" -MT"panel_controller/system_health/system_health.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/system_health/system_health.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/system_health.cpp"
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/panel_cbit.h:29,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/system_health.h:30,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/system_health.cpp:27:
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/system_health.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/pbit.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_controller/system_health/pbit.d" -MT"panel_controller/system_health/pbit.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_controller/system_health/pbit.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/pbit.cpp"
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/pbit.cpp:33:
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller/system_health/pbit.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared/SharedMemory.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"shared/SharedMemory.d" -MT"shared/SharedMemory.d" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"shared/SharedMemory.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared/SharedMemory.cpp"
In file included from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/panel_data_acq.h:36:0,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared/SharedMemory.cpp:29:
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared/SharedMemory.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/storage/log_buffer.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"storage/log_buffer.d" -MT"storage/log_buffer.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"storage/log_buffer.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/storage/log_buffer.cpp"
In file included from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/storage/log_buffer.cpp:42:0:
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/byteorder.h:7:0: warning: "LITTLE_ENDIAN" redefined
# define LITTLE_ENDIAN 1234
In file included from c:\ti\gcc-arm-none-eabi-6-2017-q1-update\arm-none-eabi\include\sys\types.h:67:0,
from c:\ti\gcc-arm-none-eabi-6-2017-q1-update\arm-none-eabi\include\stdio.h:61,
from c:\ti\gcc-arm-none-eabi-6-2017-q1-update\arm-none-eabi\include\c++\6.3.1\cstdio:42,
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/storage/log_buffer.cpp:37:
c:\ti\gcc-arm-none-eabi-6-2017-q1-update\arm-none-eabi\include\machine\endian.h:17:0: note: this is the location of the previous definition
#define LITTLE_ENDIAN _LITTLE_ENDIAN
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/byteorder.h:8:0: warning: "BIG_ENDIAN" redefined
# define BIG_ENDIAN 4321
c:\ti\gcc-arm-none-eabi-6-2017-q1-update\arm-none-eabi\include\machine\endian.h:18:0: note: this is the location of the previous definition
#define BIG_ENDIAN _BIG_ENDIAN
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/storage/log_buffer.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/panel_data_acq.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"panel_data_acq/panel_data_acq.d" -MT"panel_data_acq/panel_data_acq.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"panel_data_acq/panel_data_acq.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/panel_data_acq.cpp"
from C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/panel_data_acq.cpp:48:
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/panel_data_acq.cpp:858:2: warning: #warning Radar put into test mode with simulated waveform [-Wcpp]
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/panel_data_acq.cpp:933:2: warning: #warning This needs to reset radar scans to top of buffer. Else initBufferPtrs will cause transition from NORM to RUN to fail [-Wcpp]
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/panel_data_acq.cpp:349:13: warning: 'void resetBufferPtrs()' defined but not used [-Wunused-function]
static void resetBufferPtrs(void)
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/panel_data_acq.cpp:74:22: warning: 'accScan' defined but not used [-Wunused-variable]
static ACCGYR_SCAN_T accScan;
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq/panel_data_acq.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/crc32.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"util/crc32.d" -MT"util/crc32.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"util/crc32.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/crc32.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/crc32.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/data_q.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"util/data_q.d" -MT"util/data_q.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"util/data_q.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/data_q.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/data_q.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/data_buffer.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"util/data_buffer.d" -MT"util/data_buffer.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"util/data_buffer.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/data_buffer.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/data_buffer.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/ecc.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"util/ecc.d" -MT"util/ecc.o" @"configPkg/compiler.opt" -o"util/ecc.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/ecc.c"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/ecc.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/storage/runtime_parameter.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"storage/runtime_parameter.d" -MT"storage/runtime_parameter.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"storage/runtime_parameter.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/storage/runtime_parameter.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/storage/runtime_parameter.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/string.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"util/string.d" -MT"util/string.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"util/string.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/string.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/string.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/threads.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"util/threads.d" -MT"util/threads.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"util/threads.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/threads.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/threads.cpp"
making ../src/utils.aa15fg ...
gmake[1]: Nothing to be done for 'all'.
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/exceptions.cpp"
Invoking: GNU Compiler
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"util/exceptions.d" -MT"util/exceptions.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"util/exceptions.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/exceptions.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/exceptions.cpp"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/timesync.c"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"util/timesync.d" -MT"util/timesync.o" @"configPkg/compiler.opt" -o"util/timesync.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/timesync.c"
C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/timesync.c:259:13: warning: 'netTimeStub' defined but not used [-Wunused-function]
static void netTimeStub (void)
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/timesync.c"
Building file: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/worker.cpp"
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -c -mfloat-abi=hard -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -I"C:/ti/pdk_k2hk_4_0_9/packages" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_data_acq" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_dsp" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/panel_controller" -I"C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/shared" -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -MMD -MP -MF"util/worker.d" -MT"util/worker.o" -fno-threadsafe-statics @"configPkg/compiler.opt" -o"util/worker.o" "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/worker.cpp"
Finished building: "C:/Users/Tim Cooper/Documents/Chemring/git_panel_integ_20180727/util/worker.cpp"
making ../src/sysbios/sysbios.aa15fg ...
gmake[2]: Nothing to be done for 'all'.
Building target: "panel_arm0.out"
Invoking: GNU Linker
"C:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc.exe" -Dfar= -D__DYNAMIC_REENT__ -DSOC_K2H -DDEVICE_K2H -DU_SCAN_UPDATES_ -DU_RAW_DATA_SIM_ -D_IPC_ -ffunction-sections -fdata-sections -g -Wall -ggdb -Wunused -Wunknown-pragmas -mfloat-abi=hard -Wl,-Map,"panel_arm0.map" -nostartfiles -static -Wl,--gc-sections -L"C:/ti/pdk_k2hk_4_0_9/packages/ti/drv/pcie/lib/k2h/a15/release" -L"C:/ti/ndk_2_26_00_08/packages/ti/ndk/os/lib" -L"C:/ti/bios_6_50_01_12/packages/gnu/targets/arm/libs/install-native/arm-none-eabi/lib/fpu" --specs=rdimon.specs -o"panel_arm0.out" "./drv/accel/Accelerometer.o" "./drv/flash/flashDriver.o" "./drv/flash/flashLog.o" "./drv/flash/flashMap.o" "./drv/flash/flashParams.o" "./drv/flash/nandDriver.o" "./drv/netstack/network.o" "./drv/netstack/nimu_cppi_qmss_iface.o" "./drv/netstack/nimu_osal.o" "./drv/netstack/nimu_pa_iface.o" "./drv/pcie/pcieDriver.o" "./drv/pcie/pcieInt.o" "./drv/radar/radarDriver.o" "./gpr_interface_protocol/exception.o" "./gpr_interface_protocol/free_msg_q.o" "./gpr_interface_protocol/gip_message.o" "./gpr_interface_protocol/gip_protocol.o" "./gpr_interface_protocol/gip_server.o" "./panel_controller/gip/cmd_msg_hndlr.o" "./panel_controller/gip/data_msg_hndlr.o" "./panel_controller/gip/gip.o" "./panel_controller/gip/panel_state.o" "./panel_controller/gip/raw_msg_hndlr.o" "./panel_controller/gip/retransmit_q.o" "./panel_controller/gpr/daq_interface.o" "./panel_controller/gpr/gpr.o" "./panel_controller/panel_controller.o" "./panel_controller/panel_network.o" "./panel_controller/panel_storage/storage.o" "./panel_controller/system_health/ibit.o" "./panel_controller/system_health/panel_cbit.o" "./panel_controller/system_health/pbit.o" "./panel_controller/system_health/system_health.o" "./panel_data_acq/panel_data_acq.o" "./shared/SharedMemory.o" "./storage/log_buffer.o" "./storage/runtime_parameter.o" "./util/crc32.o" "./util/data_buffer.o" "./util/data_q.o" "./util/ecc.o" "./util/exceptions.o" "./util/string.o" "./util/threads.o" "./util/timesync.o" "./util/worker.o" -Wl,-T"configPkg/linker.cmd" -Wl,--start-group -l:ti.drv.pcie.aa15fg -lgcc -lc -lm -l:os.aa15fg -lstdc++ -Wl,--end-group
makefile:222: recipe for target 'panel_arm0.out' failed
C:\ti\ndk_2_26_00_08\packages\ti\ndk\os\lib\os.aa15fg(ossys.oa15fg): In function `stricmp':
/db/vtree/library/trees/ndk/ndk-l06/src/ti/ndk/os/ossys.c:122: undefined reference to `__locale_ctype_ptr'
c:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/lib/hard\libstdc++.a(locale.o): In function `std::locale::_Impl::_M_install_cache(std::locale::facet const*, unsigned int)':
locale.cc:(.text._ZNSt6locale5_Impl16_M_install_cacheEPKNS_5facetEj+0x18): undefined reference to `__sync_synchronize'
c:/ti/gcc-arm-none-eabi-6-2017-q1-update/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/lib/hard\libstdc++.a(locale_init.o): In function `(anonymous namespace)::get_locale_mutex()':
locale_init.cc:(.text._ZN12_GLOBAL__N_116get_locale_mutexEv+0xc): undefined reference to `__sync_synchronize'
collect2.exe: error: ld returned 1 exit status
gmake[1]: *** [panel_arm0.out] Error 1
gmake: *** [all] Error 2
makefile:218: recipe for target 'all' failed
**** Build Finished ****
