Hi.
I have a lib called system.lib.
I also have so many many CCS projects that can produce lib file.
I searched, and did not find a folder called system.
This confuses me. However, I found a little clue.
I checked the project's map file, and collected all of obj files that make up system.lib.
system.lib : init.obj (.text:Entry)
system.lib : interrupt.obj (.bss:fnRAMVectors)
system.lib : cp15.obj (.text)
system.lib : interrupt.obj (.text)
system.lib : cpu.obj (.text)
system.lib : mmu.obj (.text)
system.lib : cache.obj (.text)
system.lib : exceptionhandler.obj (.text)
system.lib : startup.obj (.text)
system.lib : startup.obj (.const:vecTbl)
system.lib : startup.obj (.const)
system.lib : cpu.obj (.data)
After filtering out, the final suspect comes out.
\armv7a
\am335x
\cgt
\exceptionhandler.asm
\ewarm
\exceptionhandler.S /*type: assembler soruce*/
\gcc
\clock.c
\device.c
\interrupt.c
\startup.c
\cgt
\cp15.asm
\cpu.c
\init.asm
\ewarm
\cp15.S /*type: assembler source*/
\cup.S /*type: assembler source*/
\init.S /*type: assembler source*/
\gcc
\Visual C++
\.vs /*invisible folder*/
\IDA8
\Debug
\... /*folders about debug*/
\system.sln /*Is this suspect?*/
\cache.c
\mmu.c
Can lib file be created by Visual C++?
Is there more smart way to find source folder that create specified lib file?
