Hi
So I have a repo with all TI extensions to be pulled from git. I have a CCS configuration script where I pull all the required extensions for CCS for a specific project. I do this for all extensions, for example the bios_6_73_01_01 as follows:
%CCS_EXE% -noSplash -data %QUM_DIR% -application com.ti.common.core.initialize -rtsc.productDiscoveryPath "%QUM_TI_DIR%\bios_6_73_01_01"
Now, for most extensions this works. However fot the said bios_6_73_01_01 extension I get the message:
!ENTRY com.ti.common.core 1 0 2021-07-12 13:21:46.399 !MESSAGE path=ccs_base/DebugServer !ENTRY com.ti.common.core 1 0 2021-07-12 13:21:46.399 !MESSAGE debugServerDir=C:/ti/ccs1040/ccs/ccs_base/DebugServer Searching for deleted extension-sites to uninstall: Finished! Searching for new extension-sites to install: Discovered new extension-site: C:\Users\...\lib\bios_6_73_01_01 Installing new extension-sites... failed! See log for errors...
If I turn on the output "-consoleLog" (where exactly is this log referred to by the message to be found???) I see the following (excerpt, there is plenty more of these messages in the form of "org.eclipse.osgi.signedcontent.InvalidContentException: The file XXX in the jar "C:\xxx\AppData\Local\Temp\signatureFile868446754174102678.jar" has been tampered!":
!SESSION 2021-07-12 13:21:44.329 ----------------------------------------------- eclipse.buildId=4.14.0.I20191210-0610 java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US Framework arguments: -application com.ti.common.core.initialize -rtsc.productDiscoveryPath C:\xxx\lib\bios_6_73_01_01 Command-line arguments: -os win32 -ws win32 -arch x86_64 -data C:\xxx\ -application com.ti.common.core.initialize -rtsc.productDiscoveryPath C:\xxx\lib\bios_6_73_01_01 -consoleLog !ENTRY com.ti.common.core 1 0 2021-07-12 13:21:46.399 !MESSAGE path=ccs_base/DebugServer !ENTRY com.ti.common.core 1 0 2021-07-12 13:21:46.399 !MESSAGE debugServerDir=C:/ti/ccs1040/ccs/ccs_base/DebugServer Searching for deleted extension-sites to uninstall: Finished! Searching for new extension-sites to install: Discovered new extension-site: C:\xxx\lib\bios_6_73_01_01 Installing new extension-sites... failed! See log for errors... !ENTRY org.eclipse.equinox.p2.engine 4 4 2021-07-12 13:21:50.082 !MESSAGE An error occurred while collecting items to be installed !SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2021-07-12 13:21:50.084 !MESSAGE session context was:(profile=epp.package.cpp, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=). !SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0 2021-07-12 13:21:50.084 !MESSAGE Problems downloading artifact: osgi.bundle,com.ti.rtsc.SYSBIOS.product.ui,6.73.1.01. !SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository 4 4 2021-07-12 13:21:50.084 !MESSAGE File has invalid content:C:\xxx\AppData\Local\Temp\signatureFile868446754174102678.jar !SUBENTRY 3 org.eclipse.equinox.p2.artifact.repository 4 2 2021-07-12 13:21:50.084 !MESSAGE Invalid content:resources/generic/minimal/main.c !STACK 0 org.eclipse.osgi.signedcontent.InvalidContentException: The file "resources/generic/minimal/main.c" in the jar "C:\xxx\AppData\Local\Temp\signatureFile868446754174102678.jar" has been tampered! at org.eclipse.osgi.internal.signedcontent.DigestedInputStream.verifyDigests(DigestedInputStream.java:111) at org.eclipse.osgi.internal.signedcontent.DigestedInputStream.read(DigestedInputStream.java:140) at org.eclipse.osgi.storage.StorageUtil.getBytes(StorageUtil.java:205) at org.eclipse.osgi.storage.bundlefile.BundleEntry.getBytes(BundleEntry.java:98) at org.eclipse.osgi.internal.signedcontent.SignedContentImpl$SignedContentEntryImpl.verify(SignedContentImpl.java:199) at org.eclipse.osgi.internal.signedcontent.SignedContentFile.getSignedEntries(SignedContentFile.java:56) at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verifyContent(SignatureVerifier.java:95) at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verify(SignatureVerifier.java:66) at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.close(SignatureVerifier.java:115) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.reportStatus(SimpleArtifactRepository.java:1250) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:636) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:776) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:319) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:289) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:225) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:155) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:759) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifacts(SimpleArtifactRepository.java:836) at org.eclipse.equinox.internal.p2.extensionlocation.ExtensionLocationArtifactRepository.getArtifacts(ExtensionLocationArtifactRepository.java:260) at org.eclipse.equinox.internal.p2.engine.DownloadManager.fetch(DownloadManager.java:127) at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:98) at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:111) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:255) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:105) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:50) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:80) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:48) at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:181) at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:76) at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.installFeatures(ExtensionSiteDiscoveryManager.java:794) at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.installExtensionSites(ExtensionSiteDiscoveryManager.java:343) at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.discoverAndInstallExtensionSites(ExtensionSiteDiscoveryManager.java:222) at org.eclipse.rtsc.project.core.extdiscovery.RTSCHeadlessInitializationParticipant.run(RTSCHeadlessInitializationParticipant.java:57) at com.ti.common.core.internal.headless.Initialize.run(Initialize.java:124) at com.ti.common.core.internal.headless.Initialize.start(Initialize.java:82) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594) at org.eclipse.equinox.launcher.Main.run(Main.java:1465) !SUBENTRY 3 org.eclipse.equinox.p2.artifact.repository 4 2 2021-07-12 13:21:50.084 !MESSAGE Invalid content:plugin.xml !STACK 0 org.eclipse.osgi.signedcontent.InvalidContentException: The file "plugin.xml" in the jar "C:\xxx\AppData\Local\Temp\signatureFile868446754174102678.jar" has been tampered! at org.eclipse.osgi.internal.signedcontent.DigestedInputStream.verifyDigests(DigestedInputStream.java:111) at org.eclipse.osgi.internal.signedcontent.DigestedInputStream.read(DigestedInputStream.java:140) at org.eclipse.osgi.storage.StorageUtil.getBytes(StorageUtil.java:205) at org.eclipse.osgi.storage.bundlefile.BundleEntry.getBytes(BundleEntry.java:98) at org.eclipse.osgi.internal.signedcontent.SignedContentImpl$SignedContentEntryImpl.verify(SignedContentImpl.java:199) at org.eclipse.osgi.internal.signedcontent.SignedContentFile.getSignedEntries(SignedContentFile.java:56) at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verifyContent(SignatureVerifier.java:95) at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verify(SignatureVerifier.java:66) at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.close(SignatureVerifier.java:115) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.reportStatus(SimpleArtifactRepository.java:1250) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:636) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:776) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:319) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:289) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:225) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:155) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:759) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifacts(SimpleArtifactRepository.java:836) at org.eclipse.equinox.internal.p2.extensionlocation.ExtensionLocationArtifactRepository.getArtifacts(ExtensionLocationArtifactRepository.java:260) at org.eclipse.equinox.internal.p2.engine.DownloadManager.fetch(DownloadManager.java:127) at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:98) at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:111) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:255) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:105) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:50) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:80) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:48) at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:181) at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:76) at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.installFeatures(ExtensionSiteDiscoveryManager.java:794) at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.installExtensionSites(ExtensionSiteDiscoveryManager.java:343) at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.discoverAndInstallExtensionSites(ExtensionSiteDiscoveryManager.java:222) at org.eclipse.rtsc.project.core.extdiscovery.RTSCHeadlessInitializationParticipant.run(RTSCHeadlessInitializationParticipant.java:57) at com.ti.common.core.internal.headless.Initialize.run(Initialize.java:124) at com.ti.common.core.internal.headless.Initialize.start(Initialize.java:82) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594) at org.eclipse.equinox.launcher.Main.run(Main.java:1465) !SUBENTRY 3 org.eclipse.equinox.p2.artifact.repository 4 2 2021-07-12 13:21:50.092 !MESSAGE Invalid content:eclipse_toc.xml !STACK 0 org.eclipse.osgi.signedcontent.InvalidContentException: The file "eclipse_toc.xml" in the jar "C:\xxx\AppData\Local\Temp\signatureFile868446754174102678.jar" has been tampered! at org.eclipse.osgi.internal.signedcontent.DigestedInputStream.verifyDigests(DigestedInputStream.java:111) at org.eclipse.osgi.internal.signedcontent.DigestedInputStream.read(DigestedInputStream.java:140) at org.eclipse.osgi.storage.StorageUtil.getBytes(StorageUtil.java:205) at org.eclipse.osgi.storage.bundlefile.BundleEntry.getBytes(BundleEntry.java:98) at org.eclipse.osgi.internal.signedcontent.SignedContentImpl$SignedContentEntryImpl.verify(SignedContentImpl.java:199) at org.eclipse.osgi.internal.signedcontent.SignedContentFile.getSignedEntries(SignedContentFile.java:56) at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verifyContent(SignatureVerifier.java:95) at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verify(SignatureVerifier.java:66) at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.close(SignatureVerifier.java:115) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.reportStatus(SimpleArtifactRepository.java:1250) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:636) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:776) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:319) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:289) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:225) at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:155) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:759) at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifacts(SimpleArtifactRepository.java:836) at org.eclipse.equinox.internal.p2.extensionlocation.ExtensionLocationArtifactRepository.getArtifacts(ExtensionLocationArtifactRepository.java:260) at org.eclipse.equinox.internal.p2.engine.DownloadManager.fetch(DownloadManager.java:127) at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:98) at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:111) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:255) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:105) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:50) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:80) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:48) at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:181) at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:76) at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.installFeatures(ExtensionSiteDiscoveryManager.java:794) at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.installExtensionSites(ExtensionSiteDiscoveryManager.java:343) at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.discoverAndInstallExtensionSites(ExtensionSiteDiscoveryManager.java:222) at org.eclipse.rtsc.project.core.extdiscovery.RTSCHeadlessInitializationParticipant.run(RTSCHeadlessInitializationParticipant.java:57) at com.ti.common.core.internal.headless.Initialize.run(Initialize.java:124) at com.ti.common.core.internal.headless.Initialize.start(Initialize.java:82) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594) at org.eclipse.equinox.launcher.Main.run(Main.java:1465) !SUBENTRY 3 org.eclipse.equinox.p2.artifact.repository 4 2 2021-07-12 13:21:50.092 !MESSAGE Invalid content:resources/generic/typical/cortexm/app.cfg !STACK 0
How can I force install or bypass this? I have read that it might be because of gits autocrlf, but we need the autocrlf feature and it works for other packages?
You mentioned you are working with git. It could be related to the post below:
ki
Disregard my last post since it appears you may have already seen it.
I'll need to investigate why the issue appears to happen with SYS/BIOS
ki
Hi thanks
I think it might be related to how codecomposer interacts with modified packages. I disabled autocrlf and also pushed every single file of bios to git. I have a running local copy of the project and all libs, however once I clone or checkout the package gets messed up (it is even messed up if i clone to the same device). Likely the package gets modified by CCS locally which is then incompatible on a different device/intance?
steps to reproduce:
1) create folder structure
lib/
proj/
2) copy bios_xxx and other libs to lib/* and create new CCS project (workspace in proj/)
3) configure CCS to use packages in lib/* for the current project and installation
4) git init on / and push
5) git clone of above repo
6) fresh install of CCS, import/install lib/*
7) install of bios will fail.
Thanks. I'll have to set up a git environment to try this with. Lets consolidate this discussion in the other thread you have so that we don't have to go back and forth between two related threads. I'll close this discussion and add any updates for this to the other thread.
