Part Number: CODECOMPOSER
Other Parts Discussed in Thread: CCSTUDIO
When CCS7.4 is installed in a centos docker container the following error occurs when running Code Composer. I have seen the information about windows installs requiring MVCS but that would not apply to linux correct?
/opt/ti/ccsv7/eclipse/eclipse -noSplash -data /workspace -application com.ti.ccstudio.apps.projectImport -ccs.location ./dspApp
!SESSION 2022-03-24 15:49:30.972 -----------------------------------------------
eclipse.buildId=4.6.0.I20160606-1100
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -application com.ti.common.core.initialize
Command-line arguments: -os linux -ws gtk -arch x86_64 -data /workspace -application com.ti.common.core.initialize
!ENTRY com.ti.common.core 4 0 2022-03-24 15:49:32.155
!MESSAGE debugServerDir=/opt/ti/ccsv7/ccs_base/DebugServer
!ENTRY org.eclipse.osgi 4 0 2022-03-24 15:49:35.289
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: com/ti/utility/filesystem/DirectoryService
at com.ti.common.core.utils.ds.CoreUtilsProvider.getUserHomeDir(CoreUtilsProvider.java:40)
at com.ti.common.core.CoreUtils.getUserHomeDir(CoreUtils.java:135)
at com.ti.common.core.internal.ExternalReferenceParser.getUserExtRefDir(ExternalReferenceParser.java:176)
at com.ti.common.project.core.internal.resexplorer.ResourceExplorerBreadcrumbFileReader.getBreadcrumbFile(ResourceExplorerBreadcrumbFileReader.java:158)
at com.ti.common.project.core.internal.resexplorer.ResourceExplorerBreadcrumbFileReader.isDataStale(ResourceExplorerBreadcrumbFileReader.java:146)
at com.ti.common.project.core.internal.resexplorer.ResourceExplorerBreadcrumbFileReader.updateData(ResourceExplorerBreadcrumbFileReader.java:76)
at com.ti.common.project.core.internal.resexplorer.ResourceExplorerBreadcrumbFileReader.getProductDiscoveryPath(ResourceExplorerBreadcrumbFileReader.java:49)
at com.ti.common.project.core.internal.tools.ADiscoveryManager.toSearchPath(ADiscoveryManager.java:375)
at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.discoverAndInstallExtensionSites(ExtensionSiteDiscoveryManager.java:199)
at org.eclipse.rtsc.project.core.extdiscovery.RTSCHeadlessInitializationParticipant.run(RTSCHeadlessInitializationParticipant.java:54)
at com.ti.common.core.internal.headless.Initialize.run(Initialize.java:87)
at com.ti.common.core.internal.headless.Initialize.start(Initialize.java:53)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: java.lang.ClassNotFoundException: com.ti.utility.filesystem.DirectoryService cannot be found by com.ti.common.core.utils.ds_1.0.0.201711260800
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:448)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:361)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:353)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
