Other Parts Discussed in Thread: AWR1843
After setting all the parameters, the compilation presents the following problems:All my .c files have the following error,Is there a solution?Thank you very much
Did you make sure that you have created CCS project in right manner and all the required path and settings are set?
Based on error 'Cannot open source file "=" ': in the CCS project, some basic setting is missing.
Try to use/refer CCS project from TI-Rex (MRR or mmw demo) for AWR1843 and build your changes on top of that (to avoid any CCS project settings error).
http://dev.ti.com/tirex/explore/node?node=AObIl5yAPR-DjIwxgdgyuA__AocYeEd__LATEST
http://dev.ti.com/tirex/explore/node?node=AH1yn4Yr-VrqkN65pfhtXg__VLyFKFf__LATEST
Jitendra
