I had a product released with LM3S9B95 rev C1 CPU and CCSv4 release unknown but purchased in May 2010. The Errata says to set the vector table from 0x00001000. So I did. Every thing was working ok.
Now I upgraded to release 4.2.3.00004. I opened same project, recompiled and started debug mode. Not working. I checked deeply and found that NVIC VTABLE offset register never set to offset 0x1000. So I restarted the debug mode and manually set the NVIC VTABLE offset register to 0x00001000. Every thing run ok.
So what is the difference between old release and this new release that do not set the NVIC VTABLE offset register. I am using same linker file and that is listed below.
* Default Linker Command file for the Texas Instruments LM3S9B95
* This is part of revision 5745 of the Stellaris Peripheral Driver Library.
--retain=g_pfnVectors
MEMORY
FLASH (RX) : origin = 0x00001000, length = 0x00040000
SRAM (RWX) : origin = 0x20000000, length = 0x00018000
/* The following command line options are set as part of the CCS project. */
/* If you are building using the command line, or for some reason want to */
/* define them here, you can uncomment and modify these lines as needed. */
/* If you are using CCS for building, it is probably better to make any such */
/* modifications in your CCS project and leave this file alone. */
/* --heap_size=0 */
/* --stack_size=256 */
/* --library=rtsv7M3_T_le_eabi.lib */
/* Section allocation in memory */
SECTIONS
.intvecs: > 0x00001000
.text : > FLASH
.const : > FLASH
.cinit : > FLASH
.pinit : > FLASH
.vtable : > 0x20000000
.data : > SRAM
.bss : > SRAM
.sysmem : > SRAM
.stack : > SRAM
__STACK_TOP = __stack + 256;
Also my startup_ccs.c listing
// startup_ccs.c - Startup code for use with TI's Code Composer Studio.
// Copyright (c) 2009-2010 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 5821 of the EK-LM3S9B92 Firmware Package.
// Forward declaration of the default fault handlers.
void ResetISR(void);
static void NmiSR(void);
static void FaultISR(void);
static void IntDefaultHandler(void);
static void FlashHandler(void);
static unsigned long faultCnt = 0;
static unsigned long nmiCnt = 0;
static unsigned long intDefCnt = 0;
// External declaration for the reset handler that is to be called when the
// processor is started
extern void _c_int00(void);
// Linker variable that marks the top of the stack.
extern unsigned long __STACK_TOP;
// External declaration for the interrupt handler used by the application.
extern void UART0IntHandler(void);
extern void UART1IntHandler(void);
extern void UART2IntHandler(void);
extern void uDMAErrorHandler(void);
extern void Timer0AIntHandler(void);
extern void GPIOPortAIntHandler(void);
extern void GPIOPortBIntHandler(void);
extern void GPIOPortCIntHandler(void);
extern void GPIOPortDIntHandler(void);
extern void GPIOPortEIntHandler(void);
extern void GPIOPortFIntHandler(void);
extern void GPIOPortGIntHandler(void);
// The vector table. Note that the proper constructs must be placed on this to
// ensure that it ends up at physical address 0x0000.0000 or at the start of
// the program if located at a start address other than 0.
#pragma DATA_SECTION(g_pfnVectors, ".intvecs")
void (* const g_pfnVectors[])(void) =
(void (*)(void))((unsigned long)&__STACK_TOP),
// The initial stack pointer
ResetISR, // The reset handler
NmiSR, // The NMI handler
FaultISR, // The hard fault handler
IntDefaultHandler, // The MPU fault handler
IntDefaultHandler, // The bus fault handler
IntDefaultHandler, // The usage fault handler
0, // Reserved
0, // Reserved
0, // Reserved
0, // Reserved
IntDefaultHandler, // SVCall handler
IntDefaultHandler, // Debug monitor handler
0, // Reserved
IntDefaultHandler, // The PendSV handler
IntDefaultHandler, // The SysTick handler
GPIOPortAIntHandler, // GPIO Port A
GPIOPortBIntHandler, // GPIO Port B
GPIOPortCIntHandler, // GPIO Port C
GPIOPortDIntHandler, // GPIO Port D
GPIOPortEIntHandler, // GPIO Port E
UART0IntHandler, // UART0 Rx and Tx
UART1IntHandler, // UART1 Rx and Tx
IntDefaultHandler, // SSI0 Rx and Tx
IntDefaultHandler, // I2C0 Master and Slave
IntDefaultHandler, // PWM Fault
IntDefaultHandler, // PWM Generator 0
IntDefaultHandler, // PWM Generator 1
IntDefaultHandler, // PWM Generator 2
IntDefaultHandler, // Quadrature Encoder 0
IntDefaultHandler, // ADC Sequence 0
IntDefaultHandler, // ADC Sequence 1
IntDefaultHandler, // ADC Sequence 2
IntDefaultHandler, // ADC Sequence 3
IntDefaultHandler, // Watchdog timer
Timer0AIntHandler, // Timer 0 subtimer A
IntDefaultHandler, // Timer 0 subtimer B
IntDefaultHandler, // Timer 1 subtimer A
IntDefaultHandler, // Timer 1 subtimer B
IntDefaultHandler, // Timer 2 subtimer A
IntDefaultHandler, // Timer 2 subtimer B
IntDefaultHandler, // Analog Comparator 0
IntDefaultHandler, // Analog Comparator 1
IntDefaultHandler, // Analog Comparator 2
IntDefaultHandler, // System Control (PLL, OSC, BO)
FlashHandler, // FLASH Control
GPIOPortFIntHandler, // GPIO Port F
GPIOPortGIntHandler, // GPIO Port G
IntDefaultHandler, // GPIO Port H
UART2IntHandler, // UART2 Rx and Tx
IntDefaultHandler, // SSI1 Rx and Tx
IntDefaultHandler, // Timer 3 subtimer A
IntDefaultHandler, // Timer 3 subtimer B
IntDefaultHandler, // I2C1 Master and Slave
IntDefaultHandler, // Quadrature Encoder 1
IntDefaultHandler, // CAN0
IntDefaultHandler, // CAN1
IntDefaultHandler, // CAN2
IntDefaultHandler, // Ethernet
IntDefaultHandler, // Hibernate
IntDefaultHandler, // USB0
IntDefaultHandler, // PWM Generator 3
IntDefaultHandler, // uDMA Software Transfer
uDMAErrorHandler, // uDMA Error
IntDefaultHandler, // uDMA Error
IntDefaultHandler, // ADC1 Sequence 0
IntDefaultHandler, // ADC1 Sequence 1
IntDefaultHandler, // ADC1 Sequence 2
IntDefaultHandler, // ADC1 Sequence 3
IntDefaultHandler, // I2S0
IntDefaultHandler, // External Bus Interface 0
IntDefaultHandler // GPIO Port J
// This is the code that gets called when the processor first starts execution
// following a reset event. Only the absolutely necessary set is performed,
// after which the application supplied entry() routine is called. Any fancy
// actions (such as making decisions based on the reset cause register, and
// resetting the bits in that register) are left solely in the hands of the
// application.
void
ResetISR(void)
// Jump to the CCS C Initialization Routine.
__asm(" .global _c_int00\n"
" b.w _c_int00");
// This is the code that gets called when the processor receives a NMI. This
// simply enters an infinite loop, preserving the system state for examination
// by a debugger.
static void
NmiSR(void)
// Enter an infinite loop.
while(1)
// This is the code that gets called when the processor receives a fault
// interrupt. This simply enters an infinite loop, preserving the system state
// for examination by a debugger.
static void
FaultISR(void)
while(1)
// This is the code that gets called when the processor receives an unexpected
static void
// Go into an infinite loop.
while(1)
// This is according to work around for rev C1 with silver dot. So take it off if we do not
// have that revision.
#define WorkaroundIntHandler ((void (*)(void))0x881)
static void
FlashHandler(void)
WorkaroundIntHandler();
