Part Number: AWR1843
Cortex_R4_0: Trouble Removing Breakpoint with the Action "Terminate Program Execution" at 0x139c4: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 8.4.0.00006)
CS_DAP_0: Error: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 8.4.0.00006)
Cortex_R4_0: Trouble Setting Breakpoint with the Action "Terminate Program Execution" at 0x139c4: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 8.4.0.00006)
CS_DAP_0: Error: (Error -122 @ 0x0) A bad parameter value was detected within a function. It is likely a problem with `SC_ARGS' in SMG_call(). (Emulation package 8.4.0.00006)
Cortex_R4_0: Trouble Removing Breakpoint with the Action "Process CIO" at 0x12886: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 8.4.0.00006)
Cortex_R4_0: Trouble Writing Memory Block at 0x0 on Page 0 of Length 0x3c: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 8.4.0.00006)
Cortex_R4_0: File Loader: Verification failed: Target failed to write 0x00000000
Cortex_R4_0: GEL: File: C:\ti\mmwave_sdk_03_03_00_03\packages\ti\control\mmwavelink\test\xwr18xx\xwr18xx_link_mss.xer4f: Load failed.
Cortex_R4_0: Trouble Removing Breakpoint with the Action "Terminate Program Execution" at 0x139c4: (Error -2044 @ 0x139C4) Internal error: Requested breakpoint does not exist. Restart the application. If error persists, please report the error. (Emulation package 8.4.0.00006)
Cortex_R4_0: Trouble Reading Register CPSR: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 8.4.0.00006)
Cortex_R4_0: Trouble Reading Register REG_ENDIAN: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 8.4.0.00006)
Cortex_R4_0: Error: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 8.4.0.00006)
CS_DAP_0: Unable to determine target status after 20 attempts
CS_DAP_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
Cortex_R4_0: Unable to determine target status after 20 attempts
Cortex_R4_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
It works fine on other computers, but I get this error on my computer. There seems to be a problem with the xds110 driver, so i delete it and try a new download, the problem still occurs.
help me.. I am a college student
